PRODUCT SPECIFICATION
Part
Number
Product
Description
Doc
Number
USB3150
A
Rev
Micro USB Plug, Type B, Through-Hole, Vertical, with Shell Stakes
and Locating Pegs
USB3150
AO
Prepared
Checked
www.gct.co
VJ
Date
30/04/15
Page
1
Approved
ST
Part
Number
Product
Description
Doc
Number
USB3150
A
Rev
and Locating Pegs
USB3150
Prepared
AO
Checked
VJ
Date
30/04/15
Page
2
Approved
ST
1.0 SCOPE.
This specification covers performance, tests and quality requirements for the Micro USB Plug.
USB3150 (Type B, Through-Hole, Vertical with Shell Stakes and Locating Pegs).
2.0 PRODUCT NAME AND PART NUMBER.
Micro USB Plug, 5 Pin, Type B: USB3150.
3.0 PRODUCT SHAPE, DIMENSIONS AND MATERIAL.
Please refer to drawings.
4.0 RATINGS.
4.1 Current rating: Signal (Pins 2, 3, 4)
1.0A
Power (Pins1, 5).....
1.8A
4.2 Voltage rating ………………………
30V AC
4.3 Operating Temperature Range ……
-30°C to +85°C
5.0 TEST AND MEASUREMENT CONDITIONS.
Product is designed to meet electrical, mechanical and environmental performance requirements
specified in Paragraph 6.0. All tests are performed in ambient conditions unless
otherwise specified.
6.0 PERFORMANCE.
Item
Test Condition
Requirement
Examination of Product
Visual, dimensional and functional
inspection as per quality plan.
Product shall meet requirements
of product drawing and
specification.
www.gct.co
Part
Number
Product
Description
Doc
Number
USB3150
A
Rev
and Locating Pegs
USB3150
Prepared
AO
Checked
VJ
Date
30/04/15
Page
3
Approved
6.1 Electrical Performance.
Item
Test Condition
Requirement
Low-signal Level
Contact
Resistance(initial)
Mate connectors, measure by dry circuit,
20mV, 100mA Max. In accordance with
EIA-364-23.
30mΩ Max.
Insulation Resistance
Mate connectors, apply
100V DC for 1 minute at sea level
between adjacent terminal or ground. In
accordance with EIA-364-21.
1000MΩ Min.
Dielectric Strength
100V AC for 1 minute at sea level. In
accordance with EIA-364-20.
No Breakdown.
6.2 Mechanical Performance.
Item
Test Condition
Requirement
Mating/Un-mating Force
(initial)
Mate/Un-mated at a rate of 12.5mm/min.
In accordance with EIA-364-13.
Mating force: 35N Max.
Un-Mating force: 8N Min. to 25N
Max.
Cycle rate, 500 cycles per hour if done
automatically and 200 if manual cycles. In
accordance with EIA-364-09.
10,000 cycles.
Low Level Contact Resistance:
10mΩ Max. change allowed.
Max.
Durability
Vibration
Mechanical Shock
Mate connectors and subject to 5.35 Gs
RMS. For a period of 15 minutes in each
of the 3 mutually perpendicular axes.
In accordance with EIA-364-28
Test condition V test letter A.
Mate connectors and subject to the
following shock conditions, 3 shocks shall
be applied along 3 mutually perpendicular
axis, passing 100 mA current during the
test. (Total of 18 shocks) Test Pulse:
Half Sine Peak Value: 294 m/s² (30G)
Duration: 11ms.
In accordance with EIA-364-27.
Test condition H.
www.gct.co
Appearance: No Damage.
Contact Resistance: 10mΩ Max.
change allowed.
Discontinuity: 1.0µ second Max.
change allowed.
ST
Part
Number
Product
Description
Doc
Number
USB3150
A
Rev
and Locating Pegs
USB3150
AO
Prepared
Checked
VJ
Date
30/04/15
Page
4
Approved
ST
6.3 Environmental Performance and Others.
Item
Test Condition
Requirement
Cyclic Humidity Test
Subject mated connectors to Duration:
168 hours (7 cycles) temperature between
-25°C to +65°C with 90 to 95% RH.
In accordance with EIA-364-31.
Test condition A method III
change allowed.
Insulation Resistance:
1000MΩ Min.
Dielectric Strength: No Breakdown.
Salt Spray
Subject mated/unmated connectors to 5%
salt-solution concentration, 35°C for 48
hours. In accordance with EIA-364-26,
Test Condition B.
50mΩ Max.
No visible rust
Temperature Life
Subject mated connectors to temperature
life at +85ºC for 96hours.
In accordance with EIA-364-17.
Test condition 2 Method A.
change allowed.
no physical damage.
Temperature Rise
Mate connector and measure the
temperature rise of contact when the
maximum rated current is passed and in
accordance with EIA-364-70.
+30°C Max. change allowed.
Thermal Shock
Mate module and subject to follow
condition for 10 cycles.
At -55°C to +85°C. In accordance with
EIA-364-32, test condition I.
Solderability
Dip solder-tails in flux then immerse in
solder bath at 245 ±5°C up to 0.5mm from
the bottom of the housing for 4~5
seconds. In accordance with EIA-364-52,
category 2.
95% of immersed area must show
no voids, pin holes.
Resistance to Soldering
Heat (Reflow Soldering)
Sample mounted on PCB and subject to
solder bath method,
Temperature:260°C for 10±1 sec
(High Temp. Thermoplastic).
In accordance with EIA-364-56.
Without deformation of shell or
excessive looseness of the
terminals (pin.)
Heat (Hand Soldering)
hand iron soldering,
Temperature:350±10°C for 3±1 sec
terminals (pin.)
www.gct.co
No Damage
Part
Number
Product
Description
Doc
Number
USB3150
A
Rev
and Locating Pegs
USB3150
AO
Prepared
VJ
Checked
Date
30/04/15
Page
5
Approved
7.0 RESISTANCE TO INFRARED REFLOW SOLDERING HEAT
7.1 Lead Free Process: Reflow soldering cycles limited to two times
Temp 260ºC
TEMPERATURE ON BOARD PATTERN SIDE
Peak temp 260ºC
MAX.(10sec. Max)
200ºC Min
40 sec. Min
Slope
