DSS12 THRU DSS120
SOD-123FL
FEATURES
Cathode Band
Top View
1.8± 0.1
1.0±0.2
The plastic package carries Underwriters Laboratory
Flammability Classification 94V-0
Metal silicon junction,majority carrier conduction
Low power loss,high efficiency
High forward surge current capability
High temperature soldering guaranteed:
250 C/10 seconds,0.375”(9.5mm) lead length,
5 lbs. (2.3kg) tension
1.3± 0.15
0.10-0.30
2.8±0.1
0.6±0.25
MECHANICAL DATA
Case: JEDEC SOD-123FL molded plastic body
Terminals: Solderable per MIL-STD-750,
Method 2026
Polarity: Color band denotes cathode end
Mounting Position: Any
Weight:0.0007 ounce, 0.02 grams
3.7±0.2
Dimensions in millimeters
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
Ratings at 25 C ambient temperature unless otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
Catalog
Number
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
Maximum average forward rectified current
Peak forward surge current
8.3ms single half sine-wave superimposed on
rated load (JEDEC Method)
Maximum instantaneous forward voltage at 1.0A
Maximum DC reverse current
TA=25 C
at rated DC blocking voltage
TA=100 C
Typical junction capacitance (NOTE 1)
Operating junction temperature range
Storage temperature range
SYMBOLS DSS12 DSS13 DSS14
K12
K13
K14
VRRM
VRMS
VDC
DSS15
K15
DSS16
K16
DSS17
K17
40
50
60
70
80
90
100
150
200
14
21
28
35
42
49
56
63
70
105
140
40
50
60
70
80
90
100
150
I(AV)
1.0
IFSM
25.0
VF
0.85
0.5
5.0
10.0
80
110
TJ
TSTG
-65 to +125
-65 to +150
-65 to +150
Note:1.Measured at 1MHz and applied reverse voltage of 4.0V D.C.
1/2
UNITS
VOLTS
VOLTS
200 VOLTS
Amp
Amps
0.70
0.55
IR
CJ
DSS18 DSS19 DSS110 DSS115 DSS120
K18
K19
K110
K115
K120
0.95
0.2
2.0
Volts
mA
pF
C
C
FIG. 1- FORWARD CURRENT DERATING CURVE
1
0.8
Single Phase
Half Wave 60Hz
Resistive or
inductive Load
0.6
0.4
DSS12-DSS16
DSS17-DSS120
0.2
50
75
100
125
150
PEAK FORWARD SURGE CURRENT,
AMPERES
AVERAGE FORWARD RECTIFIED CURRENT,
AMPERES
DSS12 THRU DSS120
FIG. 2-MAXIMUM NON-REPETITIVE PEAK FORWARD
SURGE CURRENT
30
8.3ms SINGLE HALF SINE-WAVE
(JEDEC Method)
25
10
5.0
175
FIG. 3-TYPICAL INSTANTANEOUS FORWARD
CHARACTERISTICS
1
TJ=25 C
PULSE WIDTH=300 µs
1%DUTY CYCLE
DSS12-DSS14
DSS15-DSS16
DSS17-DSS115
DSS120
0.1
0.01
0.2
0.4
0.6
0.8
1.0
1.1
FIG. 4-TYPICAL REVERSE CHARACTERISTICS
10
TJ=100 C
1
TJ=75 C
0.1
JUNCTION CAPACITANCE, pF
FIG. 5-TYPICAL JUNCTION CAPACITANCE
1000
DSS12-DSS14
DSS15-DSS120
100
TJ=25 C
10
10
TJ=25 C
0.01
60
80
PERCENT OF PEAK REVERSE VOLTAGE,%
2000
1.0
100
100
0.001
INSTANTANEOUS FORWARD VOLTAGE,
VOLTS
0.1
10
NUMBER OF CYCLES AT 60 Hz
INSTANTANEOUS REVERSE CURRENT,
MILLIAMPERES
CURRENT,AMPERES
AMBIENT TEMPERATURE, C
100
REVERSE VOLTAGE,VOLTS
2/2
100
很抱歉,暂时无法提供与“DSS16”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.13889
- 200+0.10865
- 600+0.09180
- 3000+0.07982
- 9000+0.07107
- 21000+0.06632
