Technical Data ELX1005
Effective August 2022
Supersedes February 2021
MOVS2825
Surface mount metal oxide varistor
Applications
Power supply
Home appliance
Industrial equipment
Telecommunication or telephone system
Vac driven & COB LED lighting
Agency information
Product features
Surface mount metal oxide varistor (MOV)
2825 (7264 metric) package size
High transient current capability
Plastic package meets UL 94 V-0
Meets UL1449 4th edition
Moisture sensitivity level (MSL): 1
cURus recognized:
File: E340782, Guide VZCA2 and VZCA8
Environmental compliance
HALOGEN
Pb HF
FREE
Ordering part number
MOV S 2825 V011
Family name
Type
Size
Working voltage (Vrms)
MOVS2825
Electrical characteristics (+25 °C)
Part number
Working voltage
Vrms
Vdc
(V)
(V)
maximum
maximum
Varistor voltage
@ 1 mAdc
Vv
(V)
typical
Leakage current @
Vv * 80% (at initial
state)
IL
(µA)
maximum
Clamping voltage
8/20 µs
VC
(V)
maximum
Peak
current
8/20 µs
imax
(A)
maximum
Maximum
energy
Rated
power
Typical
capacitance
(J)
10/1000 μs
(W)
(pF)
1.0 kHz
Component
thickness
T
(mm)
±0.3
MOVS2825V011 11
14
16.2~19.8
50
40 (1 A)
150
0.4
0.01
2100
3.2
MOVS2825V014 14
18
19.8~24.2
50
48 (1 A)
150
0.5
0.01
1700
3.2
MOVS2825V017 17
22
24.3~29.7
50
60 (1 A)
150
0.6
0.01
1400
3.2
MOVS2825V020 20
26
29.7~36.3
50
73 (1 A)
150
0.8
0.01
1200
4.2
MOVS2825V025 25
31
35.1~42.9
50
80 (1 A)
150
0.9
0.01
550
4.2
MOVS2825V030 30
38
42.3~51.7
50
104 (1 A)
150
1.1
0.01
640
4.2
MOVS2825V035 35
45
50.4~61.6
50
123 (1 A)
150
1.3
0.01
420
4.2
MOVS2825V040 40
56
61.2~74.8
50
145 (1 A)
150
1.6
0.01
350
4.2
MOVS2825V050 50
66
73.8~90.2
50
150 (5 A)
400
2.5
0.1
260
3.2
MOVS2825V060 60
85
90~110
50
175 (5 A)
400
3.0
0.1
240
3.2
MOVS2825V075 75
102
108~132
50
210 (5 A)
400
4.0
0.1
185
4.2
MOVS2825V095 95
127
135~165
50
260 (5 A)
400
4.1
0.1
175
4.2
MOVS2825V120 120
160
170~207
50
320 (5 A)
400
4.9
0.1
95
4.2
MOVS2825V130 130
175
185~225
50
355 (5 A)
400
6.5
0.1
90
4.2
MOVS2825V140 140
180
198~242
50
380 (5 A)
400
7.5
0.1
85
4.2
MOVS2825V150 150
200
216~264
50
415 (5 A)
400
8.0
0.1
80
4.2
MOVS2825V180 180
230
255~311
50
475 (5 A)
400
8.5
0.1
70
4.2
MOVS2825V195 195
250
270~330
50
520 (5 A)
400
9
0.1
65
4.2
MOVS2825V210 210
275
297~363
50
570 (5 A)
400
9.5
0.1
65
4.2
MOVS2825V230 230
300
324~396
50
620 (5 A)
400
10
0.1
60
4.2
MOVS2825V250 250
330
351~429
50
675 (5 A)
400
12
0.1
55
4.2
MOVS2825V275 275
370
387~473
50
745 (5 A)
400
13
0.1
50
5.6
MOVS2825V300 300
385
423~517
50
810 (5 A)
400
15
0.1
45
5.6
MOVS2825V320 320
420
459~561
50
845 (5 A)
400
16
0.1
45
5.6
MOVS2825V360 360
470
522~638
50
920 (5 A)
400
16.5
0.1
40
5.6
MOVS2825V390 390
505
558~682
50
1025 (5 A)
400
21
0.1
40
5.6
MOVS2825V420 420
560
612~748
50
1120 (5 A)
400
22
0.1
35
5.6
VRMS /VDC – Maximum operating voltage the varistor can maintain
Vv – Voltage across the device measured at 1 mA DC current. Equivalent to Vb, “Breakdown Voltage”.
Vc – Maximum peak voltage across the varistor measured at 8/20 us waveform .
imax – Maximum peak current which may be applied with 8/20 us waveform without device failure
2
www.eaton.com/electronics
MOVS2825
Dimensions- mm
Drawing not to scale
Recommended pad layout
L
W
L
C1
T
C2
Bottom view
Dimension
Value
A
6.8
7.2 ± 0.2
B
1.5
W
6.4 ± 0.2
C
4.6
T
3.2 ± 0.3
L
7.6
Dimension
Value
L
4.2 ± 0.3
5.6 ± 0.3
C1
5.8 ± 0.3
C2
1.1 ± 0.3
Note
Refer to
Electrical
specifications
table on pg 2
Part marking
Part number
Marking
Part number
Marking
MOVS2825V011
A
MOVS2825V140
O
MOVS2825V014
B
MOVS2825V150
P
MOVS2825V017
C
MOVS2825V180
Q
MOVS2825V020
D
MOVS2825V195
R
MOVS2825V025
E
MOVS2825V210
S
MOVS2825V030
F
MOVS2825V230
T
MOVS2825V035
G
MOVS2825V250
U
MOVS2825V040
H
MOVS2825V275
V
MOVS2825V050
I
MOVS2825V300
W
MOVS2825V060
J
MOVS2825V320
X
MOVS2825V075
K
MOVS2825V360
Y
MOVS2825V095
L
MOVS2825V390
Z
MOVS2825V120
M
MOVS2825V420
2
MOVS2825V130
N
General specifications
Operating temperature: -40 °C to +85 °C
Storage temperature (on board): -40 °C to +85 °C
Solderability: +245 ± 5 °C, 3 ± 1 second
Solder leach resistance: +260 ± 5 °C, 10 ± 1 second
3
Packaging information - mm
MOVS2825
900 pieces per reel for MOVS2825, T = 5.6 mm,
Dimension
Value
1100 pieces per reel for MOVS2825, T = 4.2 mm,
W
16.00 ± 0.30
1400 pieces per reel for MOVS2825, T = 3.2 mm
E
1.75 ± 0.10
F
7.50 ± 0.15
D0
1.50 ± 0.10/-0.00
D1
1.50 ± 0.10/-0.00
P0
4.00 ± 0.10
P0 x10
40.0 ± 0.20
t
0.50 ± 0.05
A0
6.75 ± 0.15/-0.05
B0
7.55 ± 0.15/-0.05
K0
6.20 maximum
P1
12.00 ± 0.10
P2
2.00 ± 0.15
Reel dimension - mm
4
Dimension
Value
A
330 ± 2.00
B
99 ± 1.50
C
13.50 ± 0.20
D
2.30 ± 0.20
E
16.50 ± 0.50
F
2.20 ± 0.20
G
10.75 ± 0.20
MOVS2825
Percent of rated value (%)
Peak current, energy and power derating curve
Temperature (°C)
Voltage vs current (V-I) curves
5
MOVS2825
Voltage vs current (V-I) curves (continued)
Rated peak surge current (A)
Pulse rating curve
Surge impulse duration (µs)
6
MOVS2825
Pulse rating curve (continued)
7
MOVS2825
Solder reflow profile
TP
TC -5°C
tP
Max. Ramp Up Rate = 3°C/s
Max. Ramp Down Rate = 6°C/s
Temperature
TL
Preheat
A
T smax
t
Table 1 - Standard SnPb solder (Tc)
Package
thickness
Volume
mm3
很抱歉,暂时无法提供与“MOVS2825V275”相匹配的价格&库存,您可以联系我们找货
