UMW
R
UMW LM317
DESCRIPTION
This monolithic integrated circuit is an adjustable 3-terminal
positive voltage regulator designed to supply more than 1.5A
of load current with an output voltage adjustable over a 1.2
to 37V. It employs internal current limiting , thermal shut-down
and safe area compensation.
TO-220-3L
FEATURE
Internal thermal overload protection
Internal short circuit current limiting
Output transistor safe operating area compensation
TO-252
1. Adj
2. Output
3. Input
SOT-223
Internal Block Diagram
Vin 3
Input
Protection
Circuitry
Voltage
Reference
Rlimit
2 Vo
Output
1
Vadj
www.umw-ic.com
1
友台半导体有限公司
UMW
R
UMW LM317
Absolute Maximum Rating s
Symbol
Parameter
Value
Unit
VI-VO
Input-Output Voltage Differential
40
V
TLEAD
Lead Temperature
230
TO-220
Power Dissipation
PD
Internally limited
TO-252
2
SOT-223
1
TJ
Operating Junction Temperature Range
0~125
Tstg
Storage Temperature Range
-55~125
Temperature Coefficient of Output Voltage
ΔVO /ΔT
W
±0.02
ELECTRICAL CHARACTERISTICS
(VO-VI=5V,IO=0.5A,0℃≤TJ≤+125℃ ,IMAX=1.5A,PDMAX=20W,unless otherwise specified)
Parameter
Line Regulation(note1)
Load Regulation(note1)
Adjustable Pin Current
Symbol
Test conditions
Rline
Rload
TYP
MAX
TA=25℃
3V≤VI-VO≤40V
0.01
0.04
3V≤VI-VO≤40V
0.02
0.07
TA=25℃ , 10mA≤ IO≤ IMAX
VO< 5V
VO ≥5V
10mA≤ IO≤ IMAX
18
0.4
25
0.5
VO
很抱歉,暂时无法提供与“LM317MDT”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.69265
- 100+0.46144
- 1250+0.41932
- 2500+0.38503
- 国内价格
- 5+0.89100
- 20+0.83160
- 100+0.77220
- 500+0.71280
- 1000+0.65340
- 2000+0.59400
- 国内价格
- 5+0.80752
- 50+0.64543
- 500+0.49343
- 1000+0.48603
- 2500+0.40925
- 国内价格
- 5+0.88992
- 50+0.71129
- 150+0.61938
- 500+0.54378
- 2500+0.45101
- 5000+0.43319
