BK-HBH-I-R
BK-HBH-I-R
    EATON(伊顿)
BK-HBH-I-R 数据手册
Effective September 2021 Supersedes October 2020 Technical Data 2118 HBH, HBV, HBW 1⁄4" x 1 1⁄4" and 5 mm x 20 mm fuse holders Agency information • CE, VDE 4009241 (HBV, HBW) SEMKO 800444 • UL Recognized: IZLT2, E14853 • CSA Certified: Class 6225-01, File 47235 Resistance ratings • Insulation resistance: 10,000 megaohm at 500 Vdc • Contact resistance: Less than 0.005 ohms at 200 mV Dielectric strength Product features • Dielectric strength: Over 200 V/mil For 1⁄4" x 1 1⁄4" and 5 x 20 mm fuses Fuse carriers are interchangeable Vertical and horizontal body mounting versions Fuse carrier and knob are spring loaded bayonet type with screwdriver slot • “Kicked” terminals (all models) for optimum wave-soldering • Stabilizer pins on HBV model • High dielectric molded thermoplastic meets UL 94V0 • • • • Part number HBH-I HBH-M HBV-I HBV-M HBW-I HBW-M HBH Fuse holder Body Mount Horizontal Horizontal Vertical w/ stability pins Vertical w/ stability pins Vertical w/o stability pins Vertical w/o stability pins Horizontal General specifications • Operating Temperature: (-40 ºC to + 85 ºC ) • Temperature rating (RTI): The mounting body for all devices has a temperature rating of 150 °C. The knob for all devices has a temperature rating of +130 °C. Ordering • Specify packaging, product, and option code Specifications Carrier Size 1 ⁄4" x 1 1⁄4" 5 x 20 mm 1 ⁄4" x 1 1⁄4" 5 x 20 mm 1 ⁄4" x 1 1⁄4" 5 x 20 mm na Voltage rating Volts 250 250 250 250 250 250 250 Current Rating (A), Agency approval UL CSA VDE SEMKO 16 12 – 10 16 12 – 10 16 12 6.3 10 16 12 6.3 10 16 12 6.3 10 16 12 6.3 10 16 12 – 10 HBH, HBV, HBW 1⁄4" x 1 1⁄4" and 5 mm x 20 mm fuse holders Technical Data 2118 Effective September 2021 0.615" min (15.62mm) min 0.46" (1.17mm) Packaging Code Prefix Blank BK Option Code Suffix -R Packaging Code Description 10 fuse holders packed into a carton 100 fuse holders packed into a cardboard shelf package Option Code Description RoHS compliant version Life Support Policy: Eaton does not authorize the use of any of its products for use in life support devices or systems without the express written approval of an officer of the Company. Life support systems are devices which support or sustain life, and whose failure to perform, when properly used in accordance with instructions for use provided in the labeling, can be reasonably expected to result in significant injury to the user. Eaton reserves the right, without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Eaton also reserves the right to change or update, without notice, any technical information contained in this bulletin. Eaton Electronics Division 1000 Eaton Boulevard Cleveland, OH 44122 United States Eaton.com/electronics © 2021 Eaton All Rights Reserved Printed in USA Publication No. 2118 September 2021 Eaton is a registered trademark. All other trademarks are property of their respective owners. Follow us on social media to get the latest product and support information.
BK-HBH-I-R 价格&库存
很抱歉,暂时无法提供与“BK-HBH-I-R”相匹配的价格&库存,您可以联系我们找货
