SPECIFICATION
Item no.:
T60404-N4646-X412
V A C U U M S C H M E LZ E
K-No.: 24618
20.01.2022
Date:
50/100A Current Sensor
For the electronic measurement of currents:
DC, AC, pulsed, mixed ..., with a galvanic
Isolation between the primary circuit
(high power) and the secondary circuit
(electronic circuit)
Customer:
Standard type
Customers Part no.:
Page
1
of
4
Description
Characteristics
Applications
• Closed loop (compensation)
Current Sensor with magnetic
field probe
• Printed circuit board mounting
• Casing and materials UL-listed
• Excellent accuracy
• Very low offset current
• Very low temperature dependency and offset
current drift
• Very low hysteresis of offset current
• Low response time
• Wide frequency bandwidth
• Compact design
• Reduced offset ripple
Mainly used for stationary operation in industrial
applications:
• AC variable speed drives and servo motor
drives
• Static converters for DC motor drives
• Battery supplied applications
• Switched Mode Power Supplies (SMPS)
• Power Supplies for welding applications
• Uninterruptable Power Supplies (UPS)
Electrical data – Ratings
IPN
Primary nominal rms current
@ VC = ±15V, RM 0Ω
@ VC = ±12V, RM 0Ω or VC = ±15V, RM
Measuring resistance VC=± 12V
VC=± 15V
Secondary nominal rms current
Turns ratio
RM
ISN
KN
50
100
0 ... 200
16 … 400
25/50
1…3 : 2000
16Ω
A
A
Ω
Ω
mA
Accuracy – Dynamic performance data
min.
IP,max
Max. measuring range
@ VC = ±12V, RM = 10Ω (tmax = 10sec)
@ VC = ±15V, RM = 16Ω (tmax = 10sec)
Accuracy @ IPN, TA= 25°C
Linearity
Offset current @ IP=0, TA= 25°C
Response time
Delay time at di/dt = 100 A/µs
Frequency bandwidth
X
L
I0
tr
t (IP,max)
f
typ.
max.
±145
±175
0.1
0.02
500
200
0.5
0.1
0.08
DC...200
Unit
A
A
mA
ns
ns
kHz
General data
min.
typ.
max.
Unit
Ambient operating temperature
-40
+85
°C
Ambient storage temperature (acc. M3101)
-40
+90
°C
Mass
13.5
g
Supply voltage
±11.4
±12 or ±15 ±15.75
V
Current consumption
18.5
mA
Constructed and manufactored and tested in accordance with EN 61800-5-1 (Pin 1 - 6 to Pin 7 – 9)
Reinforced insulation, Insulation material group 1, Pollution degree 2
clearance (component without solder pad)
10.2
mm
creepage (component without solder pad)
10.2
mm
System voltage
overvoltage category 3
600
VRMS
Working voltage (table 7 acc. to EN61800-5-1)
1020
VRMS
Rated discharge voltage
1400
VPEAK
TA
TS
m
VC
IC
Sclear
Screep
Vsys
Vwork
UPD
Max. potential difference acc. to UL 508
Date
20.01.2022
21.01.19
Hrsg.:
editor
Name
NSch.
DJ
Isuue
81
81
R&D-PD NPI D
RMS
600
VAC
Amendment
Applicable documents on sheet 4 changed. „The color of the plastic material… added. Minor change
Page 2: Marking changed from 4646X412 to 4646-X412. Page 3, Type test M3064 accurately defined. CN-19-018.
Bearb:
DJ
MC-PM: NSch.
designer
check
Copying of this document, disclosing it to third parties or using the contents there for any purposes without express written authorization by use illegally forbidden
Any offenders are liable to pay all relevant damages.
freig.: SB
released
SPECIFICATION
Item no.:
T60404-N4646-X412
K-No.: 24618
20.01.2022
Date:
Customer:
Standard type
Customers Part no.:
Mechanical outline (mm):
Page
1,905
Z
9
4
Detail
Z
1...6: ∅ 1.5mm
7...9: 0.6x0.7mm
6
0,6
11,43
0,7
1,29
Marking:
1
3
(2,64)
12,7
2x2,54
Marking
7,75
UL-sign
4646-X412
F
DC
14,45
7.6
21
3.5±0.5
0,65
3x0,7x0,6
6xØ1,5
Schematic diagram
Ip
8 + VC
1...3
7 IS
CA
RM
4...6
9 - VC
M
Possibilities of wiring for VC = ±15V (@ TA = 85°C, RM = 25 )
primary
primary current
windings
RMS maximal
IP [A] ÎP,max [A]
NP
output current turns ratio
RMS
IS (IP) [mA]
KN
primary
resistance
RP [m ]
1
100
175
50
1:2000
0.12
wiring
2
35
82
35
2:2000
0.54
3
25
58
37.5
3:2000
1.1
Hrsg.:
editor
R&D-PD NPI D
4
Connections:
DC = Date Code
F= Factory
Tolerances grid distance
±0,2mm
2x2.54= 5,08
7
of
General tolerances DIN ISO 2768-c
33,25
1,74
2
Bearb:
DJ
1
3
6
1
3
4
6
4
1
3
6
4
MC-PM: NSch.
designer
check
freig.: SB
released
SPECIFICATION
Item no.:
T60404-N4646-X412
K-No.: 24618
20.01.2022
Date:
Customer:
Standard type
Customers Part no.:
Page
3
of
Electrical Data (investigate by a type checking)
min.
VCtot
Maximum supply voltage (without function)
±15.75 to ±18 V: for 1s per hour
Secondary coil resistance @ TA=85°C
Primary coil resistance per turn @ TA=25°C
Temperature drift of X @ TA = -40 ... +85°C
Offset current (including I0, I0t, I0T)
Long term drift Offset current I0
Offset current temperature drift I0 @ TA = -40 ...+85°C
Hyteresis current @ IP=0 (caused by primary current 3 x IPN)
Supply voltage rejection ratio
Offsetripple (with 1MHz- filter first order)
Offsetripple (with 100kHz- filter first order)
Offsetripple (with 20kHz- filter first order)
Maximum possible coupling capacity (primary – secondary)
Mechanical Stress according to M3209/3
Settings: 10 – 2000 Hz, 1 min/Oktave, 2 hours
RS
Rp
XTi
I0ges
I0t
I0T
I0H
I 0 / VC
ioss
ioss
ioss
Ck
typ.
max.
±18
145
0.36
0.1
0.1
0.03
0.03
0.02
0.017
0.005
5
0.05
0.01
0.15
0.025
0.007
10
Unit
V
m
mA
mA
mA
mA
mA/V
mA
mA
mA
pF
g
An exceptionally high rate of on/off – switching of the supply voltage
accelerates the aging process of the sensor.
Inspection (Measurement after temperature balance of the samples at room temperature; SC = significant characteristic)
KN(SC)
I0
Vd
Ve
(V)
M3011/6
(V)
M3226
(V)
M3014
(AQL 1/S4)
Transformation ratio (IP=3*10A, 40-80 Hz)
Offset current
Test voltage, 1s
Partial discharge voltage acc. M3024
with Vvor
1…3 : 2000 ± 0.5 %
< 0.05
mA
2.5
kVRMS
1500
VRMS
1875
VRMS
Type Testing (Precondition acc. to M3236)
VW
HV transient test according to M3064 (1,2 µs / 50 µs-wave form)
5 pulse
polarity +, 5 pulse
polarity Testing voltage acc. M3014
(5s)
with Vvor
Vd
Ve
Hrsg.:
editor
R&D-PD NPI D
Bearb:
DJ
8
5
1500
1875
MC-PM: NSch.
designer
check
kV
kVRMS
VRMS
VRMS
freig.: SB
released
4
SPECIFICATION
Item no.:
T60404-N4646-X412
K-No.: 24618
20.01.2022
Date:
Customer:
Standard type
Customers Part no.:
Limit curve of measurable current ÎP(RM)
Page
4
of
4
Maximum measuring range (µs-range)
@ ambient temperature TA = 85 °C
Output current behaviour of a 3kA current pulse
@ VC = ±15V und RM = 25
NP * ÎP [A]
180
160
I [A]
140
120
1000
V C = +/-15V - 5%
800
100
80
600
V C = +/-12V - 5%
60
40
400
Ip [A]
60
80 100 120 140 160 180 200 220 240
RM [ ]
Ia / KN [A]
-200
2
3
t [µs]
Fast increasing currents (higher than the specified Ip,max), e.g. in case
of a short circuit, can be transmitted because the currents are
transformed directly.
The offset ripple can be reduced by an external low pass. Simplest solution is a passive low pass filter of 1st order
with
fg =
1
2π ⋅ RM ⋅ C a
In this case the response time is enlarged.
It is calculated from:
t r′ ≤ t r + 2,5 RM C a
Temperature of the primary conductor should not exceed 105°C.
Current direction: A positive output current appears at point IS, by primary current in direction of the arrow.
Constructed and manufactored and tested in accordance with EN 61800.
Further standards UL 508 ; file E317483, category NMTR2 / NMTR8
„The color of the plastic material is not specified and the current sensor can be supplied in different colors
(e.g. brown, black, white, natural). This has no effect on the specifications or UL approval.”
Hrsg.:
editor
R&D-PD NPI D
Bearb:
DJ
MC-PM: NSch.
designer
check
freig.: SB
released
