PS0612FKG070R01L
PS0612FKG070R01L
    YAGEO(国巨)
    PS0612FKG070R01L
PS0612FKG070R01L 数据手册
DATA SHEET CURRENT SENSOR - LOW TCR 4 Termination PS series 5%, 1%, 0.5% sizes 0306/0612 Product specification – May 18, 2021 V.2 Supersedes Date of Mar. 06, 2003 RoHS compliant & Halogen free Product specification Chip Resistor Surface Mount SERIES PS 2 11 0306/0612 SCOPE ORDERING INFORMATION - GLOBAL PART NUMBER This specification describes PS series 4-terminal current sensor - low TCR chip resistors made by metal alloy process. Global part numbers are identified by the series, size, tolerance, packing type, temperature coefficient, taping reel and resistance value. GLOBAL PART NUMBER PS XXXX X X X XX XXXX L (1) APPLICATIONS  Battery pack  Inverter/Converter (DCDC/AC-DC/DC-AC)  Consumer electronics  Laptops FEATURES  Total lead free without RoHS exemption  High component and equipment reliability  Ultra low resistance and narrow tolerance suitable for current detection (2) (3) (4) (5) (6) (7) (1) SIZE 0306/0612 (2) TOLERANCE D = ± 0.5% (2mΩ, 10mΩ, 20mΩ) F = ± 1% J = ± 5% (3) PACKAGING TYPE K = Embossed taping reel R = Paper taping reel (4) TEMPERATURE COEFFICIENT OF RESISTANCE M F L G P = ± 75ppm/°C = ± 100ppm/°C = ± 150ppm/°C = ± 200ppm/°C = ± 300ppm/°C (5) TAPING REEL 07 / 7W / 7T= 7 inch dia. Reel and specific rated power. Detailed power rating are shown in the Table 2. (6) RESISTANCE VALUE 0.5mΩ to 100mΩ There are 3~5 digits indicated the resistance value. Letter R is decimal point. Detailed coding rules of resistance are shown in the table of “Resistance rule of global part number”. (7) DEFAULT CODE Letter L is the system default code for ordering only. (Note) Resistance rule of global part number Resistance code rule Example 0R001 = 1mΩ 0RXXX 0UX 0R1 = 100mΩ 0U5 = 0.5mΩ ORDERING EXAMPLE The ordering code of a PS0306 1/4W chip resistor, value 0.003 Ω with ± 1% tolerance, supplied in 7inch tape reel is: PS0306FRL070R003L NOTE 1. All our RSMD products are RoHS compliant. "LFP" of the internal 2D reel label mentions "Lead-Free Process" www.yageo.com May. 18, 2021 V.2 Product specification Chip Resistor Surface Mount SERIES PS 3 11 0306/0612 MARKING PS0306/0612 Bar marking YNSC137 Fig. 1 Outlines L L B4 W B5 B4 W Top Bottom Side Marking layer Overcoat Re sistive layer H Overcoat Ceram ic substrate Term ination YNSC136_2 Fig. 2 Chip resistor outlines DIMENSION Table 1 TYPE PS0306 PS0612 L (mm) W (mm) B1/S1 (mm) B2/S2 (mm) B3/S3 (mm) 0.80± 0.15 1.60± 0.20 1.10± 0.20 0.25± 0.10 1.60+0.15/-0.20 3.20± 0.20 2.20± 0.20 0.50± 0.20 B4 (mm) B5 (mm) H (mm) 0.25± 0.10 0.20± 0.10 0.40± 0.20 (0.75/1mΩ) 0.70± 0.15 (2~100mΩ) 0.50± 0.20 0.50± 0.20 0.45± 0.20 0.70± 0.20 (0.5~1mΩ) 0.70± 0.20 (2~10mΩ) 0.60± 0.20 (12~100mΩ) 0.50± 0.20 Note: 1. For relevant physical dimensions, please refer to construction outlines. 2. Please contact with sales offices, distributors and representatives in your region before ordering. www.yageo.com May. 18, 2021 V.2 4 Product specification Chip Resistor Surface Mount PS SERIES 11 0306/0612 ELECTRICAL CHARACTERISTICS Table 2 SERIES SIZE POWER RATING(4) TOLERANCE(2) 1/4W(07) 0306 ± 1%(F) ± 5%(J) 1/3W(7W) Fig. 4 Chip resistor outlines 1/2W(7T) PS 0612 1W(07) ± 0.5%(D)(2, 10, 20mΩ) ± 1%(F) ± 5%(J) RESISTANCE RANGE TEMPERATURE COEEFICIENT OF RESISTANCE(3) 0.75/1mΩ ± 300ppm/°C(P) 2mΩ ≤ R < 5mΩ ± 150ppm/°C(L) 5mΩ ≤ R ≤ 100mΩ ± 75ppm/°C(M) ± 100ppm/°C(F) 0.5mΩ ± 300ppm/°C(P) 1mΩ ± 100ppm/°C(F) ± 150ppm/°C(L) 2mΩ ≤ R ≤ 9mΩ ± 100ppm/°C(F) 14mΩ ≤ R ≤ 100mΩ ± 100ppm/°C(F) 10mΩ ≤ R ≤ 13mΩ ± 200ppm/°C(G) Note: 1. Please contact with sales offices, distributors and representatives in your region before ordering. 2. Global part number (code 7) 3. Global part number (code 9) 4. Global part number (code 10-11) FUNCTIONAL DESCRIPTION OPERATING TEMPERATURE RANGE MRA633_1_a PS0612 0.5mΩ ≤ R ≤ 10mΩ -55 °C to +155 °C 12mΩ ≤ R ≤ 100m Ω -55 °C to +125 °C PS0306 -55°C to +125°C POWER RATING Standard rated power at 70°C RATED VOLTAGE The DC or AC (rms) continuous working voltage corresponding to the rated power is determined by the following formula: V= 0306, 0612 125 155 Fig. 3 Maximum dissipation (P max ) in percentage of rated power as a function of the operating ambient temperature (T amb ) (P *R) Where V = Continuous rated DC or AC (rms) working voltage (V) P = Rated power (W) R = Resistance value (Ω) www.yageo.com May. 18, 2021 V.2 Product specification Chip Resistor Surface Mount SERIES PS PACKING STYLE AND PACKAGING QUANTITY Table 3 Packing style and packaging quantity PACKING STYLE REEL DIMENSION PS0306 5 11 0306/0612 PS0612 Paper taping reel (R) 7" (178 mm) 5,000 --- Embossed taping reel (K) 7" (178 mm) --- 4,000 PAPER TAPE P0 D0 T P2 E F cover tape W B0 A0 P1 MBG251_b Fig. 4 Paper Tape Table 4 Dimensions of paper tape for relevant chip resistors size SIZE PS0306 Unit: mm SYMBOL A0 B0 W E F P0 P1 P2 Ø D0 T 1.10± 0.15 1.90± 0.15 8.00± 0.30 1.75± 0.10 3.50± 0.10 4.00± 0.10 4.00± 0.10 2.00± 0.10 1.50± 0.10 0.80± 0.10 www.yageo.com May. 18, 2021 V.2 Product specification Chip Resistor Surface Mount PS SERIES 6 11 0306/0612 EMBOSSED TAPE P0 D0 P2 E F cover tape W B0 MBG516_c A0 T D1 P1 direction of unreeling Fig. 5 Embossed Tape Table 5 Dimensions of embossed tape for relevant chip resistors size SIZE SYMBOL A0 Unit: mm B0 W E PS0612 1.91± 0.05 3.65± 0.05 8.00+0.30/-0.10 1.75± 0.10 F 3.50± 0.05 P0 P1 P2 Ø D0 Ø D1 T 4.00± 0.10 4.00± 0.10 2.00± 0.05 1.50± 0.10 1.00± 0.10 0.88± 0.05 www.yageo.com May. 18, 2021 V.2 Product specification Chip Resistor Surface Mount PS SERIES 7 11 0306/0612 REEL SPECIFICATION W2 D C Fig. 6 Reel N A HBK039_a W1 Table 6 Dimensions of reel specification for relevant chip resistors size SIZE QUANTITY REEL SIZE 8 mm TAPE WIDE PER REEL SYMBOL Unit: mm A N W1 W2 MAX. PS0306 5000 7"(Ø 178 mm) 178.0± 5.0 60.0± 2.0 9.0± 0.2 12.0± 0.2 PS0612 4000 7"(Ø 178 mm) 178.0± 5.0 60.0± 2.0 9.0± 0.2 12.0± 0.2 www.yageo.com May. 18, 2021 V.2 Product specification Chip Resistor Surface Mount SERIES PS 8 11 0306/0612 SOLDERING PROFILES For recommended soldering profiles, please refer to data sheet “Chip resistors mounting”. FOOTPRINT e a c preferred direction during wave soldering d b solder land / solder paste pattern SCR024 Fig. 7 Single resistor chips recommended dimensions of footprints Table 7 Footprint dimensions SIZE FOOTPRINT DIMENSIONS CODE Unit: mm a b c d e t(um) PS0306 0.40 1.75 0.35 0.20 0.20 105 PS0612 1.00 3.50 0.80 0.38 0.75 105 www.yageo.com May. 18, 2021 V.2 Product specification Chip Resistor Surface Mount PS SERIES 9 11 0306/0612 TESTS AND REQUIREMENTS Table 8 Test condition, procedure and requirements TEST TEST METHOD PROCEDURE REQUIREMENTS Life/ Operational Life/ Endurance MIL-STD-202-method 108 ± (1%+0.0005 Ω) IEC 60115-1 4.25.1 1,000 hours at 70± 2 °C applied RCWV 1.5 hours on, 0.5 hour off, still air required High Temperature Exposure/ Endurance at Upper Category Temperature IEC 60068-2-2 1,000 hours at 125 °C &155 °C ,unpowered ± (1%+0.0005 Ω) Moisture Resistance MIL-STD-202-method 106 Each temperature / humidity cycle is defined at 8 hours (method 106F), 3 cycles / 24 hours for 10d with 25 °C / 65 °C 95% R.H, without steps 7a & 7b, unpowered ± (0.5%+0.0005 Ω) Parts mounted on test-boards, without condensation on parts Measurement at 24± 2 hours after test conclusion Thermal Shock MIL-STD-202-method 107 -55/+125 °C ± (1%+0.0005 Ω) Note: Number of cycles required is 300. Devices mounted Maximum transfer time is 20 seconds. Dwell time is 15 minutes. Air – Air Short Time Overload IEC60115-1 4.13 Board Flex/ Bending IEC 60068-2-21 5 times of rated power for 5 seconds at room temperature ± (1%+0.0005 Ω) Chips mounted on a 90mm glass epoxy resin PCB(FR4) 2 mm bending Bending time: 60± 5 seconds ± (1%+0.0005 Ω) No visible damage No visible damage www.yageo.com May. 18, 2021 V.2 Product specification Chip Resistor Surface Mount PS SERIES 10 11 0306/0612 TEST TEST METHOD PROCEDURE REQUIREMENTS Solderability - Wetting J-STD-002 test B Electrical Test not required Well tinned (≥95% covered) Magnification 50X No visible damage SMD conditions: 1st step: method B, aging 4 hours at 155 °C dry heat 2nd step: leadfree solder bath at 245± 3 °C Dipping time: 3± 0.5 seconds - Resistance to Soldering Heat IEC 60068-2-58 Condition B, no pre-heat of samples ± (0.5%+0.0005 Ω) Leadfree solder, 260 °C, 10 seconds immersion time No visible damage Procedure 2 for SMD: devices fluxed and cleaned with isopropanol www.yageo.com May. 18, 2021 V.2 Product specification Chip Resistor Surface Mount SERIES PS 11 11 0306/0612 REVISION HISTORY REVISION DATE POWER TYPE Version 2 CHANGE NOTIFICATION May 18, 2021 - TEMPERATURE COEFFICIENT RANGE TOLERANCE - Mark resistorRESISTANCE outline in diagrams of paper tape (Fig. OF 4) and embossed RESISTANCE 0603 1/10W, 1/5W, 3/10W, 2/5W, 1/2W 1/8W, 1/4W, 1/3W, 1/2W 0805 Version 1 July 16, 2019 1/4W, 1/2W 1206 Version 0 PF 1W Mar.1/2W, 06, 2017 - The resistors are constructed using outstanding TCR level material, which makes Yageo PF resistors excellent for current sensing application in battery charger circuit & DC-DC converter. The composition of the resistive 2010 material is adjusted to give the approximate required resistance and is covered with a protective coating, which printed with the resistance value. Finally, the three external terminations (Ni / matte Tin) are added, as shown in Fig. 4. 2512 4527 DESCRIPTION tape (Fig. 5) 5 mΩ ≦ R 2mΩ < 100 and mΩ extend resistor value for PS0306 - Add Tol. 0.5% for PS0612, 4 mΩ ≦ R < 100 mΩ - Extend resistor value 3 mΩ ≦ R < 100 mΩ - New datasheet for current sensor - low TCR 4 terminal PS series ± 1% ± 2% 5 mΩ ≦ R < 100 mΩ ±75 ppm/°C ± 5% 1W, 2W 1 mΩ ≦ R < 100 mΩ 3W 1 mΩ ≦ R ≦ 50 mΩ 2W, 3W, 5W 6 mΩ ≦ R < 1Ω NOTE: 1. PLEASE CONTACT WITH SALES OFFICES, DISTRIBUTORS AND REPRESENTATIVES IN YOUR REGION BEFORE ORDERING “ Yageo reserves all the rights for revising the content of this datasheet without further notification, as long as the products itself are unchanged. Any product change will be announced by PCN.” www.yageo.com May. 18, 2021 V.2
PS0612FKG070R01L 价格&库存
很抱歉,暂时无法提供与“PS0612FKG070R01L”相匹配的价格&库存,您可以联系我们找货
PS0612FKG070R01L
    • 1+12.98340
    • 100+8.53010
    • 1000+5.78350
    • 2000+3.98480
    • 4000+2.83720
    库存:30
    PS0612FKG070R01L
    • 1+11.389381+1.47814
    • 10+7.4409910+0.96571
    • 25+6.3729325+0.82709
    • 50+5.7075050+0.74073
    • 100+5.13910100+0.66696
    • 250+4.51733250+0.58627
    • 500+4.12789500+0.53573
    • 1000+3.797051000+0.49279
    库存:2220
    PS0612FKG070R01L
    • 4000+3.277094000+0.42531
    • 8000+3.074308000+0.39899
    • 12000+2.9701512000+0.38548
    • 20000+2.8523620000+0.37019
    • 28000+2.7821928000+0.36108
    库存:2220
    PS0612FKG070R01L
      • 1+1.91322
      • 10+1.53101
      • 30+1.36718
      • 100+1.16284
      • 500+1.07180
      • 1000+1.01726
