SLM2110CG
SLM2110CG
    SILLUMIN(数明半导体)
    SOIC16_300MIL
    600V半桥,互锁,Vo:10-20V,HI/LI正逻辑,SD负逻辑,高低边欠压保护,兼容3.3V、5V和15V逻辑,ton/off:130/120ns, DT:NA, MT:10nS
SLM2110CG 数据手册
SLM2110 600V High and Low Side Driver PRODUCT SUMMARY      VOFFSET IO+/VOUT ton/off (typ.) Delay Matching (typ.) FEATURES  600 V max. 2.5 A / 2.5 A 10 V - 20 V 130 ns/120 ns 10 ns              GENERAL DESCRIPTION The SLM2110 is a high voltage, high speed power MOSFET and IGBT drivers with independent highand low-side referenced output channels. Proprietary HVIC and latch immune CMOS technologies enable ruggedized monolithic construction. The logic input is compatible with standard CMOS or LSTTL output, down to 3.3 V logic. The output drivers feature a high pulse current buffer stage designed for minimum driver cross conduction. Propagation delays are matched to simplify use in high frequency applications. The floating channel can be used to drive an N-channel power MOSFET or IGBT in the high-side configuration which operates up to 600 V. Floating channel designed for bootstrap operation Fully operational to +600 V Tolerant to negative transient voltage, dV/dt immune Gate drive supply range from 10 V to 20 V Undervoltage lockout for both channels 3.3 V, 5 V, and 15 V logic compatible Logic and power ground +/- 5V offset Cross-conduction prevention logic CMOS Schemitt-triggered inputs with pull-down Cycle-by-cycle edge-triggered shutdown logic Matched propagation delay for both channels Outputs in phase with inputs RoHS compliant SOIC-16 (WB) package TYPICAL APPLICATION CIRCUIT up to 600V HO VDD VDD VB HIN HIN VS SD SD LIN LIN VCC VSS VSS COM VCC to load LO SLM2110 (Refer to Lead Assignments for correct configuration). This diagram shows electrical connections only. Please refer to our Application Notes and DesignTips for proper circuit board layout. Figure 1 Typical Application Circuit Sillumin Semiconductor Co., Ltd. – www.sillumin.com Rev1.3, August 2019 1 SLM2110 PIN CONFIGURATION Package Pin Configuration (Top View) SOIC-16 (WB) 9 HO 8 10 VB 7 VS 6 11 VDD 12 HIN 5 13 SD 4 14 LIN VCC 3 15 VSS COM 2 LO 1 16 PIN DESCRIPTION No. Pin Description 1 LO Low-side gate drive output 2 COM Low-side return 3 VCC Low-side supply 4 NC No connection 5 NC No connection 6 VS High-side floating supply return 7 VB High-side floating supply 8 HO High-side gate drive output 9 NC No connection 10 NC No connection 11 VDD Logic supply 12 HIN Logic input for high-side gate driver output (HO), in phase 13 SD Logic input for shutdown 14 LIN Logic input for low-side gate driver output (LO), in phase 15 VSS Logic ground 16 NC No connection ORDERING INFORMATION Industrial Range: -40°C to +125°C Order Part No. Package QTY SLM2110CG SOIC16 (WB), Pb-Free 1500/Reel Sillumin Semiconductor Co., Ltd. – www.sillumin.com Rev1.3, August 2019 2 SLM2110 FUNCTIONAL BLOCK DIAGRAM VB VBS UVLO VDD R S Q Pulse Filter VDD/VCC Level Shift IN Pulse Gen R R S Q HO VS SD VCC VCC UVLO LO VDD/VCC Level Shift LIN R S Delay COM Q VSS SLM2110 Sillumin Semiconductor Co., Ltd. – www.sillumin.com Rev1.3, August 2019 3 SLM2110 ABSOLUTE MAXIMUM RATINGS Symbol Definition VB High-side floating absolute voltage Min. -0.3 Max. 625 Units VS High-side floating supply offset voltage VB - 25 VB + 0.3 VHO High-side floating output voltage VS - 0.3 VB + 0.3 VCC Low-side supply voltage -0.3 25 VDD Logic supply voltage -0.3 VSS + 20 VSS Logic supply offset voltage VCC - 20 VCC + 0.3 VLO Low-side output voltage -0.3 VCC + 0.3 VIN Logic input voltage (HIN, LIN, & SD) VSS - 0.3 VDD + 0.3 dVS/dt Allowable offset supply voltage transient --- 50 V/ns V PD Package power dissipation @ TA ≤ +25°C SOIC-16 (WB) --- 1.25 W RthJA Thermal resistance, junction to ambient SOIC-16 (WB) --- 100 °C/W TJ Junction temperature --- 150 TS Storage temperature -55 150 TL Lead temperature (soldering, 10 seconds) --- 300 °C Note: Absolute maximum ratings indicate sustained limits beyond which damage to the device may occur. All voltage parameters are absolute voltages referenced to COM. The thermal resistance and power dissipation ratings are measured under board mounted and still air conditions. RECOMMENDED OPERATIONG CONDITIONS Symbol Definition VB High-side floating absolute voltage Min. VS + 10 Max. VS + 20 VS High-side floating supply offset voltage Note 1 600 VHO High-side floating output voltage VS VB VCC Low-side supply voltage 10 20 VDD Logic supply voltage VSS + 3 VSS + 20 VSS Logic supply offset voltage -5 5 VLO Low-side output voltage 0 VCC VIN Logic input voltage (HIN, LIN, & SD) VSS VDD TA Ambient temperature - 40 125 Units V °C Note: The input/output logic timing diagram is shown in Fig. 1. For proper operation the device should be used within the recommended conditions. The VS offset rating is tested with all supplies biased at a 15 V differential. Sillumin Semiconductor Co., Ltd. – www.sillumin.com Rev1.3, August 2019 4 SLM2110 DYNAMIC ELECTRICAL CHARACTERISTICS VBIAS (VCC, VBS, VDD) = 15 V, CL = 1000 pF and TA = 25°C unless otherwise specified. Symbol Parameter Condition Min. Typ. Max. ton Turn-on propagation delay VS = 0 V --- 130 160 toff Turn-off propagation delay VS = 600 V --- 120 150 tsd Shutdown propagation delay VS = 600 V --- 130 160 tr Turn-on rise time --- 25 35 tf Turn-off fall time --- 17 25 Delay matching, HS & LS turn-on/off --- --- 10 MT Unit ns STATIC ELECTRICAL CHARACTERISTICS VBIAS (VCC, VBS, VDD) = 15 V and TA = 25°C unless otherwise specified. The VIN, VTH, and IIN parameters are referenced to VSS and and are applicable to all three logic input leads: HIN, LIN, and SD. The VO and IO parameters are referenced to COM and are applicable to the respective output leads: HO or LO. Symbol VIH Parameter Condition Logic “1” input voltage Min. Typ. Max. 10.2 --- --- Unit VCC = 10 V to 20V VIL Logic “0” input voltage --- --- 5.0 VOH High level output voltage, VBIAS - VO --- --- 1.4 VOL Low level output voltage, VO --- 0.02 0.15 ILK Offset supply leakage current --- --- 50 IQBS Quiescent VBS supply current --- 65 120 IQCC Quiescent VCC supply current --- 300 550 IQDD Quiescent VDD supply current --- 15 30 IIN+ Logic “1” input bias current VIN = 5V --- 25 40 IIN- Logic “0” input bias current VIN = 0V --- --- 5 8.9 9.7 V IO = 2 mA VB = VS = 600 V VIN = 0 V or 5 V VBSUV+ VBS supply undervoltage positive going threshold 7.5 VBSUV- VBS supply undervoltage negative going threshold 7.4 8.2 9.4 VCCUV+ VCC supply undervoltage positive going threshold 7.5 8.9 9.7 VCCUV- VCC supply undervoltage negative going threshold 7.4 8.2 2.0 2.5 IO+ IO- Output high short circuit pulsed current Output low short circuit pulsed current Sillumin Semiconductor Co., Ltd. – www.sillumin.com Rev1.3, August 2019 µA V V VO = 0 V VIN = Logic “1” PW ≤ 10 µs VO = 15 V VIN = Logic “0” PW ≤ 10 µs 9.4 A 2.0 2.5 5 SLM2110 Sillumin Semiconductor Co., Ltd. – www.sillumin.com Rev1.3, August 2019 6 SLM2110 Sillumin Semiconductor Co., Ltd. – www.sillumin.com Rev1.3, August 2019 7 SLM2110 Sillumin Semiconductor Co., Ltd. – www.sillumin.com Rev1.3, August 2019 8 SLM2110 Sillumin Semiconductor Co., Ltd. – www.sillumin.com Rev1.3, August 2019 9 SLM2110 Sillumin Semiconductor Co., Ltd. – www.sillumin.com Rev1.3, August 2019 10 SLM2110 Sillumin Semiconductor Co., Ltd. – www.sillumin.com Rev1.3, August 2019 11 SLM2110 Sillumin Semiconductor Co., Ltd. – www.sillumin.com Rev1.3, August 2019 12 SLM2110 Sillumin Semiconductor Co., Ltd. – www.sillumin.com Rev1.3, August 2019 13 SLM2110 PACKAGE CASE OUTLINES Sillumin Semiconductor Co., Ltd. – www.sillumin.com Rev1.3, August 2019 14 SLM2110 Revision History Note: page numbers for previous revisions may differ from page numbers in current version Page or Item Subjects (major changes since previous revision) Rev 1.0 datasheet, 2019-8-27 Whole document New company logo released Page 1 Remove “May 2019” Sillumin Semiconductor Co., Ltd. – www.sillumin.com Rev1.3, August 2019 15
SLM2110CG 价格&库存
很抱歉,暂时无法提供与“SLM2110CG”相匹配的价格&库存,您可以联系我们找货
