TSSE3H60
TSSE3H60
    TAIWANSEMICONDUCTOR(台湾半导体)
    SOD123H
    TSSE3H60
TSSE3H60 数据手册
TSSE3H45 – TSSE3H60 Taiwan Semiconductor 3A, 45V - 60V Trench Schottky Surface Mount Rectifier FEATURES ● ● ● ● ● ● ● ● KEY PARAMETERS Patented Trench Schottky technology Excellent high temperature stability Low forward voltage Lower power loss/ high efficiency High forward surge capability Moisture sensitivity level: level 1, per J-STD-020 RoHS Compliant Halogen-free according to IEC 61249-2-21 PARAMETER VALUE UNIT IF 3 A VRRM 45 - 60 V IFSM 60 A TJ MAX 150 °C Package SOD-123HE Configuration Single die APPLICATIONS ● Switching mode power supply (SMPS) ● Adapters ● DC to DC converter MECHANICAL DATA ● ● ● ● ● ● Case: SOD-123HE Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Meet JESD 201 class 2 whisker test Polarity: Indicated by cathode band Weight: 0.022g (approximately) SOD-123HE ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL Marking code on the device TSSE3H45 TSSE3H60 E3H45 E3H60 UNIT Repetitive peak reverse voltage VRRM 45 60 V Reverse voltage, total rms value VR(RMS) 32 42 V Forward current Peak forward surge current, 8.3ms single half sine-wave superimposed on rated load Junction temperature IF 3 A IFSM 60 A TJ - 55 to +150 °C Storage temperature TSTG - 55 to +150 °C 1 Version: D2103 TSSE3H45 – TSSE3H60 Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER Junction-to-lead thermal resistance SYMBOL TYP UNIT RӨJL 20 °C/W ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER CONDITIONS TSSE3H45 Forward voltage (1) TSSE3H60 Reverse current @ rated VR (2) SYMBOL IF = 3A, TJ = 25°C IF = 3A, TJ = 125°C IF = 3A, TJ = 25°C VF IF = 3A, TJ = 125°C TJ = 25°C IR TJ = 125°C TYP MAX UNIT 0.47 0.57 V 0.40 0.50 V 0.50 0.60 V 0.43 0.53 V - 100 µA - 25 mA Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms ORDERING INFORMATION ORDERING CODE(1) PACKAGE PACKING TSSE3Hx SOD-123HE 10,000 / Tape & Reel Notes: 1. “x” defines voltage from 45V(TSSE3H45) to 60V(TSSE3H60) 2 Version: D2103 TSSE3H45 – TSSE3H60 Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Typical Junction Capacitance 1000 3 CAPACITANCE (pF) 2 1 100 f=1.0MHz Vsig=50mVp-p 10 0 50 75 100 125 0.1 150 1 LEAD TEMPERATURE (°C) INSTANTANEOUS FORWARD CURRENT (A) TJ=150°C TJ=125°C 0.1 TJ=100°C 0.01 0.001 TJ=25°C 0.0001 20 30 40 50 60 70 80 90 100 1010 TSSE3H45 1 1 UF1DLW TJ=150oC oC=125°C TJ=125T J TJ=25°C 0.1 TJ=100oC 0.1 TJ=25oC 0.01 0.01 0.001 0.0 0.1 0.2 0.3 0.4 0.5 Pulse width 300μs 1% duty cycle Pulse width 0.3 0.6 0.4 0.7 0.5 0.8 0.6 0.9 0.7 1 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) FORWARD VOLTAGE (V) Fig.5 Typical Reverse Characteristics Fig.6 Typical Forward Characteristics 100 TSSE3H60 INSTANTANEOUS FORWARD CURRENT (A) INSTANTANEOUS REVERSE CURRENT (mA) TSSE3H45 10 INSTANTANEOUS REVERSE CURRENT (mA) Fig.4 Typical Forward Characteristics 100 1 100 REVERSE VOLTAGE (V) Fig.3 Typical Reverse Characteristics 10 10 TJ=150°C 10 1 TJ=125°C 0.1 TJ=100°C 0.01 0.001 TJ=25°C 0.0001 10 20 30 40 50 60 70 80 90 100 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) (A) 25 1.1 1.2 1.1 1.2 1010 TSSE3H60 1 1 UF1DLW TJ=150oC TJ=125ToC =125°C J 0.1 0.1 0.01 TJ=100oC TJ=25°C (A) AVERAGE FORWARD CURRENT (A) 4 TJ=25oC Pulse width 300μs 1% duty cycle Pulse width 0.01 0.001 0.0 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.3 0.4 0.5 0.6 0.7 0.8 0.9 0.8 1 FORWARD VOLTAGE (V) 3 Version: D2103 TSSE3H45 – TSSE3H60 Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS SOD-123HE SUGGESTED PAD LAYOUT MARKING DIAGRAM 4 P/N = Marking Code YW = Date Code F = Factory Code Version: D2103 TSSE3H45 – TSSE3H60 Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 5 Version: D2103
TSSE3H60 价格&库存
很抱歉,暂时无法提供与“TSSE3H60”相匹配的价格&库存,您可以联系我们找货
TSSE3H60
  • 10000+1.0632510000+0.13822
  • 30000+0.9386330000+0.12202
库存:60265
TSSE3H60
  • 1+5.556911+0.72238
  • 10+3.4226710+0.44494
  • 50+2.4836550+0.32287
  • 100+2.17861100+0.28322
  • 500+1.64056500+0.21327
库存:60265
