TECHNICAL DATA SHEET
1/2
INSULATED BULKHEAD JACK RECEPTACLE
FR. MOUNT. WITH SOLDER POT CONTACT + TAG
R141.574.000
Series : BNC
All dimensions are in mm.
pn
ao
COMPONENTS
BODY
CENTER CONTACT
OUTER CONTACT
INSULATOR
GASKET
OTHERS PARTS
PLATING (µm)
MATERIALS
NORYL
BERYLLIUM COPPER
BRASS
NORYL
GOLD 0.2 OVER NICKEL 2
NICKEL 2
Issue : 0629 C
In the effort to improve our products, we reserve the right to make changes judged to be
necessary.
2/2
R141.574.000
Series : BNC
PACKAGING
Standard
100
Unit
‘W’ option
SPECIFICATION
Other
Contact us
ELECTRICAL CHARACTERISTICS
ENVIRONMENTAL
Impedance
Operating temperature -65/+165 ° C
50 Ω
Frequency
Hermetic seal
0-4 GHz
NA Atm.cm3/s
VSWR
1.06 + 0,0060 x F(GHz) Maxi Panel leakage
NA
Insertion loss
.025* √F(GHz) dB Maxi
RF leakage
57 - F(GHz)) dB Maxi
Voltage rating
500 Veff Maxi
Dielectric withstanding voltage
1500 Veff mini
Insulation resistance
5000 MΩ mini
OTHER CHARACTERISTICS
Assembly instruction
Others :
* Coaxial Transmission Line Only
MECHANICAL CHARACTERISTICS
Center contact retention
Axial force – Mating end
Axial force – Opposite end
Torque
Recommended torque
Mating
Panel nut
Mating life
Weight
18 N mini
18 N mini
0.03 N.cm mini
NA N.cm
80 N.cm
500 Cycles mini
10,0000 g
Issue : 0629 C
necessary.
很抱歉,暂时无法提供与“R141574000”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+153.11160
- 200+59.24880
- 500+57.17520
- 1000+56.13840
