BF100-10-A-D-0-0640-L-C
    GCT
    SMD,P=2mm
    排母 间距:2mm 2x5P 立贴
BF100-10-A-D-0-0640-L-C 数据手册
1.00 2.00 1.00 H Ø0.9 4.00 W+1.0 Ø1.5 W+1.0 Ø1.5 G Recommended PCB Layout Top Entry General Tolerance: ±0.05 B±0.38 4.80 Material Contact: Phosphor Bronze Insulator: Standard: Polyamide, Nylon 6T, UL 94V-0 Options: Polymer, LCP, UL 94V-0 Electrical Current Rating: 2 Amp Per Pin Insulation Resistance: 1000 MΩ min Contact Resistance: 20 mΩ max. Dielectric Withstand Voltage: AC 500 V 0.80 W±0.2 Max. Insulator Height No. of Dimension Insertion H D Contacts Depth 04 ~ 16 4 4.30 4.50 18 ~ 80 8.05 Ordering Grid XX X X X XXXX X X 4.00 Request Samples and Quotation 04 ~ 16 18 ~ 80 4 8.05 4.30 Packing Options C = Tape and Reel with Film (Standard) B = Tape and Reel with Cap D = Tube (available from 6 contacts) E = Tube with Cap (available from 6 contacts) F = Tube with Film (available from 6 contacts) Contact Plating A = Gold Flash All Over (Standard) B = Selective Gold Flash Contact Area/ Tin On Tail C = Tin All Over G = 10µ" Gold Contact Area/Tin On Tail I = 30µ" Gold Contact Area/Tin On Tail Insulator Material N = Nylon 6T (Standard) L = LCP Insulator Height 'H' C = 4.00mm (Standard) D = 4.30mm Dimension W - Footprint Width (1/100mm) 'H' = 4.00mm: Standard - 6.25mm = 0625 Alternative - 5.00mm = 0500 'H' = 4.30mm: Standard - 6.40mm = 0640 Alternative - 5.60mm = 0560 - 6.25mm = 0625 Locating Peg 0 = No Peg 1 = With Peg 2 3 4 Mechanical & Environmental Operating Temperature: -40°C to +105°C Soldering Process: Nylon 6T (Standard) IR Reflow: 260°C for 10 sec. Wave: 230°C for 5-10 sec. Manual Solder: 350°C for 3-5 sec LCP (Option) IR Reflow: 260°C for 10 sec. Wave: 250°C for 5-10 sec. Manual Solder: 350°C for 3-5 sec Mates with(Subject to pin length): BF030 BF045 BF050 BF055 BF060 BF135 BF140 BF145 Part Number Product Description BF100 2.00mm Pitch Socket,Dual Row,Surface Mount, 4.3mm or 4.6mm Profile, Dual Entry Drawing Date 31st October 2007 By Detail 1 Plating See Ordering Grid 0.15 C±0.20 1.45 A H+0.3 H 1.10 No. of Contacts 04 to 80 B 4 6 8 10 12 14 16 18 20 22 24 26 28 30 32 34 36 38 40 42 44 46 48 50 52 54 56 58 60 62 64 66 68 70 72 74 76 78 80 Solder Area 5.90 0.3 Pin 0.50 x 0.20 Pegs optional BF100 Contacts Specifications Max. Insertion Depth See Table E C Recommended PCB Layout Min. Insertion Depth 1.67 ref. 0.40 ref. 0.85 Bottom Entry General Tolerance: ±0.05 Solder Area F D 2.00 1.86 2.10 A±0.25 D 0.85 2.00 2.00±0.15 Revision Date 5 CC Tolerances (Except as Noted) BF100 H PCN H3 15/12/21 X. ± 0.30 X.° ± 5° X.X° ± 3° X.X ± 0.25 X.XX ± 0.15 X.XX° ± 2° X.XXX ± 0.10 X.XXX° ± 1° Length Angle 6 Units: Metric (mm) C 3rd Angle Projection 7 This drawing is confidential and copyright of Global Connector Technology, Ltd (GCT). This drawing must not be copied or disclosed without written consent. E & OE A 2.0 4.0 6.0 8.0 10.0 12.0 14.0 16.0 18.0 20.0 22.0 24.0 26.0 28.0 30.0 32.0 34.0 36.0 38.0 40.0 42.0 44.0 46.0 48.0 50.0 52.0 54.0 56.0 58.0 60.0 62.0 64.0 66.0 68.0 70.0 72.0 74.0 76.0 78.0 Dimensions B C 4.6 / 6.6 2.0 8.6 4.0 10.6 6.0 12.6 8.0 14.6 10.0 16.6 12.0 18.6 14.0 20.6 16.0 22.6 18.0 24.6 20.0 26.6 22.0 28.6 24.0 30.6 26.0 32.6 28.0 34.6 30.0 36.6 32.0 38.6 34.0 40.6 36.0 42.6 38.0 44.6 40.0 46.6 42.0 48.6 44.0 50.6 46.0 52.6 48.0 54.6 50.0 56.6 52.0 58.6 54.0 60.6 56.0 62.6 58.0 64.6 60.0 66.6 62.0 68.6 64.0 70.6 66.0 72.6 68.0 74.6 70.0 76.6 72.0 78.6 74.0 80.6 76.0 www.gct.co Not to Scale Drawn By LYH 8 Sheet No. 1/1
BF100-10-A-D-0-0640-L-C 价格&库存
很抱歉,暂时无法提供与“BF100-10-A-D-0-0640-L-C”相匹配的价格&库存,您可以联系我们找货
  • 850+3.31641850+0.42987
  • 1700+3.158001700+0.40934
  • 2550+3.068922550+0.39779
  • 4250+2.960294250+0.38371
  • 5950+2.890855950+0.37471
  • 8500+2.819038500+0.36540
库存:2367
  • 1+5.368871+0.69591
  • 10+4.5369110+0.58807
  • 100+3.85760100+0.50002
库存:2367
