PEME2-S24-S5-S
PEME2-S24-S5-S
    OTHER
    POWER-MODULE-5P_19.65X7.05MM_TM
    PEME2-S24-S5-S
PEME2-S24-S5-S 数据手册
Additional Resources: Product Page | 3D Model | PCB Footprint date 11/07/2022 page 1 of 9 SERIES: PEME2-S │ DESCRIPTION: DC-DC CONVERTER FEATURES • • • • • • • • • 2 W isolated output single/dual unregulated output 3000 Vdc isolation continuous short circuit protection extended temperature range (-40~105°C) no-load input current as low as 8mA efficiency up to 86% UL 62368-1 designed to meet EN/BS EN 62368 MODEL input voltage output voltage output current output power ripple & noise1 efficiency2 typ (Vdc) range (Vdc) (Vdc) min (mA) max (mA) max (W) max (mVp-p) typ (%) PEME2-S5-D3-S4 5 4.5~5.5 ±3.3 ±30 ±303 2 200 75 4 PEME2-S5-D5-S 5 4.5~5.5 ±5 ±20 ±200 2 200 84 PEME2-S5-D9-S4 5 4.5~5.5 ±9 ±11 ±111 2 200 85 4 PEME2-S5-D12-S 5 4.5~5.5 ±12 ±8 ±83 2 200 85 PEME2-S5-D15-S4 5 4.5~5.5 ±15 ±7 ±67 2 200 86 PEME2-S5-D24-S 5 4.5~5.5 ±24 ±4 ±42 2 200 86 PEME2-S5-S3-S4 5 4.5~5.5 3.3 40 400 1.32 200 78 4 PEME2-S5-S5-S 5 4.5~5.5 5 40 400 2 200 84 PEME2-S5-S7-S4 5 4.5~5.5 7.2 28 278 2 200 84 PEME2-S5-S9-S 5 4.5~5.5 9 22 222 2 200 85 PEME2-S5-S12-S4 5 4.5~5.5 12 17 167 2 200 85 4 PEME2-S5-S15-S 5 4.5~5.5 15 13 133 2 200 86 PEME2-S5-S24-S4 5 4.5~5.5 24 8 83 2 200 86 PEME2-S12-D3-S 12 10.8~13.2 ±3.3 ±30 ±303 2 180 75 PEME2-S12-D5-S 12 10.8~13.2 ±5 ±20 ±200 2 180 80 PEME2-S12-D9-S 12 10.8~13.2 ±9 ±11 ±111 2 180 82 PEME2-S12-D12-S 12 10.8~13.2 ±12 ±8 ±83 2 180 83 PEME2-S12-D15-S 12 10.8~13.2 ±15 ±7 ±67 2 180 83 PEME2-S12-D24-S 12 10.8~13.2 ±24 ±4 ±42 2 180 83 PEME2-S12-S5-S 12 10.8~13.2 5 40 400 2 180 82 PEME2-S12-S9-S 12 10.8~13.2 9 22 222 2 180 82 PEME2-S12-S12-S 12 10.8~13.2 12 17 167 2 180 84 PEME2-S12-S15-S 12 10.8~13.2 15 13 133 2 180 85 PEME2-S12-S24-S 12 10.8~13.2 24 8 83 2 180 86 PEME2-S15-D5-S 15 13.5~16.5 ±5 ±20 ±200 2 180 80 PEME2-S15-D15-S4 15 13.5~16.5 ±15 ±7 ±67 2 180 82 4 PEME2-S15-S5-S 15 13.5~16.5 5 40 400 2 180 80 PEME2-S15-S9-S4 15 13.5~16.5 9 22 222 2 180 80 4 4 4 4 4 4 cui.com Additional Resources: Product Page | 3D Model | PCB Footprint CUI Inc │ SERIES: PEME2-S │ DESCRIPTION: DC-DC CONVERTER MODEL (CONTINUED) input voltage date 11/07/2022 │ page 2 of 9 output voltage output current output power ripple & noise1 efficiency2 typ (Vdc) range (Vdc) (Vdc) min (mA) max (mA) max (W) max (mVp-p) typ (%) PEME2-S15-S12-S4 15 13.5~16.5 12 17 167 2 180 81 PEME2-S15-S15-S4 15 13.5~16.5 15 13 133 2 180 81 PEME2-S15-S24-S 15 13.5~16.5 24 8 83 2 180 81 PEME2-S24-D3-S4 24 21.6~26.4 ±3.3 ±30 ±303 2 180 76 PEME2-S24-D5-S 24 21.6~26.4 ±5 ±20 ±200 2 180 80 PEME2-S24-D9-S4 24 21.6~26.4 ±9 ±11 ±111 2 180 81 PEME2-S24-D12-S 24 21.6~26.4 ±12 ±8 ±83 2 180 83 PEME2-S24-D15-S 24 21.6~26.4 ±15 ±7 ±67 2 180 83 PEME2-S24-D24-S 24 21.6~26.4 ±24 ±4 ±42 2 180 83 PEME2-S24-S3-S 24 21.6~26.4 3.3 40 400 1.32 180 76 PEME2-S24-S5-S 24 21.6~26.4 5 40 400 2 180 80 PEME2-S24-S9-S 24 21.6~26.4 9 22 222 2 180 81 PEME2-S24-S12-S 24 21.6~26.4 12 17 167 2 180 84 PEME2-S24-S15-S 24 21.6~26.4 15 13 133 2 180 86 PEME2-S24-S24-S 24 21.6~26.4 24 8 83 2 180 86 4 4 4 4 Notes: 1. 2. 3. 4. Measured at nominal input, 20 MHz bandwidth oscilloscope, with 10 µF tantalum and 1 µF ceramic capacitors on the output. Measured at nominal input voltage, full load. All specifications are measured at Ta=25°C, humidity < 75%, nominal input voltage, and rated output load unless otherwise specified. Model is not UL certified. PART NUMBER KEY PEME2- S XX - X XX - S Base Number Input Voltage Output: S = single D = dual cui.com Output Voltage Mounting Style: SIP Additional Resources: Product Page | 3D Model | PCB Footprint CUI Inc │ SERIES: PEME2-S │ DESCRIPTION: DC-DC CONVERTER date 11/07/2022 │ page 3 of 9 INPUT parameter conditions/description min typ max units operating input voltage 5 Vdc input models 12 Vdc input models 15 Vdc input models 24 Vdc input models 4.5 10.8 13.5 21.6 5 12 15 24 5.5 13.2 16.5 26.4 Vdc Vdc Vdc Vdc surge voltage for maximum of 1 second 5 Vdc input models 12 Vdc input models 15 Vdc input models 24 Vdc input models -0.7 -0.7 -0.7 -0.7 9 18 21 30 Vdc Vdc Vdc Vdc 564 500 494 488 mA 12 Vdc input models 208 mA 15 Vdc input models 167 mA 24 Vdc input models 104 mA 5 Vdc input models current filter 3.3 Vdc output 5 & 7.2 Vdc output 9 & 12 Vdc output 15 & 24 Vdc output filter capacitor OUTPUT parameter conditions/description maximum capacitive load5 3.3, 5 Vdc output models ±3.3, ±5 Vdc output models 7, 9 Vdc output models 12, 15 Vdc output models 24, ±12, ±15 Vdc output models ±9 Vdc output models ±24 Vdc output models min voltage accuracy see output regulation curves line regulation for Vin change of 1% 3.3 Vdc output models all other output models max units 2,400 1,200 1,000 560 220 470 100 μF μF μF μF μF μF μF ±1.5 ±1.2 % % 5 Vdc input models from 10% to full load 3.3 Vdc output 5 & 7.2 Vdc output 9, 12 & 15 Vdc output 24 Vdc output 10 8 7 5 % % % % all other input models from 10% to full load 3.3 Vdc output 5 Vdc output 9, 12 Vdc output 15 Vdc output 24 Vdc output 15 7 5 4 3 % % % % % 220 260 kHz kHz ±0.02 %/°C load regulation switching frequency 100% load, nominal input voltage 5 Vdc input models all other input models temperature coefficient at full load Note: typ 5. Tested at input voltage range and full load. PROTECTIONS parameter conditions/description short circuit protection continuous, auto recovery min cui.com typ max units Additional Resources: Product Page | 3D Model | PCB Footprint CUI Inc │ SERIES: PEME2-S │ DESCRIPTION: DC-DC CONVERTER date 11/07/2022 │ page 4 of 9 SAFETY AND COMPLIANCE parameter conditions/description isolation voltage input to output for 1 minute at 1 mA 3,000 min isolation resistance input to output at 500 Vdc 1,000 isolation capacitance input to output, 100 kHz / 0.1 V safety approvals certified to 62368: UL designed to meet 62368: EN, BS EN conducted emissions CISPR 32/EN 55032 Class B radiated emissions CISPR 32/EN 55032 Class B ESD IEC/EN 61000-4-2 Air ±8kV, Contact ±6kV MTBF as per MIL-HDBK-217F, 25°C RoHS yes typ max units Vdc MΩ 20 pF 3,500,000 hours ENVIRONMENTAL parameter conditions/description min operating temperature see derating curves storage temperature storage humidity non-condensing case temperature rise at 25°C typ max units -40 105 °C -55 125 °C 5 95 25 cui.com % °C Additional Resources: Product Page | CUI Inc │ SERIES: PEME2-S │ DESCRIPTION: DC-DC CONVERTER 3D Model | PCB Footprint date 11/07/2022 │ page 5 of 9 DERATING CURVES cui.com Additional Resources: Product Page | 3D Model | PCB Footprint CUI Inc │ SERIES: PEME2-S │ DESCRIPTION: DC-DC CONVERTER date 11/07/2022 │ page 6 of 9 MECHANICAL parameter conditions/description dimensions 19.65 x 7.05 x 10.16 [0.773 x 0.277 x 0.400 inch] min case material black flame-retardant and heat-resistant plastic (UL94V-0) weight typ units: mm [inch] tolerance: ±0.25[±0.010] pin section tolerance: ±0.10[±0.004] PIN CONNECTIONS PIN Function / Single output Function / Dual output 1 Vin Vin 2 GND GND 5 0V -Vo 6 No pin 0V 7 +Vo +Vo cui.com units mm 2.4 MECHANICAL DRAWING max g Additional Resources: Product Page | 3D Model | PCB Footprint CUI Inc │ SERIES: PEME2-S │ DESCRIPTION: DC-DC CONVERTER date 11/07/2022 │ page 7 of 9 APPLICATION CIRCUIT If you want to further reduce the input and output ripple, a filter capacitor may be connected to the input and output terminals (Figures 1 & 2) provided that the capacitance is less than the maximum capacitive load of the model, otherwise start-up problems may be caused if the capacitance is too large. Table 1 Figure 1 Single Output Models Vin (Vdc) Cin (μF / V) Vo (Vdc) Co (μF / V) 5 10 / 16 3.3 10 / 16 -- -- 5 10 / 16 -- -- 7.2 10 / 16 -- -- 9 2.2 / 25 -- -- 12 2.2 / 25 -- -- 15 1 / 25 -- -- 24 1 / 50 12 2.2 / 25 3.3 10 / 16 15 2.2 / 25 5 10 / 16 24 1 / 50 9 2.2 / 25 -- -- 12 2.2 / 25 -- -- 15 1 / 25 -- -- 24 1 / 50 Figure 2 Dual Output Models Table 2 Vin (Vdc) Cin (μF / V) Vo (Vdc) Co6 (μF / V) 5 10 / 16 ±3.3 4.7 / 16 -- -- ±5 4.7 / 16 -- -- ±9 1 / 25 -- -- ±12 1 / 25 -- -- ±15 0.47 / 25 -- -- ±24 0.47 / 50 12 2.2 / 25 ±3.3 4.7 / 16 15 2.2 / 25 ±5 4.7 / 16 24 1 / 50 ±9 2.2 / 25 -- -- ±12 1 / 25 -- -- ±15 1 /25 -- ±24 0.47 / 50 -Note: cui.com 6. The capacitor value of the positive and the negative output is identical. Additional Resources: Product Page | 3D Model | PCB Footprint CUI Inc │ SERIES: PEME2-S │ DESCRIPTION: DC-DC CONVERTER date 11/07/2022 │ page 8 of 9 EMC RECOMMENDED CIRCUIT Figure 3 Single Output Models Figure 4 Dual Output Models Table 3 Recommended External Circuit Components Vin (Vdc) 5 Vo (Vdc) all output models 12, 15, 24 ±12, ±15, ±24 C1 / C2 4.7 µF / 16 V 4.7 µF / 50 V 4.7 µF / 50 V CY 270 pF / 4 kV 270 pF / 3 kV 270 pF / 3 kV C3 / C4 LDM 12, 15, 24 refer to the Co in Tables 1, 2 6.8 μH 6.8 μH cui.com 6.8 μH Additional Resources: Product Page | 3D Model | PCB Footprint CUI Inc │ SERIES: PEME2-S │ DESCRIPTION: DC-DC CONVERTER date 11/07/2022 │ page 9 of 9 REVISION HISTORY rev. description date 1.0 initial release 07/23/2021 1.01 series expanded with 5 Vdc input models 06/21/2022 1.02 CE certification removed 11/07/2022 The revision history provided is for informational purposes only and is believed to be accurate. Headquarters 20050 SW 112th Ave. Tualatin, OR 97062 800.275.4899 Fax 503.612.2383 cui.com techsupport@cui.com CUI offers a two (2) year limited warranty. Complete warranty information is listed on our website. CUI reserves the right to make changes to the product at any time without notice. Information provided by CUI is believed to be accurate and reliable. However, no responsibility is assumed by CUI for its use, nor for any infringements of patents or other rights of third parties which may result from its use. CUI products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or effectiveness.
PEME2-S24-S5-S 价格&库存
很抱歉,暂时无法提供与“PEME2-S24-S5-S”相匹配的价格&库存,您可以联系我们找货
