BYV42E-200
BYV42E-200
    WEEN(瑞能)
    BYV42E-200
BYV42E-200 数据手册
DISCRETE SEMICONDUCTORS DATA SHEET BYV42E, BYV42EB series Rectifier diodes ultrafast, rugged Product specification September 2018 WeEn Semiconductors Product specification Rectifier diodes ultrafast, rugged FEATURES BYV42E, BYV42EB series SYMBOL • Low forward volt drop • Fast switching • Soft recovery characteristic • Reverse surge capability • High thermal cycling performance • Low thermal resistance QUICK REFERENCE DATA VR = 150 V/ 200 V 1 VF ≤ 0.85 V 3 IO(AV) = 30 A 2 sym084 IRRM = 0.2 A trr ≤ 28 ns GENERAL DESCRIPTION Dual, ultra-fast, epitaxial rectifier diodes intended for use as output rectifiers in high frequency switched mode power supplies. The BYV42E series is supplied in the SOT78 conventional leaded package. The BYV42EB series is supplied in the SOT404 surface mounting package. PINNING PIN SOT78 (TO220AB) DESCRIPTION 1 anode 1 (a) 2 cathode (k) 1 3 anode 2 (a) tab cathode (k) SOT404 tab tab 2 1 3 D2PAK (SOT404) 1 2 3 LIMITING VALUES Limiting values in accordance with the Absolute Maximum System (IEC 134). SYMBOL PARAMETER VRRM VRWM VR Peak repetitive reverse voltage Crest working reverse voltage Continuous reverse voltage IO(AV) Average rectified output current (both diodes conducting) Repetitive peak forward current per diode Non-repetitive peak forward current per diode CONDITIONS MIN. BYV42E / BYV42EB IFRM IFSM IRRM IRSM Tstg Tj Tmb ≤ 144˚C square wave δ = 0.5; Tmb ≤ 108 ˚C t = 25 µs; δ = 0.5; Tmb ≤ 108 ˚C t = 10 ms t = 8.3 ms sinusoidal; with reapplied VRWM(max) Repetitive peak reverse current tp = 2 µs; δ = 0.001 per diode Non-repetitive peak reverse tp = 100 µs current per diode Storage temperature Operating junction temperature - MAX. -150 150 150 150 UNIT -200 200 200 200 V V V - 30 A - 30 A - 150 160 A A - 0.2 A - 0.2 A -40 - 150 150 ˚C ˚C 1. It is not possible to make connection to pin 2 of the SOT404 package 2. SOT78 package, For output currents in excess of 20 A, the cathode connection should be made to the mounting tab. September 2018 1 Rev 1.400 WeEn Semiconductors Product specification Rectifier diodes ultrafast, rugged BYV42E, BYV42EB series ESD LIMITING VALUE SYMBOL PARAMETER CONDITIONS VC Electrostatic discharge capacitor voltage Human body model; C = 250 pF; R = 1.5 kΩ MIN. MAX. UNIT - 8 kV THERMAL RESISTANCES SYMBOL PARAMETER CONDITIONS Rth j-mb Thermal resistance junction to mounting base Thermal resistance junction to ambient per diode both diodes SOT78 package, in free air SOT404 and SOT428 packages, pcb mounted, minimum footprint, FR4 board Rth j-a MIN. TYP. MAX. UNIT - 60 50 2.4 1.4 - K/W K/W K/W K/W MIN. TYP. MAX. UNIT - 0.78 0.95 1.00 0.5 10 6 20 0.85 1.05 1.20 1 100 15 28 V V V mA µA nC ns - 13 1 22 - ns V ELECTRICAL CHARACTERISTICS characteristics are per diode at Tj = 25 ˚C unless otherwise stated SYMBOL PARAMETER CONDITIONS VF Forward voltage IR Reverse current Qs trr1 Reverse recovery charge Reverse recovery time trr2 Vfr Reverse recovery time Forward recovery voltage IF = 15 A; Tj = 150˚C IF = 15 A IF = 30 A VR = VRWM; Tj = 100 ˚C VR = VRWM IF = 2 A; VR ≥ 30 V; -dIF/dt = 20 A/µs IF = 1 A; VR ≥ 30 V; -dIF/dt = 100 A/µs IF = 0.5 A to IR = 1 A; Irec = 0.25 A IF = 1 A; dIF/dt = 10 A/µs September 2018 2 Rev 1.400 WeEn Semiconductors Product specification Rectifier diodes ultrafast, rugged I dI F BYV42E, BYV42EB series 0.5A F dt IF t 0A rr time Q I 10% s I rec = 0.25A IR 100% trr2 I R rrm I = 1A R Fig.1. Definition of trr1, Qs and Irrm I Fig.4. Definition of trr2 20 F PF / W Tmb(max) / C 102 D = 1.0 BYV42 Vo = 0.705 V Rs = 0.0097 Ohms 0.5 15 time 0.2 0.1 10 114 126 VF V tp I 5 D= tp T 138 fr t T VF 0 time Fig.2. Definition of Vfr 0 5 10 15 IF(AV) / A 20 150 25 Fig.5. Maximum forward dissipation PF = f(IF(AV)) per diode; square current waveform where IF(AV) =IF(RMS) x √D. R 15 PF / W Tmb(max) / C 114 a = 1.57 BYV42 Vo = 0.705 V Rs = 0.0097 Ohms 1.9 2.2 D.U.T. 2.8 10 Voltage Pulse Source 4 Current shunt 138 5 to ’scope 0 0 5 IF(AV) / A 10 150 15 Fig.6. Maximum forward dissipation PF = f(IF(AV)) per diode; sinusoidal current waveform where a = form factor = IF(RMS) / IF(AV). Fig.3. Circuit schematic for trr2 September 2018 126 3 Rev 1.400 WeEn Semiconductors Product specification Rectifier diodes ultrafast, rugged BYV42E, BYV42EB series trr / ns 100 Qs / nC 1000 IF=20A 10A 5A 2A 1A IF=20A 100 10 IF=1A 10 1 1 10 dIF/dt (A/us) 1.0 100 Fig.7. Maximum trr at Tj = 25 ˚C; per diode 10 -dIF/dt (A/us) 100 Fig.10. Maximum Qs at Tj = 25 ˚C; per diode Irrm / A 10 1.0 10 Transient thermal impedance, Zth j-mb (K/W) IF=20A 1 1 IF=1A 0.1 0.1 PD 0.01 0.001 1us 0.01 10 -dIF/dt (A/us) 1 100 Fig.8. Maximum Irrm at Tj = 25 ˚C; per diode 50 tp D= T 10us tp T t 100us 1ms 10ms 100ms 1s pulse width, tp (s) BYV42E 10s Fig.11. Transient thermal impedance; per diode; Zth j-mb = f(tp). IF / A Tj = 150 C 40 Tj = 25 C 30 20 typ 10 max 0 0 0.5 VF / V 1.0 1.5 Fig.9. Typical and maximum forward characteristic IF = f(VF); parameter Tj September 2018 4 Rev 1.400 WeEn Semiconductors Product specification Rectifier diodes ultrafast, rugged BYV42E, BYV42EB series MECHANICAL DATA Plastic single-ended package; heatsink mounted; 1 mounting hole; 3-lead TO-220AB SOT78 E A A1 p q mounting base D1 D L1(1) L2(1) Q L b1(2) (3×) b2(2) (2×) 1 2 3 c b(3×) e e 0 5 10 mm scale DIMENSIONS (mm are the original dimensions) UNIT A A1 b b1(2) b2(2) c D D1 E e L L1(1) L2(1) max. p q Q mm 4.7 4.1 1.40 1.25 0.9 0.6 1.6 1.0 1.3 1.0 0.7 0.4 16.0 15.2 6.6 5.9 10.3 9.7 2.54 15.0 12.8 3.30 2.79 3.0 3.8 3.5 3.0 2.7 2.6 2.2 Notes 1. Lead shoulder designs may vary. 2. Dimension includes excess dambar. OUTLINE VERSION SOT78 September 2018 REFERENCES IEC JEDEC JEITA 3-lead TO-220AB SC-46 5 EUROPEAN PROJECTION ISSUE DATE 08-04-23 08-06-13 Rev 1.400 WeEn Semiconductors Product specification Rectifier diodes ultrafast, rugged BYV42E, BYV42EB series MECHANICAL DATA September 2018 6 Rev 1.400 WeEn Semiconductors Legal information Data sheet status Document status [1][2] Product status [3] Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Definition Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.ween-semi.com. Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. WeEn Semiconductors does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local WeEn Semiconductors sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between WeEn Semiconductors and its customer, unless WeEn Semiconductors and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the WeEn Semiconductors product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, WeEn Semiconductors does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. WeEn Semiconductors takes no responsibility for the content in this document if provided by an information source outside of WeEn Semiconductors. In no event shall WeEn Semiconductors be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges whether or not such damages are based on tort (including negligence, warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, WeEn Semiconductors’ aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of WeEn Semiconductors. Right to make changes — WeEn Semiconductors reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — WeEn Semiconductors products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an WeEn Semiconductors product can reasonably be expected to result in personal injury, death or severe property or environmental damage. WeEn Semiconductors and its suppliers accept no liability for inclusion and/or use of WeEn Semiconductors products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Applications — Applications that are described herein for any of these products are for illustrative purposes only. WeEn Semiconductors makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using WeEn Semiconductors products, and WeEn Semiconductors accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the WeEn Semiconductors product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. WeEn Semiconductors does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using WeEn Semiconductors products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). WeEn does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific WeEn Semiconductors product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. WeEn Semiconductors accepts no liability for inclusion and/or use of nonautomotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without WeEn Semiconductors’ warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond WeEn Semiconductors’ specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies WeEn Semiconductors for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond WeEn Semiconductors’ standard warranty and WeEn Semiconductors’ product specifications. WeEn Semiconductors Translations — A non-English (translated version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners.
BYV42E-200 价格&库存
很抱歉,暂时无法提供与“BYV42E-200”相匹配的价格&库存,您可以联系我们找货
