AC0201KRX7R9BB221
AC0201KRX7R9BB221
    YAGEO(国巨)
    AC0201KRX7R9BB221
AC0201KRX7R9BB221 数据手册
DATA SHEET SURFACE MOUNT MULTILAYER CERAMIC CAPACITORS Automotive grade NP0/X7R 6.3 V TO 2000 V Product Specification – January 14, 2022 V.17 0.2 pF to 680nF Product specification Surface-Mount Ceramic Multilayer Capacitors Automotive grade NPO/X7R 6.3 V to 2000 V SCOPE ORDERING INFORMATION - GLOBAL PART NUMBER This specification describes Automotive grade chip capacitors with lead-free terminations and used for automotive equipments. All part numbers are identified by the series, size, tolerance, TC material, packing style, voltage, process code, termination and capacitance value. GLOBAL PART NUMBER AC APPLICATIONS All general purpose applications under normal operation and usage conditions for automotive equipments. XXXX X X XXX X (1) (2) (3) (4) B (5) X XXX (6) (7) (1) SIZE – INCH BASED (METRIC) 0201 (0603) / 0402 (1005) / 0603 (1608) / 0805 (2012) / 1206 (3216)/ 1210 (3225) / 1812 (4532) (2) TOLERANCE FEATURES NPO(< 10 pF) NPO(≥ 10 pF) X7R  AEC-Q200 qualified  MSL class: MSL 1  AC series soldering is compliant with J-STD-020D  High component and equipment reliability  The capacitors are 100% performed by automatic optical inspection prior to taping. B = ± 0.1 pF F = ± 1% J = ± 5% C = ± 0.25 pF G = ± 2% K = ± 10% D = ± 0.5 pF J = ± 5% M = ± 20% Note: Capacitance tolerance ±5% doesn’t available for full X7R range, please contact local sale before order. (3) PACKING STYLE (SEE TABLE. 9 FOR DETAIL) R = Paper/PE taping reel; Reel 7 inch K = Blister taping reel; Reel 7 inch P = Paper/PE taping reel; Reel 13 inch F = Blister taping reel; Reel 13 inch (4) TC MATERIAL NPO X7R (5) RATED VOLTAGE 5 = 6.3 V 6 = 10 V B = 500 V 7 = 16 V C = 1000 V D = 2000 V 8 = 25 V Z = 630 V 9 = 50 V 0 = 100 V A = 200 V Y = 250 V 6) PROCESS N = NP0 B = X7R (7) CAPACITANCE VALUE 2 significant digits+number of zeros The 3rd digit signifies the multiplying factor, and letter R is decimal point Example: 121 = 12 x 101 = 120 pF www.yageo.com Jan. 14, 2022 V.17 Product specification Surface-Mount Ceramic Multilayer Capacitors Automotive grade NPO/X7R 6.3 V to 2000 V CONSTRUCTION The capacitor consists of a rectangular block of ceramic dielectric in which a number of interleaved metal electrodes are contained. This structure gives rise to a high capacitance per unit volume. The inner electrodes are connected to the two end terminations and finally covered with a layer of plated tin (Matte Sn). The terminations are leadfree. A cross section of the structure is shown in Fig.1. terminations electrodes MLB457 ceramic material Fig. 1 Surface mounted multilayer ceramic capacitor construction OUTLINES DIMENSION Table 1 For outlines see fig. 2 For dimension see Table 1 TYPE L1 (mm) W (mm) T (MM) 0201 0.6± 0.03 0.3± 0.03 0402 1.0± 0.05 0603 0805 L2 / L3 (mm) L4 (mm) min. max. min. 0.3± 0.03 0.10 0.20 0.20 0.5 ± 0.05 0.5± 0.05 0.15 0.35 0.30 1.6± 0.10 0.8± 0.10 0.8± 0.10 0.20 0.60 0.40 2.0± 0.10 1.25± 0.10 0.25 0.75 0.70 2.0± 0.20 1.25± 0.20 3.2± 0.15 1.6± 0.15 0.25 0.75 1.40 0.25 0.75 1.40 0.25 0.75 2.20 0.25 0.75 2.20 0.25 0.75 3.40 0.6± 0.10 0.85± 0.10 1.25± 0.20 Fig. 2 Surface mounted multilayer ceramic capacitor dimension 0.6± 0.10 0.85± 0.10 1.00± 0.10 1206 3.2± 0.30 1.6± 0.20 1.15± 0.10 1.25± 0.20 1.6± 0.20 1210 1808 3.2± 0.30 1.6± 0.30 1.6± 0.30 3.2± 0.20 2.5± 0.20 3.2± 0.30 2.5± 0.20 3.2± 0.40 2.5± 0.30 2.5± 0.20 4.5± 0.40 2.0± 0.30 1.25± 0.20 0.85± 0.10 1.25± 0.20 1.6± 0.20 2.0± 0.20 0.85± 0.10 1812 4.5± 0.40 3.2± 0.30 1.25± 0.20 1.60± 0.20 2020 5.7± 0.40 5.0± 0.30 0.85 ± 0.10 2.0± 0.20 1.25 1.25 ± ± 0.20 0.20 1.6 ± 0.20 1.6 ± 0.20 www.yageo.com Jan. 14, 2022 V.17 Product specification Surface-Mount Ceramic Multilayer Capacitors Automotive grade NPO/X7R 6.3 V to 2000 V CAPACITANCE RANGE & THICKNESS FOR NP0 Table 2 Sizes from 0201 to 0805 0201 0402 CAP. 0603 0805 0.2 pF 0.3± 0.03 0.47 pF 0.3± 0.03 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 0.56 pF 0.3± 0.03 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 0.68 pF 0.3± 0.03 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 0.82 pF 0.3± 0.03 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 1.0 pF 0.3± 0.03 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 1.2 pF 0.3± 0.03 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 1.5 pF 0.3± 0.03 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 1.8 pF 0.3± 0.03 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 2.2 pF 0.3± 0.03 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 2.7 pF 0.3± 0.03 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 3.3 pF 0.3± 0.03 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 3.9 pF 0.3± 0.03 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 4.7 pF 0.3± 0.03 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 5.6 pF 0.3± 0.03 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 6.8 pF 0.3± 0.03 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 8.2 pF 0.3± 0.03 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 10 pF 0.3± 0.03 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 12 pF 0.3± 0.03 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 15 pF 0.3± 0.03 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 18 pF 0.3± 0.03 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 22 pF 0.3± 0.03 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 27 pF 0.3± 0.03 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 33 pF 0.3± 0.03 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 39 pF 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 47 pF 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 56 pF 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 68 pF 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 82 pF 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 100 pF 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 NOTE 1. Values in shaded cells indicate thickness class in mm 2. Capacitance value of non E-12 series is on request www.yageo.com Jan. 14, 2022 V.17 Product specification Surface-Mount Ceramic Multilayer Capacitors Automotive grade NPO/X7R 6.3 V to 2000 V CAPACITANCE RANGE & THICKNESS FOR NP0 Table 3 Sizes from 0402 to 0805 (continued) CAP. 0402 0603 0805 120 pF 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 150 pF 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 180 pF 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 220 pF 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.85± 0.1 270 pF 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.85± 0.1 330 pF 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.85± 0.1 390 pF 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.85± 0.1 470 pF 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.6± 0.1 0.85± 0.1 560 pF 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.85± 0.1 0.85± 0.1 680 pF 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.85± 0.1 0.85± 0.1 820 pF 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.85± 0.1 0.85± 0.1 1.0 nF 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.6± 0.1 0.85± 0.1 0.85± 0.1 1.2 nF 0.8± 0.1 0.8± 0.1 0.85± 0.1 0.85± 0.1 1.5 nF 0.8± 0.1 0.8± 0.1 0.85± 0.1 0.85± 0.1 1.8 nF 0.8± 0.1 0.8± 0.1 0.85± 0.1 0.85± 0.1 2.2 nF 0.8± 0.1 0.8± 0.1 1.25± 0.2 1.25± 0.2 2.7 nF 0.8± 0.1 1.25± 0.2 1.25± 0.2 3.3 nF 0.8± 0.1 1.25± 0.2 1.25± 0.2 3.9 nF 0.8± 0.1 1.25± 0.2 1.25± 0.2 4.7 nF 0.8± 0.1 1.25± 0.2 1.25± 0.2 5.6 nF 0.8± 0.1 1.25± 0.2 1.25± 0.2 6.8 nF 0.8± 0.1 1.25± 0.2 1.25± 0.2 8.2 nF 0.8± 0.1 1.25± 0.2 1.25± 0.2 10 nF 0.8± 0.1 1.25± 0.2 1.25± 0.2 NOTE 1. Values in shaded cells indicate thickness class in mm 2. Capacitance value of non E-12 series is on request www.yageo.com Jan. 14, 2022 V.17 Product specification Surface-Mount Ceramic Multilayer Capacitors Automotive grade NPO/X7R 6.3 V to 2000 V CAPACITANCE RANGE & THICKNESS FOR NP0 Table 4 Sizes from 1206 to 1210 CAP. 1210 1206 50 V 100 V 200 V / 250 V 500 V 630 V 1000 V 2000 V 10 pF 0.6± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 1.25± 0.2 1.25± 0.2 1.25± 0.2 12 pF 0.6± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 1.25± 0.2 1.25± 0.2 1.25± 0.2 15 pF 0.6± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 1.25± 0.2 1.25± 0.2 1.25± 0.2 18 pF 0.6± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 1.25± 0.2 1.25± 0.2 1.25± 0.2 22 pF 0.6± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 1.25± 0.2 1.25± 0.2 1.25± 0.2 27 pF 0.6± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 1.25± 0.2 1.25± 0.2 1.25± 0.2 33 pF 0.6± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 1.25± 0.2 1.25± 0.2 1.25± 0.2 39 pF 0.6± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 1.25± 0.2 1.25± 0.2 1.25± 0.2 47 pF 0.6± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 1.25± 0.2 1.25± 0.2 1.25± 0.2 56 pF 0.6± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 1.25± 0.2 1.25± 0.2 68 pF 0.6± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 1.25± 0.2 1.25± 0.2 82 pF 0.6± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 1.25± 0.2 1.25± 0.2 100 pF 0.6± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 1.25± 0.2 1.25± 0.2 120 pF 0.6± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 1.25± 0.2 1.25± 0.2 150 pF 0.6± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 1.25± 0.2 1.25± 0.2 180 pF 0.6± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 1.25± 0.2 1.25± 0.2 220 pF 0.6± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 1.25± 0.2 1.25± 0.2 270 pF 0.6± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 1.25± 0.2 330 pF 0.6± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 1.25± 0.2 390 pF 0.6± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 1.25± 0.2 470 pF 0.6± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 1.25± 0.2 560 pF 0.6± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 1.25± 0.2 680 pF 0.6± 0.1 0.6± 0.1 0.6± 0.1 0.6± 0.1 1.25± 0.2 820 pF 0.6± 0.1 0.6± 0.1 0.85± 0.1 0.85± 0.1 1.25± 0.2 1.0 nF 0.6± 0.1 0.6± 0.1 0.85± 0.1 0.85± 0.1 1.25± 0.2 1.2 nF 0.6± 0.1 0.6± 0.1 1.5 nF 0.6± 0.1 0.6± 0.1 1.8 nF 0.6± 0.1 2.2 nF 2.7 nF 50 V 100 V 200 V / 250 V 500 V 1.25± 0.2 1.25± 0.2 1.25± 0.2 1.25± 0.2 0.85± 0.1 1.25± 0.2 1.25± 0.2 1.25± 0.2 1.25± 0.2 0.85± 0.1 1.25± 0.2 1.25± 0.2 1.25± 0.2 1.25± 0.2 0.6± 0.1 1.25± 0.2 1.25± 0.2 1.25± 0.2 1.25± 0.2 0.6± 0.1 0.6± 0.1 1.25± 0.2 1.25± 0.2 1.25± 0.2 0.6± 0.1 0.6± 0.1 1.25± 0.2 1.25± 0.2 1.25± 0.2 NOTE 1. Values in shaded cells indicate thickness class in mm 2. Capacitance value of non E-12 series is on request www.yageo.com Jan. 14, 2022 V.17 Product specification Surface-Mount Ceramic Multilayer Capacitors Automotive grade NPO/X7R 6.3 V to 2000 V CAPACITANCE RANGE & THICKNESS FOR X7R Table 5 CAP. Sizes from 0201 to 0603 0201 25V 0603 0402 50 V 10V 16 V 25 V 50 V 100 V 10V 16 V 25 V 50 V 100 V 1.0 nF 0.3± 0.03 0.3± 0.03 0.5± 0.05 0.5± 0.05 0.5± 0.05 0.5± 0.05 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.8± 0.1 1.5 nF 0.3± 0.03 0.5± 0.05 0.5± 0.05 0.5± 0.05 0.5± 0.05 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.8± 0.1 2.2 nF 0.3± 0.03 0.5± 0.05 0.5± 0.05 0.5± 0.05 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.8± 0.1 3.3 nF 0.3± 0.03 0.5± 0.05 0.5± 0.05 0.5± 0.05 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.8± 0.1 4.7 nF 0.3± 0.03 0.5± 0.05 0.5± 0.05 0.5± 0.05 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.8± 0.1 6.8 nF 0.3± 0.03 0.5± 0.05 0.5± 0.05 0.5± 0.05 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.8± 0.1 10 nF 0.3± 0.03 0.5± 0.05 0.5± 0.05 0.5± 0.05 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.8± 0.1 15 nF 0.5± 0.05 0.5± 0.05 0.5± 0.05 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.8± 0.1 22 nF 0.5± 0.05 0.5± 0.05 0.5± 0.05 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.8± 0.1 33 nF 0.5± 0.05 0.5± 0.05 0.5± 0.05 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.8± 0.1 47 nF 0.5± 0.05 0.5± 0.05 0.5± 0.05 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.8± 0.1 68 nF 0.5± 0.05 0.5± 0.05 0.5± 0.05 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.8± 0.1 100 nF 0.5± 0.05 0.5± 0.05 0.5± 0.05 0.5± 0.05 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.8± 0.1 150 nF 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.8± 0.1 220 nF 0.8± 0.1 0.8± 0.1 0.8± 0.1 0.8± 0.1 330 nF 0.8± 0.1 0.8± 0.1 0.8± 0.1 470 nF 0.8± 0.1 0.8± 0.1 0.8± 0.1 680 nF 0.8± 0.1 0.8± 0.1 0.8± 0.1 100 pF 0.3± 0.03 0.3± 0.03 150 pF 0.3± 0.03 0.3± 0.03 220 pF 0.3± 0.03 0.3± 0.03 0.5± 0.05 0.5± 0.05 0.5± 0.05 0.5± 0.05 0.5± 0.05 330 pF 0.3± 0.03 0.3± 0.03 0.5± 0.05 0.5± 0.05 0.5± 0.05 0.5± 0.05 0.5± 0.05 470 pF 0.3± 0.03 0.3± 0.03 0.5± 0.05 0.5± 0.05 0.5± 0.05 0.5± 0.05 0.5± 0.05 680 pF 0.3± 0.03 0.3± 0.03 0.5± 0.05 0.5± 0.05 0.5± 0.05 0.5± 0.05 0.5± 0.05 NOTE 1. Values in shaded cells indicate thickness class in mm 2. Capacitance value of non E-6 series is on request www.yageo.com Jan. 14, 2022 V.17 Product specification Surface-Mount Ceramic Multilayer Capacitors Automotive grade NPO/X7R 6.3 V to 2000 V CAPACITANCE RANGE & THICKNESS FOR X7R Table 6 Size 0805 0805 CAP. 10 V 16 V 25 V 50 V 100 V 200 V / 250 V 500 V 1.0 nF 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 1.5 nF 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 2.2 nF 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 3.3 nF 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 4.7 nF 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 6.8 nF 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 1.25± 0.2 10 nF 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 1.25± 0.2 15 nF 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 1.25± 0.2 22 nF 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 1.25± 0.2 33 nF 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 1.25± 0.2 47 nF 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 1.25± 0.2 68 nF 0.85± 0.1 0.85± 0.1 0.85± 0.1 100 nF 0.85± 0.1 0.85± 0.1 0.85± 0.1 150 nF 0.85± 0.1 0.85± 0.1 0.85± 0.1 1.25± 0.2 220 nF 0.85± 0.1 0.85± 0.1 0.85± 0.1 1.25± 0.2 330 nF 1.25± 0.2 1.25± 0.2 1.25± 0.2 1.25± 0.2 470 nF 1.25± 0.2 1.25± 0.2 1.25± 0.2 1.25± 0.2 680 nF 1.25± 0.2 1.25± 0.2 1.25± 0.2 1.25± 0.2 0.85± 0.1 1.25± 0.2 0.85± 0.1 1.25± 0.2 1.25± 0.2 1.25± 0.2 NOTE 1. Values in shaded cells indicate thickness class in mm 2. Capacitance value of non E-6 series is on request www.yageo.com Jan. 14, 2022 V.17 Product specification Surface-Mount Ceramic Multilayer Capacitors Automotive grade NPO/X7R 6.3 V to 2000 V CAPACITANCE RANGE & THICKNESS FOR X7R Table 7 CAP. Size 1206 1206 6.3 V 10V 16V 25V 50 V 100 V 200 V / 250 V 500 V 630 V 1000 V 220 pF 1.25± 0.2 1.25± 0.2 1.25± 0.2 330 pF 1.25± 0.2 1.25± 0.2 1.25± 0.2 470 pF 1.25± 0.2 1.25± 0.2 1.25± 0.2 680 pF 1.25± 0.2 1.25± 0.2 1.25± 0.2 1 nF 1.25± 0.2 1.25± 0.2 1.25± 0.2 2.2 nF 1.25± 0.2 1.25± 0.2 4.7 nF 1.25± 0.2 1.25± 0.2 10 nF 1.25± 0.2 1.25± 0.2 22 nF 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 1.25± 0.2 33 nF 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 1.60± 0.2 47 nF 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 1.60± 0.2 68 nF 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 1.25± 0.2 1.60± 0.2 100 nF 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 1.25± 0.2 1.60± 0.2 150 nF 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 1.25± 0.2 1.25± 0.2 220 nF 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 1.25± 0.2 1.25± 0.2 330 nF 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 1.60± 0.2 1.60± 0.2 470 nF 1.00± 0.1 1.00± 0.1 1.00± 0.1 1.00± 0.1 1.60± 0.2 1.60± 0.2 680 nF 1.15± 0.1 1.15± 0.1 1.15± 0.1 1.60± 0.2 1.60± 0.2 1.60± 0.2 Table 8 Size 1210 1812 1210 CAP. 6.3V 10 V 16 V 25 V 50V 100 V 200 V / 250 V 50V 100V 100 nF 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 1.25± 0.2 150 nF 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 1.25± 0.2 1.25± 0.2 220 nF 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 1.25± 0.2 1.25± 0.2 330 nF 0.85± 0.1 0.85± 0.1 0.85± 0.1 0.85± 0.1 1.25± 0.2 2.0± 0.2 470 nF 1.25± 0.2 1.25± 0.2 1.25± 0.2 1.25± 0.2 1.25± 0.2 2.0± 0.2 1.60± 0.2 1.60± 0.2 680 nF 1.25± 0.2 1.25± 0.2 1.25± 0.2 1.25± 0.2 1.25± 0.2 2.0± 0.2 1.60± 0.2 1.60± 0.2 NOTE 1. Values in shaded cells indicate thickness class in mm 2. Capacitance value of non E-6 series is on request www.yageo.com Jan. 14, 2022 V.17 Product specification Surface-Mount Ceramic Multilayer Capacitors Automotive grade NPO/X7R 6.3 V to 2000 V THICKNESS CLASSES AND PACKING QUANTITY Table 9 THICKNESS SIZE CODE CLASSIFICATION PACKING CODE 7 INCH 13 INCH QUANTITY PER REEL TAPE WIDTH Ø 180 MM / 7 INCH Paper Blister Ø 330 MM / 13 INCH Paper Blister 0201 0.3 ± 0.03 mm R P 8 mm 15,000 --- 50,000 --- 0402 0.5 ± 0.05 mm R P 8 mm 10,000 --- 50,000 --- 0603 0.8 ± 0.1 mm R P 8 mm 4,000 --- 15,000 --- 0.6 ± 0.1 mm R P 8 mm 4,000 --- 20,000 --- 0.85 ± 0.1 mm R P 8 mm 4,000 --- 15,000 --- 1.25 ± 0.2 mm K F 8 mm --- 3,000 --- 10,000 0.6 ± 0.1 mm R P 8 mm 4,000 --- 20,000 --- 0.85 ± 0.1 mm R P 8 mm 4,000 --- 15,000 --- 1.0/1.15 ± 0.1 mm K F 8 mm --- 3,000 --- 10,000 1.25 ± 0.2 mm K F 8 mm --- 3,000 --- 10,000 1.60 ± 0.2 mm K F 8 mm --- 2,000 --- 8,000 0.85 ± 0.1 mm K F 8 mm --- 4,000 --- 10,000 1.15 ± 0.1 mm K F 8 mm --- 3,000 --- 10,000 1.25 ± 0.2 mm K F 8 mm --- 3,000 --- 10,000 2.0 ± 0.2 mm K 8 mm --- 2,000 --- --- 2.5 ± 0.2 mm K 8 mm --- 1,000 --- --- 0.6 / 0.85± 0.1 mm K 12 mm --- 2,000 --- --- 1.15± 0.1 mm K 12 mm --- 1,000 --- --- 1.25± 0.2 mm K 12 mm --- 1,000 --- --- 1.6 ± 0.2 mm K 12 mm --- 2,000 --- --- 0805 1206 1210 1812 www.yageo.com Jan. 14, 2022 V.17 Product specification Surface-Mount Ceramic Multilayer Capacitors Automotive grade NPO/X7R 6.3 V to 2000 V PAPER/PE TAPE SPECIFICATION Fig. 3 Paper/PE tape Table 10 Dimensions of paper/PE tape for relevant chip size; see Fig.3 SIZE Unit: mm SYMBOL CODE A0 B0 W E F P0 (1) P1 P2 Ø D0 K0 T 0.38 ± 0.05 (0.47 / 0.55)±0.10 0201 0.39 ± 0.06 0.70 ± 0.06 8.0 ± 0.20 1.75 ± 0.1 3.50 ± 0.05 4.0 ± 0.05 2.0 ± 0.05 2.0 ± 0.05 1.55 ± 0.03 0402 0.70 ± 0.15 1.21 ± 0.12 8.0 ± 0.20 1.75 ± 0.1 3.50 ± 0.05 4.0 ± 0.05 2.0 ± 0.05 2.0 ± 0.05 1.50 +0.1 /-0 (0.75 / 0.60)±0.10 (0.85 / 0.70)±0.10 0603 1.05 ± 0.14 1.86 ± 0.13 8.0 ± 0.20 1.75 ± 0.1 3.50 ± 0.05 4.0 ± 0.10 4.0 ± 0.10 2.0 ± 0.05 1.50 +0.1 /-0 (1.05 / 0.95 / 0.75)±0.10 (1.15 / 1.05 / 0.85)±0.10 0805 1.50 ± 0.15 2.26 ± 0.20 8.0 ± 0.20 1.75 ± 0.1 3.50 ± 0.05 4.0 ± 0.10 4.0 ± 0.10 2.0 ± 0.05 1.50 +0.1 /-0 (1.05 / 0.95 / 0.75)±0.10 (1.15 / 1.05 / 0.85)±0.10 1206 1.90 ± 0.15 3.50 ± 0.20 8.0 ± 0.20 1.75 ± 0.1 3.50 ± 0.05 4.0 ± 0.10 4.0 ± 0.10 2.0 ± 0.05 1.50 +0.1 /-0 (0.95 / 0.75)±0.10 (1.05 / 0.85)± 0.10 NOTE 1. P0 pitch tolerance over any 10 pitches is 0.2 mm www.yageo.com Jan. 14, 2022 V.17 Product specification Surface-Mount Ceramic Multilayer Capacitors Automotive grade NPO/X7R 6.3 V to 2000 V BLISTER TAPE SPECIFICATION P0 D0 K0 P2 E F cover tape W B0 A0 T2 SCM015 D1 P1 K0: so chosen that the orientation of the component cannot change For W = 8 mm: T2 = 3.5 mm max. For W = 12 mm: T2 = 6.5 mm max. direction of unreeling Fig. 4 Blister tape Table 11 Dimensions of blister tape for relevant chip size; see Fig.4 SYMBOL SIZE A0 B0 CODE Unit: mm K0 W E F Min. Max. Min. Max. Min. Max. Ø D0 Ø D1 P0 (2) P1 P2 T2 Min. Min. Max. 0805 1.29 1.65 2.09 2.60 1.25 1.62 8.1 ± 0.20 1.75 ± 0.1 3.5 ± 0.05 1.5 +0.1/-0.0 1 +0.1/-0.0 4.0 ± 0.10 4.0 ± 0.10 2.0 ± 0.05 1.30 1.67 1206 1.65 2.12 3.30 3.75 1.22 2.15 8.1 ± 0.20 1.75 ± 0.1 3.5 ± 0.05 1.5 +0.1/-0.0 1 +0.1/-0.0 4.0 ± 0.10 4.0 ± 0.10 2.0 ± 0.05 1.27 2.20 1210 2.55 3.02 3.31 3.88 0.97 2.92 8.1 ± 0.20 1.75 ± 0.1 3.5 ± 0.05 1.5 +0.1/-0.0 1 +0.1/-0.0 4.0 ± 0.10 4.0 ± 0.10 2.0 ± 0.05 1.02 2.97 1808 2.05 2.55 4.80 5.45 1.30 2.45 12.1 ± 0.20 1.75 ± 0.1 5.5 ± 0.05 1.5 +0.1/-0.0 1.5 +0.1/-0.0 4.0 ± 0.10 4.0 ± 0.10 2.0 ± 0.05 1.35 2.50 1812 3.35 3.75 4.70 5.33 0.70 2.40 12.1 ± 0.20 1.75 ± 0.1 5.5 ± 0.05 1.5 +0.1/-0.0 1.5 +0.1/-0.0 4.0 ± 0.10 8.0 ± 0.10 2.0 ± 0.05 0.75 2.45 NOTE 1. Typical capacitor displacement in pocket 2. P0 pitch tolerance over any 10 pitches is ±0.2 mm www.yageo.com Jan. 14, 2022 V.17 Product specification Surface-Mount Ceramic Multilayer Capacitors Automotive grade NPO/X7R 6.3 V to 2000 V REEL SPECIFICATION W2 C N A HBK039 W1 Fig. 5 Reel Table12 Reel dimensions; see Fig.5 TAPE WIDTH SYMBOL Unit: mm A N C W1 W2max. 8 (Ø 178 mm/7") 178 ± 1.0 60 ± 1.0 13 +0.50/-0.20 9.4 ± 1.5 14.4 8 (Ø 330 mm/13") 330 ± 1.0 100 ± 1.0 13 +0.50/-0.20 9.0 ± 0.2 14.4 12 (Ø 178 mm/7") 178 ± 1.0 60 ± 1.0 13 +0.50/-0.20 13.4 ± 1.5 18.4 P ROPERTIES OF REEL Material: polystyrene Surface resistance: 220nF * Applied 1.5 x Ur 0402/X7R/50V/>10nF 0603/X7R/25V/>220nF; 0603/X7R/50V/220nF 0603/X7R/100V/≥100nF 0805/X7R/100V/≥ 470nF 7 External Visual Any applicable method using × 10 magnification In accordance with specification 8 Physical Dimension Verify physical dimensions to the applicable device specification. In accordance with specification ∆C/C Three shocks in each direction shall be applied along the three NPO: Within ± 0.5% or 0.5 pF, mutually perpendicular axes of the test specimen whichever is greater (18 shocks) X7R: ± 10% 9 Mechanical Shock Peak value: 1,500 g’s Duration: 0.5 ms Velocity change: 15.4 ft/s Waveform: Half-sin 10 Vibration 5 g’s for 20 minutes, 12 cycles each of 3 orientations. D.F. Within initial specified value IR Within initial specified value ∆C/C NP0: Within ± 0.5% or 0.5 pF, whichever is greater X7R: ± 10% Test from 10-2000 Hz. D.F: meet initial specified value IR meet initial specified value www.yageo.com Jan. 14, 2022 V.17 Product specification Surface-Mount Ceramic Multilayer Capacitors NO 11 AEC-Q200 TEST Resistance to Soldering Heat Automotive grade NPO/X7R 6.3 V to 2000 V TEST METHOD REQUIREMENTS Precondition: 150 +0/–10 °C for 1 hour, then keep for 24 ± 1 hours at room temperature Preheating: for size ≤ 1206: 120 °C to 150 °C for 1 minute Preheating: for size >1206: 100 °C to 120 °C for 1 minute and 170 °C to 200 °C for 1 minute Solder bath temperature: 260± 5 °C Dipping time: 10± 0.5 seconds Recovery time: 24± 2 hours Dissolution of the end face plating shall not exceed 25% of the length of the edge concerned ∆C/C NPO: Within ± 1% or 0.5 pF, whichever is greater. X7R: ± 10% D.F. within initial specified value IR within initial specified value 12 Thermal Shock 1. Preconditioning, class 2 only: 150 +0/-10 °C /1 hour, then keep for 24± 1 hour at room temp 2. Initial measure: Spec: refer to initial spec C, D, IR 3. Rapid change of temperature test: -55 °C to +125 °C; 300 cycles 15 minutes at -55°C ; 15 minutes at 125 °C 4. Recovery time: NPO: 6 to 24 hours X7R: 24± 2 hours 5. Final measure: C, D, IR No visual damage ∆C/C NPO: Within ± 1% or 1 pF, whichever is greater X7R: ± 15% D.F: meet initial specified value IR meet initial specified value A component passes a voltage level if all components stressed at that voltage level pass. Per AEC-Q200-002 YNM0053-1 6 kV DC FAIL PASS 2 kV DC FAIL 13 ESD 12 kV AD PASS 1 kV DC FAIL FAIL < 500 V DC 4 kV DC PASS 500 V DC FAIL 1 kV DC FAIL 2 kV DC PASS 8 kV DC PASS 4 kV DC FAIL 6 kV DC 16 kV AD PASS 8 kV DC PASS 500 V DC FAIL PASS 12 kV AD 25 kV AD FAIL PASS 16 kV AD 25 kV AD Note: Classify the components according to the highest ESD voltage level survived during ESD testing. Fig. 7 Passive component HBM ESD test flow diagram (DC = Direct Contact Discharge, AD = Air Discharge) www.yageo.com Jan. 14, 2022 V.17 Product specification Surface-Mount Ceramic Multilayer Capacitors NO 14 AEC-Q200 TEST Solderability Capacitance 15 Electrical Characterization Dissipation Factor (D.F.) Insulation Resistance (I.R.) Automotive grade NPO/X7R 6.3 V to 2000 V TEST METHOD REQUIREMENTS 1. Preheat at 155°C for 4 hours. After preheating, immerse the capacitor in a solution of ethanol and rosin (25% rosin in weight proportion). Immerse in eutectic solder solution for 5+0/-0.5 seconds at 235± 5°C. 2. Should be placed into steam aging for 8 hours± 15 minutes. After preheating, immerse the capacitor in a solution of ethanol and rosin (25% rosin in weight proportion). Immerse in eutectic solder solution for 5+0/-0.5 seconds at 235± 5°C. 3. Should be placed into steam aging for 8 hours± 15 minutes. After preheating, immerse the capacitor in a solution of Ethanol and rosin (25% rosin in weight proportion). Immerse in eutectic solder solution for 120± 5 seconds at 260± 5°C. The solder should cover over 95% of the critical area of each termination. NPO: f = 1 MHz for C ≤ 1nF, measuring at voltage 1 Vrms at 25 °C f = 1 KHz for C > 1nF, measuring at voltage 1 Vrms at 25 °C X7R: At 25 °C, 24 hours after annealing f = 1 KHz, measuring at voltage 1 Vrms at 25 °C Within specified tolerance NPO: f = 1 MHz for C ≤ 1nF, measuring at voltage 1 Vrms at 25 °C f = 1 KHz for C > 1nF, measuring at voltage 1 Vrms at 25°C X7R: At 25 °C, 24 hours after annealing f = 1 KHz, measuring at voltage 1 Vrms at 25 °C In accordance with specification on Table 13 At Ur (DC) for 1 minute In accordance with specification on Table 13 www.yageo.com Jan. 14, 2022 V.17 Product specification Surface-Mount Ceramic Multilayer Capacitors NO AEC-Q200 TEST Temperature coefficient 15 Electrical Characterization Automotive grade TEST METHOD NPO/X7R 6.3 V to 2000 V REQUIREMENTS Capacitance shall be measured by the steps shown in the following table. ∆C/C NPO: ± 30ppm /°C The capacitance change should be measured after 5 min at each specified temperature stage. X7R: ± 15% Step Temperature(°C) a 25± 2 b Lower temperature± 3°C c 25± 2 d Upper Temperature± 2°C e 25± 2 (1) NPO Temperature Coefficient shall be calculated from the formula as below C2 - C1 Temp, Coefficient = 106 [ppm/°C] C1 xΔT C1: Capacitance at step c C2: Capacitance at 125°C ∆T: 100°C (=125°C -25°C) (2) X7R Capacitance Change shall be calculated from the formula as below C2 - C1 ∆C = x 100% C1 C1: Capacitance at step c C2: Capacitance at step b or d Voltage Proof 1. Specified stress voltage applied for 1~5 seconds 2. Ur ≤ 100 V: series applied 2.5 Ur 3. 100 V < Ur ≤ 200 V series applied (1.5 Ur + 100) 4. 200 V < Ur ≤ 500 V series applied (1.3 Ur + 100) 5. Ur ≥ 500 V: 1.3 Ur 6. Ur ≥ 1000 V: 1.2 Ur Charge/Discharge current is less than 50 mA No breakdown or flashover www.yageo.com Jan. 14, 2022 V.17 Product specification Surface-Mount Ceramic Multilayer Capacitors NO AEC-Q200 TEST Automotive grade NPO/X7R 6.3 V to 2000 V TEST METHOD REQUIREMENTS Part mounted on a 100mm × 40mm FR4 PCB board, which is 1.6± 0.2 mm thick and has a layer-thickness 35µm± 10 µm. Part should be mounted using the following soldering reflow profile. Conditions: ∆C/C NPO: Within ± 1% or 0.5 pF, whichever is greater X7R: ± 10% NPO: Bending 3 mm at a rate of 1 mm/s, radius jig 340 mm X7R: Bending 2 mm at a rate of 1 mm/s, radius jig 340 mm 16 Board Flex Dimension(mm) Test Substrate: b C 4.5 YNSC147 40 a 100 Type a b c 0201 0.3 0.9 0.3 0402 0.4 1.5 0.5 0603 1.0 3.0 1.2 0805 1.2 4.0 1.65 1206 2.2 5.0 1.65 1210 2.2 5.0 2.0 1808 3.5 7.0 3.7 unit: mm 17 Terminal Strength With the component mounted on a PCB obtained with the device to be tested, apply a 17.7N (1.8Kg) force to the side of a device being tested. This force shall be applied for 60+1 seconds. Also the force shall be applied gradually as not to apply a shock to the component being tested. * Apply 2N force for 0402 size. * Apply 1N force for 0201 size. Place the part in the beam load fixture. Apply a force until the part breaks or the minimum acceptable force level required in the user specification(s) is attained. 18 Beam Load Test Magnification of 20X or greater may be employed for inspection of the mechanical integrity of the device body, terminals and body/terminal junction. Before, during and after the test, the device shall comply with all electrical requirements stated in this specification. ≤ 0805 Thickness > 0.5mm: 20N Thickness ≤ 0.5mm: 8N ≥ 1206 Thickness ≥1.25 mm: 54N Thickness < 1.25 mm: 15N www.yageo.com Jan. 14, 2022 V.17 Product specification Surface-Mount Ceramic Multilayer Capacitors Automotive grade NPO/X7R 6.3 V to 2000 V REVISION HISTORY REVISION DATE CHANGE NOTIFICATION - DESCRIPTION Version 17 Jan. 14, 2022 Version 16 Nov. 17, 2021 - - Add 1206/X7R/500V to 1000V/220pF to 1nF Version 15 Oct. 12, 2021 - Add 0603/NPO/25V/50V/2.7nF to 10nF - - Add 1206/NPO/2000V/10pF to 47pF - I.R. for NPO change to " I.R. ≥ 100 GΩ or I.R. × C ≥ 1000Ω.F. whichever is less" Version 14 Aug. 09, 2021 - - Add 1206/NPO/1kV/10pF to 220pF 1206/X7R/1kV/1nF Version 13 Jun. 08, 2021 - - Move out "Array" and "High Cap" to individual specification Add 0603 NPO 50V/100V 1.2nF to 2.2nF 0402 X7R 50V 15nF to 100nF 0603 X7R 25V 330nF to 680nF 0603 X7R 50V 150nF to 220nF 0603 X7R 100V 68nF to 100nF - Add 0201/ X7R/ 50V / 100 pF to 1nF 0603/ X7R/ 16V / 680nF to 1µF 0603/ X7R/ 25V / 150nF / 220nF/ 1µF 1210/ X7R/ 50V / 4.7µF Version 12 Feb. 26, 2021 Version 11 Jun. 29, 2018 - May. 2, 2018 - - Add 0201 NPO 25V/ 50V, 0.2pF to 33pF, Add 0402 NPO 50V 270pF to 1nF, Add 0805 X7R 25V 2.2uF - Add 0603 NPO 100V 820pF to 1nF, - Add 0805 NPO 50V to 100V, 1.2nF to 10nF, Version 10 - Add 0805 X7R 16V 2.2uF, 50V 680nF to 1uF, - Add 1206 X7R 100V 330nF to 2.2uF, 250V 33nF to 100nF Version 9 Mar. 22, 2018 Version 8 Nov. 22, 2017 - - Add X7R/0201/25V/100pF~10nF Version 7 Jul. 7, 2017 - Add X7R/0805/330nF to 470nF/50V, X7R/1206/10uF/6.3V Version 6 Mar. 31, 2017 - - - Add 0402 X7R 100nF 25~50V - Add NPO/0603/1nF/50V, X7R/0603/1uF/10V, X7R/0603/470nF/16V, X7R/0603/220nF/25V Version 5 Nov. 15, 2016 - - Add Soldering Condition Version 4 Jun. 14, 2016 - - Add X7R/0805/2.2uF/10V and NPO/1206/1.2nF to 1.5nF/250V Version 3 Jul. 21, 2015 - - Tests and Requirements update Version 2 Jul. 17, 2014 - - Tests and Requirements update Version 1 Apr. 19, 2013 - - Capacitance range update Version 0 Dec. 25, 2012 - - New www.yageo.com Jan. 14, 2022 V.17 Product specification Surface-Mount Ceramic Multilayer Capacitors Automotive grade NPO/X7R 6.3 V to 2000 V LEGAL DISCLAIMER YAGEO, its distributors and agents (collectively, “YAGEO”), hereby disclaims any and all liabilities for any errors, inaccuracies or incompleteness contained in any product related information, including but not limited to product specifications, datasheets, pictures and/or graphics. YAGEO may make changes, modifications and/or improvements to product related information at any time and without notice. YAGEO makes no representation, warranty, and/or guarantee about the fitness of its products for any particular purpose or the continuing production of any of its products. To the maximum extent permitted by law, YAGEO disclaims (i) any and all liability arising out of the application or use of any YAGEO product, (ii) any and all liability, including without limitation s pecial, consequential or incidental damages, and (iii) any and all implied warranties, including warranties of fitness for a particular purpose, non -infringement and merchantability. YAGEO products are designed for general purpose applications under normal operation and usage conditions. Please contact YAGEO for the applications listed below which require especially high reliability for the prevention of defects which might directly cause damage to the third party's life, body or property: Aerospace equipment (artificial satellite, rocket, etc.), Atomic energy-related equipment, Aviation equipment, Disaster prevention equipment, crime prevention equipment, Electric heating apparatus, burning equipment, Highly public information network equipment, data-processing equipment , Medical devices, Military equipment, Power generation control equipment, Safety equipment, Traffic signal equipment, Transportation equipment and Undersea equipment, or for any other application or use in which the failure of YAGEO produ cts could result in personal injury or death, or serious property damage. Information provided here is intended to indicate product specifications only. YAGEO reserves all the rights for revising this content without further notification, as long as produ cts are unchanged. Any product change will be announced by PCN. www.yageo.com Jan. 14, 2022 V.17
AC0201KRX7R9BB221 价格&库存
很抱歉,暂时无法提供与“AC0201KRX7R9BB221”相匹配的价格&库存,您可以联系我们找货
AC0201KRX7R9BB221
  • 15000+0.0531115000+0.00689
  • 30000+0.0484830000+0.00629
  • 45000+0.0461745000+0.00599
  • 75000+0.0436075000+0.00565
  • 105000+0.04210105000+0.00546
  • 150000+0.04066150000+0.00527
库存:85030
AC0201KRX7R9BB221
  • 1+0.884081+0.11460
  • 10+0.2375310+0.03079
  • 50+0.1604250+0.02080
  • 100+0.13571100+0.01759
  • 500+0.09548500+0.01238
  • 1000+0.083151000+0.01078
  • 2500+0.070292500+0.00911
  • 5000+0.062595000+0.00812
库存:85030
AC0201KRX7R9BB221
    • 1+0.40690
    • 100+0.23550
    • 1000+0.14710
    • 7500+0.09920
    • 15000+0.06730
    库存:37790
