MFBM1V1005-101-R
MFBM1V1005-101-R
    EATON(伊顿)
    单路 0402磁珠 阻抗100Ω@100MHZ
MFBM1V1005-101-R 数据手册
Technical Data 11110 Effective June 2020 MFBM1V1005 Multilayer chip ferrite bead Applications • Industrial connectivity (IoT) • Wireless communications • Bluetooth • WiFi • Antenna • Machine-to-machine (M2M) • Mobile phones Product features • Wearable devices • 0402 (1005 metric) package • Wireless LAN • High current handling • Computing/gaming consoles • Multilayer monolithic construction yields high reliability • Broadband components • Impedance range from 0 Ω to 1000 Ω • RF transceiver modules Environmental compliance and general specifications • Operating temperature range: -40 °C to +85 °C (ambient plus self-temperature rise) HALOGEN Pb HF FREE MFBM1V1005 Multilayer chip ferrite bead  Technical Data 11110 Effective June 2020 Product specifications Impedance tolerance Part number3 Impedance (Ω) DCR (Ω) maximum @ +25 °C Test frequency1 (MHz) Test voltage1 (mV) Rated I2 (mA) maximum MFBM1V1005-000-R 0~15 Ω 0 0.05 100 50 1800 MFBM1V1005-050-R 0~15 Ω 5 0.05 100 50 1800 MFBM1V1005-070-R 0~11 Ω 7 0.05 100 50 1800 MFBM1V1005-090-R 5~13 Ω 9 0.05 100 50 1800 MFBM1V1005-110-R 7~15 Ω 11 0.05 100 50 1800 MFBM1V1005-150-R 9~21 Ω 15 0.05 100 50 1800 MFBM1V1005-190-R 12~25 Ω 19 0.06 100 50 1500 MFBM1V1005-300-R ±25% 30 0.08 100 50 1300 MFBM1V1005-600-R ±25% 60 0.10 100 50 1000 MFBM1V1005-700-R ±25% 70 0.15 100 50 800 MFBM1V1005-800-R ±25% 80 0.15 100 50 800 MFBM1V1005-101-R ±25% 100 0.15 100 50 800 MFBM1V1005-121-R ±25% 120 0.15 100 50 800 MFBM1V1005-151-R ±25% 150 0.20 100 50 700 MFBM1V1005-201-R ±25% 200 0.25 100 50 700 MFBM1V1005-221-R ±25% 220 0.30 100 50 600 MFBM1V1005-301-R ±25% 300 0.30 100 50 600 MFBM1V1005-501-R ±25% 500 0.40 100 50 500 MFBM1V1005-601-R ±25% 600 0.50 100 50 500 MFBM1V1005-801-R ±25% 800 0.65 100 50 300 MFBM1V1005-102-R ±25% 1000 0.65 100 50 300 1. Impedance test frequency and voltage. 2. Rated I: Current rating for an approximate self-temperature rise of 40 °C or less. 3. Part number definition: MFBM1V1005-xxx-R MFBM1V1005 = Product code and size xxx = Impedance value in Ω, last character equals number of zeros -R suffix = RoHS compliant Mechanical parameters, schematic, pad layout (mm) Recommended pad layout Schematic a (2plcs) Part number L W T a F G H MFBM1V1005-xxx-R 1.0 ±0.15 0.50 ±0.15 0.50 ±0.15 0.25 ±0.10 0.90 ref 0.20 ref 0.80 ref Part marking: No marking All soldering surfaces to be coplanar within 0.1 millimeters Tolerances are ±0.1 millimeters unless stated otherwise Pad layout dimensions are reference only Traces or vias underneath the inductor is not recommended 2 www.eaton.com/electronics Technical Data 11110 MFBM1V1005  Multilayer chip ferrite bead Effective June 2020  Packaging information (mm) Drawing not to scale Supplied in tape and reel packaging, 10000 parts per 7” diameter reel W±0.2 8.00 F±0.1 3.50 E1±0.2 1.75 E2 Min na P0±0.2 4.00 P1±0.2 2.00 P2±0.1 2.00 D0±0.1 1.55 A0 0.65±0.1 B0 1.15±0.1 T 0.60±0.1 T1 Max na www.eaton.com/electronics 3 MFBM1V1005 Multilayer chip ferrite bead  Technical Data 11110 Effective June 2020 Qualification testing No. Test item Sample size (pcs) Test condition Acceptable value/range 1 External visual 72 Specification No physical damage 2 Physical dimension 72 Specification Specification 3 Initial electrical test 72 Specification User specification 4 Solderability 6 +245 °C ±5 °C, dipping 5 ±1s >95% solder coverage 5 Resistance to soldering heat 6 +260 ±5 °C for 10 ±1 s 1. ΔZ/Z
MFBM1V1005-101-R 价格&库存
很抱歉,暂时无法提供与“MFBM1V1005-101-R”相匹配的价格&库存,您可以联系我们找货
MFBM1V1005-101-R
    • 20000+0.04634
    MFBM1V1005-101-R
    • 20000+0.03990
    库存:30000
    MFBM1V1005-101-R
    库存:30000
