RS1AA THRU RS1MA
1.0A Surface Mount Fast
Recovery Rectifiers-50-1000V
Package outline
Features
The plastic package carries Underwriters Laboratory
Flammability Classification 94V-0
For surface mounted applications
Fast switching for high efficiency
Low reverse leakage
Built-in strain relief,ideal for automated placement
High forward surge current capability
High temperature soldering guaranteed:
250 C/10 seconds at terminals
Glass passivated chip junction
Compliant to RoHS Directive 2011/65/EU
SMA
0.108(2.75)
0.096(2.45)
0.067 (1.70)
0.051 (1.30)
0.177(4.50)
0.157(3.99)
0.012(0.305)
0.006(0.152)
0.096(2.42)
0.078(1.98)
Mechanical data
0.060(1.52)
0.030(0.76)
Case: JEDEC DO-214AC molded plastic body
Terminals: Solder plated, solderable per MIL-STD-750,
Method 2026
Polarity: Color band denotes cathode end
Mounting Position: Any
0.208(5.28)
0.188(4.80)
Dimensions in inches and (millimeters)
Maximum ratings and Electrical Characteristics (AT
PARAMETER
0.008(0.203)MAX.
T A=25 oC unless otherwise noted)
CONDITIONS
Symbol
MIN.
TYP.
MAX.
UNIT
Forward rectified current
See Fig.2
IO
1.0
A
Forward surge current
8.3ms single half sine-wave (JEDEC methode)
I FSM
30
A
V R = V RRM T A = 25 OC
Reverse current
Thermal resistance
Junction to ambient
NOTE 1
Diode junction capacitance
f=1MHz and applied 4V DC reverse voltage
*1
V RRM
(V)
V RMS*2
(V)
*3
VR
(V)
RS1AA
50
35
50
RS1BA
100
70
100
RS1DA
200
140
200
RS1GA
400
280
400
RS1JA
600
420
600
RS1KA
800
560
800
RS1MA
1000
700
1000
*4
VF
(V)
*5
t rr
(ns)
Operating
temperature
T J, ( OC)
O
75
CJ
T STG
μA
50
R θJA
Storage temperature
SYMBOLS
5.0
IR
V R = V RRM T A = 100 OC
pF
15
-55
C/W
O
+150
C
*1 Repetitive peak reverse voltage
*2 RMS voltage
150
*3 Continuous reverse voltage
1.30
-55 to +150
*4 Maximum forward voltage@I F=1.0A
250
*5 Maximum Reverse recovery time, note 2
500
Note: 1.P.C.B. mounted with 2.0x2.0”(5.0x5.0cm) copper pad areas
2. Reverse recovery time test condition, I F =0.5A, I R =1.0A, I RR =0.25A
www.fuxinsemi.com
Page 1
Ver2.1
RS1AA THRU RS1MA
Rating and characteristic curves
AVERAGE FORWARD RECTIFIED CURRENT,
AMPERES
FIG. 1- FORWARD CURRENT DERATING CURVE
0.8
0.6
Single Phase
Half Wave 60Hz
Resistive or
inductive Load
0.4
0.2
50
30
£PEAK FORWARD SURGE CURRENT,
AMPERES
1.0
FIG. 2-MAXIMUM NON-REPETITIVE PEAK FORWARD
SURGE CURRENT
75
100
125
150
25
10
175
5.0
8.3ms SINGLE HALF SINE-WAVE
(JEDEC Method)
1
10
LEAD TEMPERATURE, C
FIG. 3-TYPICAL INSTANTANEOUS FORWARD
CHARACTERISTICS
FIG. 4-TYPICAL REVERSE CHARACTERISTICS
1,000
10
1
TJ=25 C
PULSE WIDTH=300 ms
1%DUTY CYCLE
0.1
0.01
0.6
0.8
1.0
1.2
1.4
1.5
INSTANTANEOUS REVERSE CURRENT,
MICROAMPERES
CURRENT,AMPERES
10
TJ=100 C
1
0.1
TJ=25 C
0.01
INSTANTANEOUS FORWARD VOLEAGE,
VOLTS
60
80
100
FIG. 6-TYPICAL TRANSIENT THERMAL IMPEDANCE
TRANSIENT THERMAL IMPEDANCE,
C/W
FIG. 5-TYPICAL JUNCTION CAPACITANCE
TJ=25 C
100
PERCENT OF PEAK REVERSE VOLTAGE,%
200
JUNCTION CAPACITANCE, pF
100
NUMBER OF CYCLES AT 60 Hz
10
100
10
1
0.1
0.01
0.1
1
10
100
1
0.1
1.0
10
100
REVERSE VOLTAGE,VOLTS
www.fuxinsemi.com
t,PULSE DURATION,sec.
Page 2
Ver2.1
RS1AA THRU RS1MA
Pinning information
Pin
Pin1
Pin2
Simplified outline
cathode
anode
1
Symbol
2
1
2
Marking
Type number
Marking code
RS1AA
RS1BA
RS1DA
RS1GA
RS1JA
RS1KA
RS1MA
RS1A
RS1B
RS1D
RS1G
RS1J
RS1K
RS1M
Example
For Halogen D evice
RS1M
Marking code
Suggested solder pad layout
C
A
B
www.fuxinsemi.com
PACKAGE
A
B
C
SMA
0.110 (2.80)
0.063 (1.60)
0.087 (2.20)
Page 3
Ver2.1
RS1AA THRU RS1MA
Suggested thermal profiles for soldering processes
1.Storage environment: Temperature=5 oC ~40 oC Humidity=55%±25%
2.Reflow soldering of surface-mount devices
Critical Zone
TL to TP
Tp
TP
Ramp-up
TL
TL
Tsmax
Temperature
Tsmin
tS
Preheat
Ramp-down
25
o
t25 C to Peak
Time
3.Reflow soldering
Profile Feature
Soldering Condition
Average ramp-up rate(T L to T P )
o
很抱歉,暂时无法提供与“RS1MA”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.07744
- 200+0.06286
- 600+0.05476
- 5000+0.04742
- 10000+0.04320
- 20000+0.04083
- 国内价格
- 1+0.16830
- 500+0.05599
- 2500+0.03729
- 5000+0.03058
