MF1103004M4EP0FPT0
MF1103004M4EP0FPT0
    STE(松田)
    插件,P=7.5mm
MF1103004M4EP0FPT0 数据手册
Negative Temperature Coefficient Thermistor (NTC Series) Negative Temperature Coefficient Thermistor (NTC) Data Sheet Feature ■Wide operating voltage range from φ5 to φ20 ■Operating Temperature Style Operating Temperature Range φ5 -40℃~155℃ Φ7/φ9/φ11 -40℃~175℃ Φ13/φ15/φ20 -40℃~200℃ ■Storage Temperature: 15℃~35℃ Applications ■Suitable for power supply, electronic motors, transformers, adapters, projectors, halogen machines, LED drive circuits, etc. Applicable Standard Approval Organization Safety Standards Certificate No. China CQC GB/T 6663.1 CQC15001128226 USA Canada UL UL 1434 E474052 Revision: 2018-04-29 1 Email: info@songtian.cn Website: http://songtian.cn Negative Temperature Coefficient Thermistor (NTC Series) Part Number Code MF 05 Songtian MF:NTC 100 X8 M Zero Power Resistance 0R5:0.5Ω 080:8Ω 100:10Ω 121:120Ω 3 B X7 B 0 Inner Management Encapsulation material Environmental Standard S:Silicone+RoHS P:Phenolic Resin+RoHS F:Phenolic Resin +Halogen free R:Phenolic Resin + Halogen free Foot Type 1:Long straight 2:Outside Crimped 3:Short Straight 4:Inside kink lead 8:Vertical Crimped Maximum Steady State Current X1:0.1A S5:1.5A 03:3.0A 10:10A S Package B: Bulk T:Tape Pitch B:5.0mm E:7.5mm D:10.0mm Tolerance M:±20% Core Diameter 05:5mm 20:20mm C Lead Material F: Tinned copper clad steel wire C:Copper wire Lead Length S0~S9:1.0~1.9mm X0~X9:2.0~2.9mm A0~A9:3.0~3.9mm B0~B9:4.0~4.9mm C0~C9:5.0~5.9mm D0~D9:6.0~6.9mm E0~E9:7.0~7.9mm Lead Length F0~F9:8.0~8.9mm G0~G9:9.0~9.9mm H0~H9:10.0~10.9mm J0~J9:11.0~11.9mm K0~K9:12.0~12.9mm L0~L9:13.0~13.9mm M0~M9:14.0~14.9mm Lead Length M0~M9:14.0~14.9mm N0:16~27.0mm(Bulk) H0=16.5(Taped) Taping PO:17.0mm Q0:20.0mm Electrical Characteristics □D-5 Series Part Number Rated Zero Power Resistance @25℃(Ω) Maximum Steady Current @25℃(A) Residual Resistor At Maximum Steady Current @25℃(Ω) B Value (K) ±10% Thermal Time Constant (S) Heat Dissipation Coefficient (mW/℃) Operating Temperature Range (℃) 5D-5 5 1 0.353 2500 <20 >6 -40℃~155℃ 10D-5 10 0.7 0.771 2600 <20 >6 -40℃~155℃ 15D-5 15 0.6 1.53 2600 <20 >6 -40℃~155℃ 20D-5 20 0.5 1.253 2600 <20 >6 -40℃~155℃ 22D-5 22 0.6 2.06 2600 <20 >6 -40℃~155℃ 30D-5 30 0.4 2.227 2600 <20 >6 -40℃~155℃ Revision: 2018-04-29 2 Email: info@songtian.cn Website: http://songtian.cn Negative Temperature Coefficient Thermistor (NTC Series) Part Number Rated Zero Power Resistance @25℃(Ω) Maximum Steady Current @25℃(A) Residual Resistor At Maximum Steady Current @25℃(Ω) B Value (K) ±10% Thermal Time Constant (S) Heat Dissipation Coefficient (mW/℃) Operating Temperature Range (℃) 33D-5 33 0.4 1.324 2600 <20 >6 -40℃~155℃ 50D-5 50 0.4 2.653 2800 <18 >6 -40℃~155℃ 60D-5 60 0.3 1.878 2800 <18 >6 -40℃~155℃ Part Number Rated Zero Power Resistance @25℃(Ω) Maximum Steady Current @25℃(A) Residual Resistor At Maximum Steady Current @25℃(Ω) B Value (K) ±10% Thermal Time Constant (S) Heat Dissipation Coefficient (mW/℃) Operating Temperature Range (℃) 5D-7 5 2 0.283 2600 <30 >10 -40℃~175℃ 8D-7 8 1 0.539 2600 <28 >9 -40℃~175℃ 10D-7 10 1 0.616 2800 <27 >9 -40℃~175℃ 12D-7 12 1 0.816 2800 <27 >9 -40℃~175℃ 16D-7 16 0.7 1.003 2800 <27 >9 -40℃~175℃ 20D-7 20 0.6 1.102 2800 <27 >9 -40℃~175℃ 22D-7 22 0.6 1.108 2800 <27 >9 -40℃~175℃ 30D-7 30 0.5 3.7059 2800 <28 >10 -40℃~175℃ 33D-7 33 0.2 1.485 2800 <28 >10 -40℃~175℃ 50D-7 50 0.5 1.653 2800 <28 >10 -40℃~175℃ Part Number Rated Zero Power Resistance @25℃(Ω) Maximum Steady Current @25℃(A) Residual Resistor At Maximum Steady Current @25℃(Ω) B Value (K) ±10% Thermal Time Constant (S) Heat Dissipation Coefficient (mW/℃) Operating Temperature Range (℃) 3D-9 3 4 0.120 2600 <35 >11 -40℃~175℃ 4D-9 4 3 0.190 2600 <35 >11 -40℃~175℃ 5D-9 5 3 0.210 2600 <34 >11 -40℃~175℃ 6D-9 6 2 0.315 2600 <34 >11 -40℃~175℃ 7D-9 7 2 0.3265 2800 <34 >11 -40℃~175℃ 8D-9 8 2 0.400 2800 <32 >11 -40℃~175℃ 10D-9 10 2 0.458 2800 <32 >11 -40℃~175℃ 12D-9 12 1 0.652 2800 <32 >11 -40℃~175℃ 16D-9 16 1 0.802 2800 <31 >11 -40℃~175℃ □D-7 Series □D-9 Series Revision: 2018-04-29 3 Email: info@songtian.cn Website: http://songtian.cn Negative Temperature Coefficient Thermistor (NTC Series) Part Number Rated Zero Power Resistance @25℃(Ω) Maximum Steady Current @25℃(A) Residual Resistor At Maximum Steady Current @25℃(Ω) B Value (K) ±10% Thermal Time Constant (S) Heat Dissipation Coefficient (mW/℃) Operating Temperature Range (℃) 20D-9 20 1 0.864 3000 <30 >11 -40℃~175℃ 22D-9 22 1 0.950 3000 <30 >11 -40℃~175℃ 30D-9 30 1 1.022 3000 <30 >11 -40℃~175℃ 33D-9 33 1 1.124 3000 <30 >11 -40℃~175℃ 50D-9 50 1 1.252 3200 <30 >11 -40℃~175℃ 60D-9 60 0.8 1.502 3200 <31 >11 -40℃~175℃ 80D-9 80 0.8 2.010 3200 <30 >11 -40℃~175℃ 120D-9 120 0.8 3.015 3200 <30 >11 -40℃~175℃ 200D-9 200 0.5 5.007 3400 <32 >11 -40℃~175℃ Part Number Rated Zero Power Resistance @25℃(Ω) Maximum Steady Current @25℃(A) Residual Resistor At Maximum Steady Current @25℃(Ω) B Value (K) ±10% Thermal Time Constant (S) Heat Dissipation Coefficient (mW/℃) Operating Temperature Range (℃) 2.5D-11 2.5 5 0.095 2600 <43 >13 -40℃~175℃ 3D-11 3 5 0.100 2600 <43 >13 -40℃~175℃ 4D-11 4 4 0.150 2600 <44 >13 -40℃~175℃ 5D-11 5 4 0.156 2800 <45 >13 -40℃~175℃ 6D-11 6 3 0.240 2800 <45 >13 -40℃~175℃ 7D-11 7 3 0.2824 2800 <45 >13 -40℃~175℃ 8D-11 8 3 0.255 2800 <47 >14 -40℃~175℃ 10D-11 10 3 0.275 2800 <47 >14 -40℃~175℃ 12D-11 12 2 0.462 2800 <48 >14 -40℃~175℃ 15D-11 15 2 0.468 2800 <50 >14 -40℃~175℃ 16D-11 16 2 0.470 2800 <50 >14 -40℃~175℃ 20D-11 20 2 0.512 3000 <52 >15 -40℃~175℃ 22D-11 22 2 0.563 3000 <52 >15 -40℃~175℃ 25D-11 25 2 0.623 3000 <52 >15 -40℃~175℃ 30D-11 30 1.5 0.667 3000 <52 >15 -40℃~175℃ 33D-11 33 1.5 0.734 3000 <52 >15 -40℃~175℃ 47D-11 47 1.5 1.002 3200 <52 >15 -40℃~175℃ 50D-11 50 1.5 1.021 3200 <52 >15 -40℃~175℃ □D-11 Series Revision: 2018-04-29 4 Email: info@songtian.cn Website: http://songtian.cn Negative Temperature Coefficient Thermistor (NTC Series) Part Number Rated Zero Power Resistance @25℃(Ω) Maximum Steady Current @25℃(A) Residual Resistor At Maximum Steady Current @25℃(Ω) B Value (K) ±10% Thermal Time Constant (S) Heat Dissipation Coefficient (mW/℃) Operating Temperature Range (℃) 60D-11 60 1.5 1.215 3200 <52 >15 -40℃~175℃ 80D-11 80 1.2 1.656 3200 <52 >15 -40℃~175℃ 120D-11 120 1.1 2.253 3000 <50 >15 -40℃~175℃ Part Number Rated Zero Power Resistance @25℃(Ω) Maximum Steady Current @25℃(A) Residual Resistor At Maximum Steady Current @25℃(Ω) B Value (K) ±10% Thermal Time Constant (S) Heat Dissipation Coefficient (mW/℃) Operating Temperature Range (℃) 1.3D-13 1.3 7 0.062 2600 <60 >13 -40℃~200℃ 1.5D-13 1.5 7 0.073 2600 <60 >13 -40℃~200℃ 2.5D-13 2.5 6 0.088 2600 <60 >13 -40℃~200℃ 3D-13 3 6 0.092 2600 <60 >14 -40℃~200℃ 4D-13 4 5 0.120 2800 <67 >15 -40℃~200℃ 4.7D-13 4.7 5 0.1469 2800 <67 >15 -40℃~200℃ 5D-13 5 5 0.125 2800 <68 >15 -40℃~200℃ 6D-13 6 4 0.170 2800 <65 >15 -40℃~200℃ 7D-13 7 4 0.188 3000 <65 >15 -40℃~200℃ 8D-13 8 4 0.194 3000 <60 >15 -40℃~200℃ 10D-13 10 4 0.206 3000 <65 >15 -40℃~200℃ 12D-13 12 3 0.316 3200 <65 >16 -40℃~200℃ 15D-13 15 3 0.335 3200 <60 >16 -40℃~200℃ 16D-13 16 3 0.338 3200 <60 >16 -40℃~200℃ 18D-13 18 3 0.356 3200 <60 >16 -40℃~200℃ 20D-13 20 3 0.372 3200 <65 >16 -40℃~200℃ 22D-13 22 3 0.625 3200 <65 >16 -40℃~200℃ 25D-13 25 2.5 0.422 3200 <65 >16 -40℃~200℃ 30D-13 30 2.5 0.517 3200 <65 >16 -40℃~200℃ 33D-13 33 2.5 0.592 3200 <65 >16 -40℃~200℃ 47D-13 47 2 0.810 3200 <65 >17 -40℃~200℃ 50D-13 50 2 1.161 3200 <65 >13 -40℃~200℃ 120D-13 120 1.2 2.124 3400 <65 >17 -40℃~200℃ □D-13 Series Revision: 2018-04-29 5 Email: info@songtian.cn Website: http://songtian.cn Negative Temperature Coefficient Thermistor (NTC Series) □D-15 Series Part Number Rated Zero Power Resistance @25℃(Ω) Maximum Steady Current @25℃(A) Residual Resistor At Maximum Steady Current @25℃(Ω) B Value (K) ±10% Thermal Time Constant (S) Heat Dissipation Coefficient (mW/℃) Operating Temperature Range (℃) 1.3D-15 1.3 8 0.048 2600 <68 >18 -40℃~200℃ 1.5D-15 1.5 8 0.052 2600 <69 >18 -40℃~200℃ 2.5D-15 2.5 7 0.065 2800 <76 >18 -40℃~200℃ 3D-15 3 7 0.075 2800 <76 >18 -40℃~200℃ 4D-15 4 6 0.1985 2800 <76 >18 -40℃~200℃ 5D-15 5 6 0.112 3000 <76 >20 -40℃~200℃ 6D-15 6 5 0.155 3000 <80 >20 -40℃~200℃ 7D-15 7 5 0.173 3000 <80 >20 -40℃~200℃ 8D-15 8 5 0.178 3000 <80 >20 -40℃~200℃ 10D-15 10 5 0.180 3200 <75 >20 -40℃~200℃ 12D-15 12 4 0.250 3200 <75 >20 -40℃~200℃ 15D-15 15 4 0.268 3200 <85 >21 -40℃~200℃ 16D-15 16 4 0.276 3200 <70 >21 -40℃~200℃ 18D-15 18 4 0.3375 3200 <70 >21 -40℃~200℃ 20D-15 20 4 0.288 3200 <86 >21 -40℃~200℃ 22D-15 22 4 0.3812 3200 <86 >21 -40℃~200℃ 25D-15 25 3.5 0.358 3200 <86 >21 -40℃~200℃ 30D-15 30 3.5 0.438 3200 <75 >21 -40℃~200℃ 33D-15 33 3 0.571 3200 <86 >21 -40℃~200℃ 40D-15 40 3 0.587 3200 <86 >21 -40℃~200℃ 47D-15 47 3 0.680 3200 <86 >21 -40℃~200℃ 50D-15 50 3 0.734 3200 <86 >21 -40℃~200℃ 120D-15 120 1.8 1.652 3400 <87 >22 -40℃~200℃ Part Number Rated Zero Power Resistance @25℃(Ω) Maximum Steady Current @25℃(A) Residual Resistor At Maximum Steady Current @25℃(Ω) B Value (K) ±10% Thermal Time Constant (S) Heat Dissipation Coefficient (mW/℃) Operating Temperature Range (℃) 0.7D-20 0.7 11 0.018 2400 <89 >24 -40℃~200℃ 1.3D-20 1.3 9 0.037 2600 <88 >24 -40℃~200℃ □D-20 Series Revision: 2018-04-29 6 Email: info@songtian.cn Website: http://songtian.cn Negative Temperature Coefficient Thermistor (NTC Series) Part Number Rated Zero Power Resistance @25℃(Ω) Maximum Steady Current @25℃(A) Residual Resistor At Maximum Steady Current @25℃(Ω) B Value (K) ±10% Thermal Time Constant (S) Heat Dissipation Coefficient (mW/℃) Operating Temperature Range (℃) 2.2D-20 2.2 8 0.1292 2800 <88 >24 -40℃~200℃ 2.5D-20 2.5 8 0.052 2800 <88 >24 -40℃~200℃ 3D-20 3 8 0.055 2800 <88 >24 -40℃~200℃ 5D-20 5 7 0.087 3000 <87 >24 -40℃~200℃ 6D-20 6 6 0.113 3000 <103 >25 -40℃~200℃ 8D-20 8 6 0.142 3000 <105 >25 -40℃~200℃ 10D-20 10 6 0.162 3200 <102 >25 -40℃~200℃ 12D-20 12 5 0.195 3200 <100 >25 -40℃~200℃ 16D-20 16 5 0.212 3200 <100 >25 -40℃~200℃ Dimensions (mm) and Approval Size (mm) Part No. □D-5 □D-7 □D-9 □D-11 □D-13 □D-15 □D-20 Revision: 2018-04-29 D Max. T Max. F±0.8 7.0 4.5 9.0 Approval d±0.05 CQC cUL (Canada) CP CU 5.0 0.6 0.6 √ √ 5.0 5.0 0.6 0.6 √ √ 11.0 6.0 5.0 0.7 0.8 √ √ 13.0 6.5 7.5 0.7 0.8 √ √ 15.5 7.0 7.5 0.7 0.8 √ √ 17.5 7.0 7.5 0.7 0.8 √ √ 22.5 7.0 10.0 1.0 1.0 √ √ 7 Email: info@songtian.cn Website: http://songtian.cn Negative Temperature Coefficient Thermistor (NTC Series) Lead Configuration Lead Length L (mm) Coating Lead Length C (mm) Height H (mm) Long Straight 16.0 min 3.0 Max / Short Straight ①[2.5≤L<6.0]+/-0.5; ②[6.0≤L≤10]+/-1.0 3.0 Max / Outside Crimped ①[2.5≤L<6.0]+/-0.5; ②[6.0≤L≤10]+/-1.0 Not exceed the bend point 5.0mm Max Inner Crimped ①[2.5≤L<6.0]+/-0.5; ②[6.0≤L≤10]+/-1.0 Not exceed the bend point 6.0mm Max Vertical Crimped ①[2.5≤L<6.0]+/-0.5; ②[6.0≤L≤10]+/-1.0 Not exceed the bend point 4.0mm Max Lead Style Revision: 2018-04-29 Drawing 8 Email: info@songtian.cn Website: http://songtian.cn Negative Temperature Coefficient Thermistor (NTC Series) Taping Specification (mm) Fig.1 Fig.2 Figure Fig.1 (P=5.0) Symbol P=5.0 P=7.5 P=10.0 Po 12.7±0.3 12.7±0.3 12.7±0.3 P 12.7±1.0 25.4±1.0 25.4±1.0 P1 3.85±0.7 8.95±0.7 7.7±0.7 P2 6.35±1.3 12.7±1.3 12.7±1.3 F 5±0.8 7.5±0.8 10.0±0.8 Δh 0±2.0 0±2.0 0±2.0 W 18.0+1.5/-1.0 18.0 +1.5/-1.0 18.0 +1.5/-1.0 Wo 10.5 Max 10.5 Max 10.5 Max W1 9.0+0.75/-0.5 9.0+0.75/-0.5 9.0+0.75/-0.5 W2 3.0 Max 3.0 Max 3.0 Max Do 4.0±0.2 4.0±0.2 4.0±0.2 H 20+1.5/-1.0 20+1.5/-1.0 20+1.5/-1.0 16.5&17.0 16.5&17.0 16.5&17.0 Ho +1.5/-1.0 +1.5/-1.0 +1.5/-1.0 Straight Lead Crimped Lead Straight Lead Crimped Lead Straight Lead Crimped Lead 11.0 Max 9.0 Max 11.0 Max 9.0 Max 11.0 Max 9.0 Max L Fig.2 (P=7.5 & 10) Revision: 2018-04-29 t1 0.5±0.2 0.5±0.2 0.5±0.2 t2 1.7 Max 1.7 Max 1.7 Max 9 Email: info@songtian.cn Website: http://songtian.cn
MF1103004M4EP0FPT0 价格&库存
很抱歉,暂时无法提供与“MF1103004M4EP0FPT0”相匹配的价格&库存,您可以联系我们找货
MF1103004M4EP0FPT0
  • 5+0.61917
  • 50+0.49842
  • 150+0.43805
  • 1000+0.35759
  • 2000+0.32141
  • 5000+0.30327
库存:679
