2.00
2.00 Ref.
15.0
4-Ø0.92
Insulator: UL94V-0 Rated
Thermoplastic PBT
Color- White or Black
14.50 Ref.
13.30 Ref.
2.71
7.62 Ref.
Contacts: Copper Alloy
7.00 Ref.
15.65±0.25
Plating Options:
Standard-Gold Flash
on Contact Area, Tin
on Solder Tail, all over
Nickel
2-Ø2.30
-30 Option- 30u" Gold
Nickel
7.00
0.58
13.14
15.00 Ref.
2.50 Ref.
Recommended PCB Layout
Shell: Copper Alloy
Tin Plated
Electrical Specifications
Contact Current Rating:
1A Max.
12.5
7.0
Contact Resistance:
30 milliohms Max.
Insulation Resistance:
1000 Megohms Min.
5.1
5.92
7.12 Ref.
2.8
5.92 Ref.
0.25
2.7 Ref.
Rated Voltage:
30V AC (rms)
Dielectric Withstanding:
750V AC
1
Mechanical Specifications
3.91Ref
Insertion Force:
3.57kg max.
2.00
1.465 Ref.
KYCON, Inc. 305 Digital Drive, Morgan Hill, CA 95037 (408)494-0330
Materials and Finish
2.50
Extraction Force:
1.02kg min.
Part Number
Plating
Color
KUSBVX-AS1N-W
Flash
White
KUSBVX-AS1N-W30
30u"
White
KUSBVX-AS1N-B
Flash
Black
KUSBVX-AS1N-B30
30u"
Black
Operating Temperature:
-55°C to 85°C
Durability:
1500 mating cycles min.
Tolerances
R
R
RoHS COMPLIANT
E134345
REV.
DATE
DESCRIPTION
REV. BY
CHK. BY
DRAWN BY
DATE
A2
A3
A4
A5
A6
A7
9/28/05
04/24/06
06/20/07
08/25/11
05/08/13
08/17/18
ECO #05-043
ECO #06-014
ECO #07-022
ECO #11-058
ECO #13-020
Address Update
R. Aguirre
R. Aguirre
A. Frederick
S. Vien
W. Cook
G. Serrato
H. MA
H. MA
H. MA
H. MA
P. DalCanto
D. Shehan
H. MA
3/9/05
UNITS
mm
KUSBVX-AS1N-xxx
USB A-type Receptacle, Single, Vertical,
Through Hole, RoHS Compliant
C
US
LR78160
X.X ± 0.35
X.XX ± 0.25
Unless Stated
Otherwise
很抱歉,暂时无法提供与“KUSBVX-AS1N-B30”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+8.654001+1.11838
- 10+7.3601710+0.95117
- 25+6.9022625+0.89200
- 50+6.5702050+0.84908
- 120+6.17612120+0.79816
- 360+5.71518360+0.73859
- 600+5.51268600+0.71242
- 1080+5.288691080+0.68347
- 2520+4.981792520+0.64381
