CT4406-2
CT4406-2
    CALTESTELECTRONICS
    CT4406-2
CT4406-2 数据手册
5kV, 4mm Sheathed Banana Jack, Panel Mount, M3 Threaded Hole CT4406-# Features: • 1,000 V CAT IV, 5 kV non-category with 2 kV transient overvoltage • M3 Threaded hole termination • 10 A Max • Panel mount • CE listed • RoHS 2 compliant Measurement Drawing: M12x0.75 (dimensions in mm, not to scale) Ø4 M3x0.5 Ø14.2 2.8 16 2.8 37.2 Description: The CT4406 operates up to 5 kV when used in non-category environments with transient overvoltages up to 2 kV. a This jack also extends the rating of our 4mm Sheathed Banana Jacks to 1,000 V CAT IV. b For use only with Cal Test’s LongReach High Voltage Test Leads, CT3018 or CT3020. The jack offers an M3 threaded hole for connections. The jack fits into both plastic and metal panels fixed with a 14.5 mm hex panel nut. The CT4406 is available in 2 colors. a. Never hold or touch equipment while connected to live voltages. b. Must be used in conjunction with other similarly rated products. Specifications and appearance subject to change without notice D440600 020720 1 - www.caltestelectronics.com Order Information: Contact Info: CT4406-# Toll Free: 800-572-1028 (US Only) Phone: 714-221-9330 Fax: 714-921-9849 22820 Savi Ranch Parkway Yorba Linda, CA 92887-4610 USA www.caltestelectronics.com 5kV, 4mm Sheathed Banana Jack, Panel Mount, M3 Threaded Hole • Color - replace ‘-#’ with dash number: -0 Black, -2 Red Copyright © 2020, Cal Test Electronics, Inc. All rights reserved. Information in this publication supersedes that in all previously published material. Trade names referenced are the service marks, trademarks or registered trademarks of their respective companies. Specifications and appearance subject to change without notice D440600 020720 2 - www.caltestelectronics.com
CT4406-2 价格&库存
很抱歉,暂时无法提供与“CT4406-2”相匹配的价格&库存,您可以联系我们找货
CT4406-2
  • 1+31.204221+4.03853
库存:32
