NJM4556A
DUAL HIGH CURRENT OPERATIONAL AMPLIFIER
■ GENERAL DESCRIPTION
The NJM4556A integrated circuit is a high-gain,high output
current dual operational amplifier capable of driving ±70mA into
150Ω loads ( ±10.5V output voltage ),and operating low supply
voltage ( V+/V-=±2V~ ).
The NJM4556A combines many of the features of the
popular NJM4558 as well as having the capability of driving
150Ω loads.In addition,the wide band-width,low noise,high slew
rate and low distortion of the NJM4556A make it ideal for many
audio,telecommunications and instrumentation applications.
■ FEATURES
● Supply Voltage
● High Output Current
● Slew Rate
● Gain Band Width Product
● Equivalent Input Noise Voltage
● Package Outline
● Bipolar Technology
( ±2V~±18V )
( IO=70mA )
( 3V/μs typ. )
( 8MHz typ. )
( 10nV/√Hz typ. )
DIP8,DMP8,SIP8,SSOP8
■ PACKAGE OUTLINE
NJM4556AD
NJM4556AM
NJM4556AV
NJM4556AL
■ PIN CONFIGURATION
NJM4556AD
NJM4556AM
NJM4556AV
NJM4556AL
PIN FUNCTION
1.A OUTPUT
2.A –INPUT
3.A +INPUT
4.V
5.B +INPUT
6.B –INPUT
7.B OUTPUT
8.V
■ EQUIVALENT CIRCUIT ( 1/2 Shown )
Ver.2020-03-26
-1-
NJM4556A
■ ABSOLUTE MAXIMUM RATINGS
( Ta=25˚C )
PARAMETER
Supply Voltage
Differential Input Voltage
Input Voltage
SYMBOL
+ V /V
VID
VIC
Power Dissipation
PD
Operating Temperature Range
Storage Temperature Range
Topr
Tstg
RATINGS
± 18
± 30
± 15 ( note )
( DIP8 ) 700
( DMP8 ) 300
( SSOP8 ) 250
( SIP8 ) 800
-40~+85
-40~+125
UNIT
V
V
V
mW
˚C
˚C
( note ) For supply voltage less than ±15V,the absolute maximum input voltage is equal to the supply voltage.
■ ELECTRICAL CHARACTERISTICS ( NJM4556AD / NJM4556AL )
( V+/V-=±15V,Ta=25˚C )
PARAMETER
Input Offset Voltage
Input Offset Current
Input Bias Current
Input Resistance
Large Signal Voltage Gain
Maximum Output Voltage Swing 1
Maximum Output Voltage Swing 2
Input Common Mode Voltage Range
Common Mode Rejection Ratio
Supply Voltage Rejection Ratio
Supply Current
Slew Rate
Gain Bandwidth Product
SYMBOL
VIO
IIO
IB
RIN
AV
VOM1
VOM2
VICM
CMR
SVR
ICC
SR
GB
TEST CONDITION
RS≤10kΩ
RL≥2kΩ,VO=±10V
RL≥2kΩ
RL≥150Ω
RS≤10kΩ
RS≤10kΩ
MIN.
0.3
86
± 12
± 10.5
± 13.5
70
76.5
TYP.
0.5
5
50
5
100
± 13.5
± 11
± 14
90
90
9
3
8
MAX.
6.0
60
500
12
UNIT
mV
nA
nA
MΩ
dB
V
V
V
dB
dB
mA
V/μs
MHz
■ ELECTRICAL CHARACTERISTICS ( NJM4556AM / NJM4556AV )
PARAMETER
Input Bias Current
SYMBOL
VIO
IIO
IB
AV
VOM1
VOM2
Input Common Mode Voltage Range 1
Input Common Mode Voltage Range 2
Supply Current
Slew Rate
VICM1
VICM2
CMR
SVR
ICC
SR
GB
-2-
TEST CONDITION
RS≤10kΩ
RL≥2kΩ,VO=±10V
VIN =4V,VIN =3V,V =9V,V =0V
ISOURCE=40mA
VIN =3V,VIN =4V,V =9V,V =0V
ISINK=40mA
V =9V,V =0V,VIL
V =9V,V =0V,VIH
RS≤10kΩ
RS≤10kΩ
V =9V,V =0V
MIN.
86
7.5
TYP.
0.5
5
50
100
MAX.
6.0
60
500
UNIT
mV
nA
nA
dB
V
2.1
V
8
70
76.5
90
90
8
3
8
1.5
12
V
V
dB
dB
mA
V/μs
MHz
Ver.2020-03-26
NJM4556A
■ TYPICAL CHARACTERISTICS
Ver.2020-03-26
-3-
NJM4556A
[CAUTION]
The specifications on this databook are only
given for information , without any guarantee
as regards either mistakes or omissions. The
application circuits in this databook are
described only to show representative usages
of the product and not intended for the
guarantee or permission of any right including
the industrial rights.
-4-
Ver.2020-03-26
很抱歉,暂时无法提供与“NJM4556AD”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+3.36960
- 10+2.62440
- 50+2.24640
- 100+1.85760
- 500+1.67400
- 1000+1.56600
