5.50
3.04
H
8.94
4x 1.80
0.13
3.58
B12 B9 A5 B5 A9 A12
2x 1.50
2.85
2x 0.95±0.10
2x 1.10±0.10
2x 0.70
2x 0.80
2x 0.76
1.20
2x 1.35
2x 3.58±0.15
G
Pin
Signal
Mating
Sequence
A5
CC1
Second
A9
VBUS
First
A12
GND
First
B5
CC2
Second
B9
VBUS
First
B12
GND
First
SHELL
10.25
Specifications
Material
Insulator: LCP, UL 94V-0, Black
Contact: Copper Alloy
Shell: Stainless Steel
Middle Plate: Stainless Steel
GND
Plating
Contact: Gold Flash All Over
Shell: 50µ" min. Nickel
Middle Plate: Clear
Recommended PCB Layout
+0.045
-0.055
6.69
A9
A12
Component Outline
Electrical
Current Rating:
6.90±0.15
3.00A collectively for VBUS pins
4.25A collectively for GND pins
1.25A for B5 pin
0.25A for A5 pin
Voltage Rating: 20V DC
Contact Resistance: 40mΩ max initial.
50mΩ max after test
Dielectric Withstanding Voltage: 100V AC
Insulation Resistance 100MΩ min
3.22
3.16
1.68
A5
Solder Area
3.25
E
2.56±0.04
Tolerance: ±0.05mm
8.34+0.06
-0.02
1.20±0.05
F
1.00
0.1
D
B12
B9
B5
11.14
6.65
1.85
Mechanical & Environmental
Operating Temperature: -30°C to +85°C
Mating Force: 5 to 20 N.
Unmated Force: 6 to 20 N after test
Durability: 20,000 cycles
Plug
5.60
6.78
C
Ordering Grid
USB4135
B
2x 0.56±0.05
2x 0.60±0.05
Packing Options
A = Tape & Reel
Part Number
Product Description
USB4135
Type C Receptacle, Horizontal, SMT,
For Power Charging Only
Drawing Date
21st January 2022
By
2
Request Samples
and Quotation
(1200 per reel)
Detail
1
A
Contact Plating
GF = Gold Flash
Plug and Receptacle Mating View
2x 0.50±0.05
2x 1.00±0.10
2x 3.04±0.10
2x 5.50±0.10
A
GF
3
4
Revision
Date
5
CC
Drawing
Release
A1
22/11/22
Tolerances (Except as Noted)
Length
Angle
X.X ± 0.30
X.XX ± 0.25
X.XXX ± 0.10
Units:
Metric (mm)
C
3rd Angle Projection
6
7
This drawing is confidential and
copyright of Global Connector
Technology, Ltd (GCT).
This drawing must not be copied
or disclosed without written
consent. E & OE
www.gct.co
Not to
Scale
Drawn By
CC
8
Sheet No.
1/2
Folder Paper Board
H
Unloaded Section
1200 PCS
Unloaded Section
(20 Pockets)
(20 Pockets)
Paper Board
G
Detail E
Direction of Unreeling
F
Peeling
Angle
165°~180°
Vacuum Bag
Reel and Tape
E
Ø330
Carton
D
3
295
Ø1
Label
Paper Board
W+0.5
34
C
4.00±0.10
2.00±0.10
0.0
50 Ø1.
Pcs /
Reel
1200
1.75±0.10
24.00±0.30
B
Product Description
USB4135
21st January 2022
By
Detail: E
1
2
Detail
3
4
Total
Quantity
10800 pcs
Part Number
Drawing Date
12.00±0.10
A
Reels /
Carton
9
Revision
Date
5
CC
Drawing
Release
A1
22/11/22
Length
Angle
X.X ± 0.30
X.XX ± 0.25
X.XXX ± 0.10
Units:
Metric (mm)
C
6
7
consent. E & OE
www.gct.co
Not to
Scale
Drawn By
CC
8
Sheet No.
2/2
很抱歉,暂时无法提供与“USB4135-GF-A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1200+3.655061200+0.47515
- 2400+3.480572400+0.45247
- 3600+3.382403600+0.43970
- 6000+3.262706000+0.42414
- 8400+3.186188400+0.41420
- 12000+3.1070612000+0.40391
- 国内价格 香港价格
- 1+5.996601+0.77954
- 10+5.1269910+0.66649
- 25+4.8036825+0.62447
- 50+4.5759850+0.59487
- 100+4.35628100+0.56631
- 250+4.08324250+0.53081
- 500+3.88806500+0.50544
