This document contains data proprietary to PUI Audio Inc. Any use or reproduction, in any form, without prior written permission
of PUI Audio Inc. is prohibited.
©2019, PUI Audio Inc.
Data Sheet
DMM-4026-B-I2S-R
Specifications
Parameters
Directivity
Data Format (Single Channel)
Sensitivity
Rated Voltage
Operating Voltage Range
Supply Current
Signal-to-Noise Ratio
Frequency Range
Total Harmonic Distortion
(typical)
Startup Time
Input Clock Frequency
Clock Jitter
Load Capacitance
Pass Band
Pass Band Attenuation
Acceptable Soldering Methods
Environmental Compliances
Power Supply Rejection
Weight
Operating Temperature
Storage Temperature
MSL (Moisture Sensitivity Level)*
Condition
Values
Units
Omnidirectional
2
I S 24-bit data size with 18-bit precision, 32-bit word size
1 kHz @ 50cm with 94 dB source
0 dB=1V/Pa
-26±1
dB
1.8
VDC
1.5 to 3.6
VDC
Normal Mode
820 ~ 1000
µA
Sleep Mode (clock off)
5
µA
1kHz, 94 dB input, A-weighted
64
dB
20~20,000
Hz
110 dB @ 50cm, 1 kHz acoustic
source
1%
Sensitivity reaching 90% of
listed value from initial powerup
mS
From Sleep Mode
mS
From Normal Mode to Sleep
Mode
mS
Normal Mode
2.048 ~ 4.096
MHz
Sleep Mode
320
kHz
Long Term RMS
500
pS
140
pF
Fs=48 kHz
18
kHz
0.5
dB
See page 4
Reflow Solder
for soldering
information
RoHS/Halogen Free
100 mVpp Square Wave
@ 217 Hz, A-weighted
-86
dBFS
很抱歉,暂时无法提供与“DMM-4026-B-I2S-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 2+19.24998
- 20+17.35466
- 200+15.98524
- 1000+14.82931
- 2000+12.04361
- 国内价格 香港价格
- 1250+13.479451250+1.74349
- 2500+12.808392500+1.65670
- 国内价格 香港价格
- 1+25.967331+3.35873
- 10+20.3786410+2.63586
- 25+18.5606125+2.40071
- 50+17.3080650+2.23870
- 100+16.15273100+2.08927
- 250+15.67747250+2.02780
