S16B-XADSS-N
S16B-XADSS-N
    JST
    S16B-XADSS-N
S16B-XADSS-N 数据手册
XAD CONNECTOR 2.5 mm pitch/Disconnectable Crimp style connectors Specifications XAD CONNECTOR • Current rating: 3 A AC/DC (AWG #20) • Voltage rating: 250 V AC/DC • Temperature range: -25℃ to +85℃ (including temperature rise in applying electrical current) • Contact resistance: Initial value/10 mΩ max. After environmental tests/ 20 mΩ max. • Insulation resistance: 1,000 MΩ min. • Withstanding voltage: 1,000 VAC/minute • Applicable wire: AWG #28 to #20 • Applicable PC board thickness: 1.6 mm XAD Dual-row construction connector with secure locking device. Secure locking device Solder crack preventive material Polarizing boss Mis-insertion preventive design Standards ® Recognized E60389 Certified LR20812 R9851219 ® ® ® ® PC board layout and Assembly layout (11.5) Top entry type +0.1 φ0.9 0 ●With a boss ●Without a boss A±0.05 Side entry type 2.5±0.05 2.5±0.05 ±0.05 1.7 +0.1 φ0.9 0 2.5±0.05 φ1.1+0.1  0 2.5±0.05 1.8±0.05 Even number circuits Odd number circuits Circuit No.1 A±0.05 Even number circuits Odd number circuits Circuit No.1 (13.8) ● ● ● ● * In using the products,refer to "Handling Precautions for Terminals and Connectors" described on our website (Technical documents of Product information page). * RoHS2 compliance * Dimensional unit: mm * Contact JST for details. 2.8±0.05 2.5±0.05 A±0.05 (13.5) 2.5 ±0.05 Even number circuits 7.6±0.05 Circuit No.1 Odd number circuits 2.0±0.05 (19.9) +0.1 φ0.9 0 Note: 1 . The above figure is the figure viewed from the connector mounting side. 2. Tolerances are non-cumulative: ± 0.05 mm for all centers. 3. Hole dimension differ according to the type of PC board and piercing method. The dimensions above should serve as a guideline. Contact JST for details. 1 XAD CONNECTOR Contact Model No. 1.9 SXA-01T-P0.6 SXA-001T-P0.6 SXA-001T-P0.6L 3.1 6.5 1.3 Applicable wire mm2 AWG# Insulation O.D. (mm) Q’ty/reel 0.22~0.5  24~20 1.5~1.9 8,000 0.08~0.33 28~22 0.8~1.9 8,000 0.13~0.33 26~22 1.3~1.7 8,000 Material and Finish 1.6 Phosphor bronze, tin-plated (reflow treatment) 2.3 RoHS2 compliance Note: 1 . SXA-001T-P0.6L is low-insertion force type contact, for easier insertion/withdrawal, which would be less resistant to the vibration. The crimp height is different from the standard contact. 2. Contact JST for gold-plated products. Contact Applicator Crimping machine Crimp applicator Dies SXA-01T-P0.6 SXA-001T-P0.6 MKS-L AP-K2N SXA-001T-P0.6L Crimp applicator with dies MK/SXA/M-01-06 APLMK SXA/M01-06 MK/SXA/M-001-06 APLMK SXA/M001-06 MK/SXA/M-001-06L APLMK SXA/M001-06L Note: Contact JST for fully automatic crimping applicator. Housing 〈8 to 16 circuits〉 B A 2.5 Circuit No.1 mark 11.4 3.6 12 6.8 H JST 12 〈18 to 40 circuits〉 B A 2.5 Circuit No.1 mark 3.6 11.4 Model No. Dimensions (mm) A B Q'ty/bag 8 XADRP-08V 7.5 14.7 1,000 10 XADRP-10V 10.0 17.2 1,000 12 XADRP-12V 12.5 19.7 1,000 14 XADRP-14V 15.0 22.2 1,000 16 XADRP-16V 17.5 24.7 1,000 18 XADRP-18V 20.0 27.2 1,000 20 XADRP-20V 22.5 29.7 500 22 XADRP-22V 25.0 32.2 500 24 XADRP-24V 27.5 34.7 500 26 XADRP-26V 30.0 37.2 500 28 XADRP-28V 32.5 39.7 500 30 XADRP-30V 35.0 42.2 500 32 XADRP-32V 37.5 44.7 500 34 XADRP-34V 40.0 47.2 500 36 XADRP-36V 42.5 49.7 250 40 XADRP-40V 47.5 54.7 250 12 6.8 H JST 30 No. of circuits Material and Finish PA 66, UL94V-0, natural (white) RoHS2 compliance Note: Contact JST if retainers are required. As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. ex. XADRP-08V-oo(blank)...natural (white) K...black R...red E...blue O...orange M...green L...lemon yellow PK...pink 2 XAD CONNECTOR Shrouded header Top entry type No. of circuits 〈8 to 16 circuits〉 B A 2.5 (3.5) 10.1 1.5 H JST 12 1.7 〈18 to 40 circuits〉 B A Circuit No.1 Mark H JST 22 1.7 φ 0.6 2.5 1.8 φ0.9 10.1 (3.5) 10.1 1.5 φ0.6 2.5 10.1 Circuit No.1 Mark 2.5 1.8 φ 0.9 Without a boss With a boss A B Side entry type 8 B08B-XADSS-N B08B-XADSS-N-A S08B-XADSS-N 7.5 15.0 200 270 B10B-XADSS-N B10B-XADSS-N-A S10B-XADSS-N 10.0 17.5 200 234 12 B12B-XADSS-N B12B-XADSS-N-A S12B-XADSS-N 12.5 20.0 200 198 14 B14B-XADSS-N B14B-XADSS-N-A S14B-XADSS-N 15.0 22.5 150 180 16 B16B-XADSS-N B16B-XADSS-N-A S16B-XADSS-N 17.5 25.0 150 162 18 B18B-XADSS-N B18B-XADSS-N-A S18B-XADSS-N 20.0 27.5 150 144 20 B20B-XADSS-N B20B-XADSS-N-A S20B-XADSS-N 22.5 30.0 100 126 22 B22B-XADSS-N B22B-XADSS-N-A - 25.0 32.5 100 - 24 B24B-XADSS-N B24B-XADSS-N-A - 27.5 35.0 100 - 26 B26B-XADSS-N B26B-XADSS-N-A S26B-XADSS-N 30.0 37.5 100 108 28 B28B-XADSS-N B28B-XADSS-N-A - 32.5 40.0 100 - 30 B30B-XADSS-N B30B-XADSS-N-A - 35.0 42.5 50 - 32 B32B-XADSS-N B32B-XADSS-N-A - 37.5 45.0 50 - 34 B34B-XADSS-N B34B-XADSS-N-A - 40.0 47.5 50 - 36 B36B-XADSS-N B36B-XADSS-N-A - 42.5 50.0 50 - 40 B40B-XADSS-N B40B-XADSS-N-A - 47.5 55.0 50 - Material and Finish 〈8 to 16 circuits〉 B A 3.5 12.1 RoHS2 compliance   This product displays (LF)(SN) on a label. Note: Contact JST for the headers with gold-plated pins. As the color identification, the following alphabet shall be put in the underlined part. For availability, delivery and minimum order quantity, contact JST. 9.9 2.7 φ0.6 16.2 10.3 2.5 Pin: Copper alloy, copper-undercoated, tin-plated (reflow treatment) Wafer: Glass-filled PA 66, UL94V-0, natural (white) 2.5 ex. (3.4) 3.5 9.9 φ0.6 16.2 10.3 2.5 12.1 2.5 2.7 B A B08B-XADSS-NS...natural (white) K...black R...red E...blue O...orange M...green L...lemon yellow PK...pink 9.9 〈18 to 26 circuits〉 2.5 Side entry type Q’ty/box Top entry type 10 Side entry type 2.5 Dimensions (mm) Model No. Top entry type (3.4) 9.9 3
S16B-XADSS-N 价格&库存
很抱歉,暂时无法提供与“S16B-XADSS-N”相匹配的价格&库存,您可以联系我们找货
S16B-XADSS-N
    • 162+3.42210
    库存:648
