UMW
R
UMW FDN335N
SOT-23 Plastic-Encapsulate MOSFETS
FDN335N
N-Channel 20-V(D-S) MOSFET
V(BR)DSS
RDS(on)MAX
ID
70mΩ@ 4.5V
20 V
1.7A
100mΩ@ 2.5V
FEATURE
● TrenchFET Power MOSFET
● Supper high density cell design
APPLICATION
※ Battery protection
SOT–23
※ Load switch
※ Battery management
MARKING
Equivalent Circuit
1. GATE
2. SOURCE
3. DRAIN
Maximum ratings ( Ta=25℃ unless otherwise noted)
Parameter
Symbol
Value
Drain-Source Voltage
VDS
Gate-Source Voltage
VGS
±8
ID
1.7
Pulsed Diode Curren
IDM
10
Power Dissipation
PD
1
W
RθJA
250
℃/W
TJ
150
TSTG
-55~+150
Continuous Drain Current
Thermal Resistance from Junction to Ambient (t≤10s)
Operating Junction
Storage Temperature
www.umw-ic.com
1
Unit
V
A
友台半导体有限公司
UMW
R
UMW FDN335N
MOSFET ELECTRICAL CHARACTERISTICS
Static Electrical Characteristics (Ta = 25 ℃ Unless Otherwise Noted)
Parameter
Symbol
Test Condition
Min
V(BR)DSS
VGS = 0V, ID = 250µA
VGS(th)
VDS =VGS, ID = 250µA
0.4
Gate-source leakage
IGSS
Zero gate voltage drain current
IDSS
Typ
Max
Unit
Static
Drain-source breakdown voltage
Gate-source threshold voltage
Drain-source on-state resistancea
Forward transconductancea
Diode forward voltage
V
1.5
V
VDS =0V, VGS = ±8V
±100
nA
VDS = 16V, VGS =0V
1
µA
VGS = 4.5V, ID = 1.7A
55
70
mΩ
VGS = 2.5V, ID = 1.5A
78
100
mΩ
gfs
VDS = 4.5V, ID = 1.7A
7
VSD
IS= 1A,VGS=0V
0.8
RDS(on)
S
1.2
V
Dynamic
Input capacitance
Ciss
Output capacitance
Coss
Reverse transfer capacitanceb
Crss
Total gate charge
Qg
Gate-source charge
Qgs
Gate-drain charge
Qgd
Gate resistance
VDS = 10V,VGS =0V,
f=1MHz
VDS = 10V,VGS = 4.5V,
ID = 1.7A
Rg
f=1MHz
310
pF
80
pF
40
pF
3.5
nC
0.6
nC
1
nC
0.5
2.2
Ω
Switchingbtr
Turn-on delay time
Rise time
Turn-off delay time
Fall time
td(on)
tr
td(off)
VDS= 10V
RL=3.5Ω, ID ≈ 1A,
VGEN= 4.5V,Rg=3Ω
tf
5
ns
8.5
ns
11
ns
3
ns
Drain-source body diode characteristicstr
Continuous Source-Drain Diode Current
Pulsed Diode forward Curren
Tc=25℃
IS
ISM
1.2
A
10
A
Note :
1. Repetitive Rating : Pulse width limited by maximum junction temperature.
2. Surface Mounted on FR4 Board, t < 10 sec.
3. Pulse Test : Pulse Width≤300µs, Duty Cycle ≤ 2%.
4. Guaranteed by design, not subject to production testing.
www.umw-ic.com
2
友台半导体有限公司
UMW
R
www.umw-ic.com
UMW FDN335N
3
友台半导体有限公司
很抱歉,暂时无法提供与“FDN335N”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.30580
- 200+0.19800
- 1500+0.17160
- 3000+0.15180
- 国内价格
- 20+0.17062
- 200+0.13093
- 国内价格 香港价格
- 3000+1.149713000+0.14822
- 6000+1.115726000+0.14384
- 9000+1.098729000+0.14165
- 15000+1.0798515000+0.13922
- 21000+1.0688421000+0.13780
- 30000+1.0582430000+0.13643
- 国内价格 香港价格
- 1+2.732481+0.35227
- 10+1.9063310+0.24577
- 25+1.6949925+0.21852
- 100+1.45643100+0.18777
- 250+1.34349250+0.17320
- 500+1.27534500+0.16442
- 1000+1.219131000+0.15717
