SST-20-B-B120-S450
SST-20-B-B120-S450
    LUMINUS(朗明纳斯)
    SMD3535
    发光二极管/LED SMD3535
SST-20-B-B120-S450 数据手册
SST-20-Blue Product Datasheet SST-20-B Blue LED Features: Table of Contents SST-20 Binning Structure. . . 2 Part Numbering and Bin Kit Information. . . . . . . . . . . . . . . . 3 • High Power Blue LED with Peak Wavelength of 450nm • Typical Wall-Plug Efficiency of 72% at 350 mA • Maximum drive current: 3 A • Available with 2 industry standard soldering footprint configurations • High thermal conductivity package - junction thermal resistance of only 3.5°C/W Optical and Electrical Characteristics. . . . . . . . . . . . . 4 • Available with 120° viewing angle A120 - Mech. Dimensions. . . 6 • Electrically isolated thermal path B120 - Mech. Dimensions. . . 7 • RoHS and REACh compliant • 8000V HBM ESD rating per MIL STD-883D A120/B120 - Tape and Reel. . 8 Reel Packaging. . . . . . . . . . . . . 9 Box Packaging Info. . . . . . . . 10 Soldering Profile. . . . . . . . . . 11 Precautions for Use. . . . . . . . 12 Applications • Horticulture / Growlights • Remote-phosphor fixtures • Accent and effect lighting • Stage lighting • Architectural lighting History of Changes. . . . . . . . 13 1 PDS-002955 Rev 02 © 2018 Luminus Devices, Inc. - All Rights Reserved Luminus Devices, Inc. • T 408.708.7000 • www.luminus.com 1145 Sonora Court • Sunnyvale, CA 94086 SST-20-Blue Product Datasheet SST-20 Binning Structure SST-20 Blue LEDs are tested for luminous flux and chromaticity at a drive current of 350mA - 20ms single pulse and placed into one of the following luminous flux (FF) and chromaticity (WW) bins: Flux Bins - Test condition=350mA, 250C, 20ms pulse Flux Bin (FF) Minimum Flux (mW) Maximum Flux (mW) R 630 670 S 670 710 T 710 750 U 750 790 V 790 830 Wavelength Bins - Test condition=350mA, 250C, 20ms pulse *Note: Chromaticity Bin (WW) Minimum Wavelength (nm) Maximum Wavelength (nm) B2 440 445 B3 445 450 B4 450 455 B5 455 460 Luminus maintains a +/- 6% tolerance on flux measurements. Ordering Information Products Ordering Part Number Description SST-20-B-A120 SST-20-B-A120-xx123 High Power 2-mm2 Blue LED in a 3535 surface mount package and a 120-degree viewing angle - Type A soldering pad configuration SST-20-B-B120 SST-20-B-B120-xx123 High Power 2-mm2 Blue LED in a 3535 surface mount package and a 120-degree viewing angle - Type B soldering pad configuration 2 PDS-002955 Rev 02 © 2018 Luminus Devices, Inc. - All Rights Reserved Luminus Devices, Inc. • T 408.708.7000 • www.luminus.com 1145 Sonora Court • Sunnyvale, CA 94086 SST-20-Blue Product Datasheet Part Number Nomenclature SST Product Family 20 LED Emission Area Color Package Configuration Bin kit 20: 2.0 mm2 : Color B = Blue P: Soldering pad configuration A type - see page 6 B type - see page 7 AA(A): Viewing angle 120° See Tables F =minimum flux bin CCC: Chromaticity bin kit SST: Surface Mount Package SST-20 Bin Kit Order Codes The following table describes the bin kit ordering codes available for the SST-20 Blue LEDs. Each bin kit specifies a minimum flux as well as specific chromaticity bins allowed. Please note that within each kit a maximum flux is not specified and as a result Luminus may ship any part meeting or exceeding the minimum flux specification. Shipments will always meet the listed chromaticity bins. For information on ordering bin kits not listed below, please contact Luminus. SST-20 Blue Bin Kit Order Codes Luminous Flux Color Chromaticity Bins Kit Number 630 B2,B3,B4,B5 R450 S 670 B2,B3,B4,B5 S450 T 710 B2,B3,B4,B5 T450 Bin Kit Flux Code Min. Flux R Blue Product Shipping & Labeling Information All SST-20 products are packaged and labeled with their respective bin as outlined in the tables on pages 2 & 3. Each reel will only contain one bin. SST-20 Blue SST 20 B P120 FCCC Product Family LED Emission Area Color Package Configuration Bin kit SST: Surface Mount Package 20: 2.0 mm2 Color P: Soldering pad configuration A type - see page 6 B type - see page 7 Flux and Chromaticity bin kit code as outlined above 3 PDS-002955 Rev 02 © 2018 Luminus Devices, Inc. - All Rights Reserved Luminus Devices, Inc. • T 408.708.7000 • www.luminus.com 1145 Sonora Court • Sunnyvale, CA 94086 SST-20-Blue Product Datasheet (Part #) Product Datasheet Optical and Electrical Characteristics1-3 Optical and Electrical Characteristics at 350mA1 Parameter Symbol Minimum Typical Maximum Unit Forward Current at test2 If 350 mA Output Radiometric Power Φr 710 mW Forward Voltage Vf Wall-Plug Efficiency 2.5 2.80 WPE 72 Photosynthetic Photon Flux (PPF)4 mmol/s 2.68 PPF Efficacy (PPF/W) mmol/J 2.73 2 Ø1/2 120 Viewing Angle (A120 / B120) Peak Wavelength 3.2 V % degrees λP 440 450 460 nm Dλ1/2 20 22 24 nm Ifmin, Ifmax 0.2 3 A If-smax 4 A Maximum Reverse Current3 Irev N.A. LED Junction Temperature Tj 150 FWHM Forward Current (CW)2 Maximum Surge Current C 0 ESD withstand Voltage HBM Per JEDEC/ESDA STANDARD JS-001 VHBM 8000 V ESD withstand Voltage CDM Per JEDEC/ESDA STANDARD JS-002 VCDM 1000 V Operating Temperature TOPR -40 80 Storage Temperature TSTG -40 100 Thermal resistance junction to case (electrical) RΘjc-el 3.5 0C C 0 °C/W Note 1: Ratings are based on operation at a constant junction temperature of Tj = 25ºC. Note 2: Sustained operation at maximum current will result in shortened lifetime. Note 3: Not designed for reverse voltage operation. Note 4: Values at 350mA, Tj=25C and computed in the 400nm to 700nm range. 4 PDS-002955 Rev 02 © 2018 Luminus Devices, Inc. - All Rights Reserved Luminus Devices, Inc. • T 408.708.7000 • www.luminus.com 1145 Sonora Court • Sunnyvale, CA 94086 SST-20-Blue Product Datasheet (Part #) Product Datasheet Optical and Electrical Characteristics Relative Output Flux vs. Forward Current Forward Voltage vs. Forward Current Relative Output Flux vs. Junction Temperature Typical Spectra Typical Angular Pattern of Radiant Power - Types A120 and B1204 Note 4: Angular pattern measurements were made at 350mA, 250C. 5 PDS-002955 Rev 02 © 2018 Luminus Devices, Inc. - All Rights Reserved Luminus Devices, Inc. • T 408.708.7000 • www.luminus.com 1145 Sonora Court • Sunnyvale, CA 94086 SST-20-Blue Product Datasheet 8 6 7 D Mechanical Dimensions5 5 4 2 3 A120 Package Configuration 1 D 1.98 3.45 3.25 0.53 OPTICAL REFERENCE 0.50 C 3.45 3.25 C 2.30 1.30 0.48 R1.30 OPTICAL REFERENCE B B SIDE VIEW FRONT VIEW BACK VIEW Recommended PCB Solder Pad and Stencil Pattern5 8 5 6 7 4 2 3 A120 Package Configuration This document and its contents are confidential information of Luminus Devices, Inc. Copyright 2005 Luminus Device,Inc. All rights reserved. A D 1 1145 SONORA COURT SUNNYVALE, CA 94086 408-708-7000 PROPRIETARY AND CONFIDENTIAL DESCRIPTION: DIMENSIONS ARE IN (UNLESS OTHERWISE SPECIFIED): SIZE: ALL MEASUREMENTS ARE 0.13mm UNLESS OTHERWISE SPECIFIED A DRAWING,OUTLINE,SST-20-W-A130 B MILLIMETERS [INCHES] 3.25 DRAFTER: SCALE: NUMBER: ENGINEER: D REV: SHEET: A 25:1 X.XIE 6 7 8 4 5 2 3 1 0.50 C 3.25 0.58 1.30 3.25 2.30 1.15 C 0.48 0.48 0.25 3.25 B Note 5: 0.75 Recommended PCB Solder Pad 1145 SONORA COURT SUNNYVALE, CA 94086 408-708-7000 PROPRIETARY AND CONFIDENTIAL Dimensions are in millimeters +/- 0.13 mm This document and its contents are confidential information of Luminus Devices, Inc. Copyright 2005 Luminus Device,Inc. All rights reserved. A DESCRIPTION: DIMENSIONS ARE IN (UNLESS OTHERWISE SPECIFIED): SIZE: © 2018 Luminus Devices, Inc. - All Rights Reserved ALL MEASUREMENTS ARE 0.13mm UNLESS OTHERWISE SPECIFIED REV: SHEET: SCALE: DRAFTER: NUMBER: ENGINEER: X.XIE 8 7 6 A DRAWING,OUTLINE,SST-20-W-PAD A Luminus Devices, Inc. • T 408.708.7000 • www.luminus.com MILLIMETERS 1145 Sonora Court[INCHES] • Sunnyvale, CA 25:1 94086 A B 6 PDS-002955 Rev 02 B Recommended Stencil Pattern 5 4 3 2 1 SST-20-Blue Product Datasheet 8 6 7 Mechanical Dimensions6 5 4 D 2 3 B120 Package Configuration 1 D 1.98 3.45 0.53 OPTICAL REFERENCE 0.35 C C 3.45 2.70 1.70 1.00 0.50 R1.30 0.43 OPTICAL REFERENCE B SIDE VIEW FRONT VIEW 8 2.70 5 6 7 BACK VIEW 4 2 3 Recommended PCB Solder Pad and Stencil Pattern6 1145 SONORA COURT SUNNYVALE, CA 94086 408-708-7000 PROPRIETARY AND CONFIDENTIAL B120 Package Configuration This document and its contents are confidential information of Luminus Devices, Inc. Copyright 2005 Luminus Device,Inc. All rights reserved. A B 2.70 DESCRIPTION: 2.70 DIMENSIONS ARE IN (UNLESS OTHERWISE SPECIFIED): SIZE: ALL MEASUREMENTS ARE 0.13mm UNLESS OTHERWISE SPECIFIED A DRAWING,OUTLINE,SST-20-W-B130 MILLIMETERS [INCHES] DRAFTER: B SCALE: NUMBER: ENGINEER: REV: SHEET: A 25:1 X.XIE 7 8 6 5 4 2 3 0.40 0.35 2.70 2.70 1 1.70 0.90 0.50 0.50 0.25 0.55 Recommended PCB Solder Pad Note 6: Recommended Stencil Pattern Dimensions are in millimeters +/- 0.13 mm 7 PDS-002955 Rev 02 © 2018 Luminus Devices, Inc. - All Rights Reserved LuminusPROPRIETARY Devices, AND Inc. • T 408.708.7000 • www.luminus.com 1145 SONORA CONFIDENTIAL C 1145 Sonora Court • Sunnyvale, CASUNNYVALE, 94086 This document and its contents are confidential information of Luminus Devices, Inc. Copyright 2005 Luminus Device,Inc. All rights reserved. DESCRIPTION: 408-708-7 DRAWING,OUTLINE,SST-20-W PAD SST-20-Blue Product Datasheet Tape and Reel - A120 and B120 Package Configurations7,8  “  “  “  “          “  “ $ &$7+2'(6,'( %                    %  “  “  “  “ “ “  “  “                     815((/,1*',5(&7,21 $12'(6,'( “ $           ƒ 6(&7,21%% ƒ 6(&7,21$$ 127(6   ),1$/7$3($1'5((/3$&.$*,1*08670((77+( 5(48,5(0(1762)-('(&67'/(9(/$       /($9(PP>LQ@2)7$3((037
SST-20-B-B120-S450 价格&库存
很抱歉,暂时无法提供与“SST-20-B-B120-S450”相匹配的价格&库存,您可以联系我们找货
SST-20-B-B120-S450
  • 1+15.881441+2.06454
  • 10+11.3431210+1.47457
  • 100+8.59880100+1.11782
  • 500+7.38580500+0.96013
库存:1070
SST-20-B-B120-S450
  • 1000+7.939891000+1.03216
  • 2000+7.558552000+0.98259
  • 3000+7.363233000+0.95720
  • 5000+7.142755000+0.92854
  • 7000+7.011707000+0.91150
  • 10000+6.8839610000+0.89490
库存:1070
SST-20-B-B120-S450
    SST-20-B-B120-S450
      SST-20-B-B120-S450
        • 1+15.73560
        • 200+6.28560
        • 500+6.06960
        • 1000+5.96160
