773-E15-113R461
773-E15-113R461
    NORCOMP
773-E15-113R461 数据手册
Description: Dimensions (inch/mm) 0.283" Right Angle / Machined Pins 9 A ±0.008 15 B ± 0.008 25 Ø 0.120 2-PLS C ± 0.008 F ±0.008 B C D E F 1.213 30.80 1.543 39.20 2.089 53.05 0.984 25.00 1.311 33.30 1.852 47.05 0.665 16.90 0.994 25.25 1.533 38.95 0.327 8.30 0.327 8.30 0.327 8.30 0.240 6.10 0.240 6.10 0.240 6.10 0.492 12.50 0.492 12.50 0.492 12.50 0.031 (0.80) ±0.008 D ±0.008 Pin 1 0.118 (3.00) TYP. Ø 0.026 (0.65) 773-EYY-11YRYY1 E ±0.008 0.433 (11.00) ±0.012 Meets IP67 Standards (See page 3 for sealing details) Material: Shell: Insulator: Process Temperature: Contact: Seal: Nickel Plated Steel Glass-Filled Nylon Thermoplastic, UL94 V-0 260°C Precision Machined Copper Alloy Flexible F08 Adhesive Electrical: Current Rating: Contact Resistance: Insulation Resistance: Working Voltage: Temperature: Series Position E09 E15 E25 Gender 1 = Male Termination 1 = PCB Mounting Shell Plating 3 = Nickel RoHS Compliant Hardware Options 00 = No Hardware 01 = 0.065" Clinch Nut (Board Side) 0A = 0.098" Clinch Nut (Board Side) 14 = Standard Bracket with 4-40 Screwlock 46 = Boardlock Bracket with 4-40 Insert Plating Options 1 = Gold Flash 2 = 30 " Gold 5 AMPS 10 mOhms Max. 5 GOhms Min. 250V -55° C TO +125° C RoHS COMPLIANT N C A THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF NorComp AND SHALL NOT BE REPRODUCED, COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. UNITS = inch [mm] DRAWN: Pam Jenkins DATE: 06/29/2009 DO NOT SCALE FROM DRAWING NorComp SCALE: SHEET NTS DWG NO. REV OF 1 4 773-EYY-11YRYY1 16 Description: PCB Layout 9 POSITION 15 POSITION 25 POSITION 0.984 1.312 1.852 CL CL 0.492 0.108 * 0.378 0.216 0.270 0.112 (9, 15, 25, 37 POSITON) 0.162 0.054 0.339 0.283 CL Ø 0.126 Minimum see page (3) for Bracket Hole Location 0.656 0.926 0.652 0.544 0.435 0.326 0.218 0.109 0.108 0.162 Ø 0.043 0.216 0.054 PCB Edge Typical for 9,15,25 Position 0.324 * 0.055 0.163 0.272 0.381 0.489 0.598 UNITS = inch Typical Suggested Size * May Not Be Suitable For All Applications RoHS COMPLIANT N C THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF NorComp AND SHALL NOT BE REPRODUCED, COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. DO NOT SCALE FROM DRAWING DRAWN: Pam Jenkins DATE: 06/29/2009 NorComp SCALE: SHEET NTS DWG NO. REV OF 2 4 773-EYY-11YRYY1 16 Description: IP67 Sealing Process A A FRONT SEAL APPLIED OVER INSULATOR AND BETWEEN FRONT & REAR SHELLS DETAIL A-A RoHS COMPLIANT N C THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF NorComp AND SHALL NOT BE REPRODUCED, COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. DO NOT SCALE FROM DRAWING DRAWN: Pam Jenkins DATE: 06/29/2009 NorComp SCALE: SHEET NTS DWG NO. REV OF 3 4 773-EYY-11YRYY1 16 Description: Hardware Options 01 Hardware Option 0A Hardware Option 0.065" Clinch Nut (Board Side) 0.098" Clinch Nut (Board Side) 0.108 [2.74] 14 Hardware Option 1 2 3 4 0.142 [3.60] Description NorComp Part Number 4-40 Screwlock Bracket Lock Washer 4-40 Nut SFSO4401NR K501CZ LW1T N4401N 2 1 0.065 [1.65] 3 0.098 [2.50] Clinch Nut has 4-40 Internal Threads 4 Clinch Nut has 4-40 Internal Threads **Search Hardware Part Number To Obtain Technical Specifications. 46 Hardware Option Boardlock Bracket and 4-40 Insert #4-40 Threaded Insert 9-25 Position Connector Boardlock Bracket Hole C/L 0.339 [8.62] Boardlock Brackets Come Assembled On Connector RoHS COMPLIANT N C THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF NorComp AND SHALL NOT BE REPRODUCED, COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. UNITS = inch [mm] DRAWN: Pam Jenkins DATE: 06/29/2009 DO NOT SCALE FROM DRAWING NorComp SCALE: SHEET NTS DWG NO. REV OF 4 4 773-EYY-11YRYY1 16
773-E15-113R461 价格&库存
很抱歉,暂时无法提供与“773-E15-113R461”相匹配的价格&库存,您可以联系我们找货
773-E15-113R461
