KH-2FH-2X10P-H4.3
KH-2FH-2X10P-H4.3
    KINGHELM(金航标)
    插件,P=2mm
    排母 间距:2mm 2x10P 直插
KH-2FH-2X10P-H4.3 数据手册
SPECIFICATIONS Current Rating: 1.5 Amps Insulation Resistance:1000MΩ Min Contact Resistance: 20mΩ Max Withstanding Voltage: AC 500V Operation Temperature:-40°to+105° Contact Material: Brass Standard: PA6T Insrlator Material: Polyester(UL 94V-0) Contact Plating: Gold Flash Max.Processing Temp: 240°C for30-60seconds (260°C for 5 seconds) RECOMMEND P.C.B LAYOUT PCB TOLERANCE:±0.05 (TOP VIEW) (1) Pin Spacing:200=2.0mm (2) Product Name:FH=Female Header (3) No.of Rows: 1=Single Row ;2=Dual Row (4) No.of Pins Per Row: 1~40 (5) Insulator Material Height:43=4.3mm;72=7.2mm (6) Connector Type:S=Straight;R=Right;Angle M=SMT (7) Connector Material Length:24=2.4mm;28=2.8mm (8) Insulator Material Width: 40=4.0mm 45=4.5mm (9) Contact Plating: G0=Gold Flash;AU10=Au 1.0u" (10)Insulator Material Option: A=BK-PA6T;B=BK-PA46;C=KB-LCP;S=Special PIN 0.5X0.2 深圳市金航标电子有限公司 WWW.BDS666.COM KH-2FH-2X10P-H4.3 UNLESS OTHEWIXE SPECIFIED TOLERANCE X :±0.3 X.X :±0.2 X.XX:±0.1 X° :±5° X.X° :±1° X.XX°:±0.5° CHECKED: LI BEI LIN 12/03/07 DRAWM NAME: SIZE REV A4 A CHECKED: No. of DIM.A 1 0755-83044319 2.0FH 2xnPin H4.3 DIP SCALE PROUCT NO. UNIT PROJECT / / APPROVED: PAGE 1/1 / / 0.00 DIM.B No. of DIM.A DIM.B No. of DIM.A DIM.B No. of DIM.A DIM.B
KH-2FH-2X10P-H4.3
物料型号:KH-2FH-2X10P-H4.3 器件简介:未提供 引脚分配:2排,每排10个引脚 参数特性: - 接触电阻:最大20mΩ - 耐压:交流500V - 工作温度:-40°C至+105°C - 接触材料:黄铜 - 绝缘体材料:聚酯(UL 94V-0) - 接触镀层:金闪 - 最大加工温度:240°C(30-60秒)或260°C(5秒) 功能详解:未提供 应用信息:未提供 封装信息: - 产品名称:FH=Female Header(Female Header) - 行数:1=单行;2=双行 - 每行引脚数:1~40 - 绝缘体材料高度:43=4.3mm; 72=7.2mm - 连接器类型:S=直;R=直角;M=SMT - 连接器材料长度:24=2.4mm; 28=2.8mm - 绝缘体材料宽度:40=4.0mm; 45=4.5mm - 接触镀层:G0=金闪;AU10=1.0μ"金 - 绝缘体材料选项:A=BK-PA6T; B=BK-PA46; C=KB-LCP; S=特殊
KH-2FH-2X10P-H4.3 价格&库存
很抱歉,暂时无法提供与“KH-2FH-2X10P-H4.3”相匹配的价格&库存,您可以联系我们找货
