AFH34-S40FIA-1H
AFH34-S40FIA-1H
    JS(钜硕电子)
    SMD,P=0.5mm,卧贴
    间距:0.5mm 触点数量:40P 锁定特性:翻盖式 安装类型:卧贴 触点类型:双侧触点/上下接 板上高度:H1.0mm 触头镀层:镀金1U
AFH34-S40FIA-1H 数据手册
AFH34 - S   **   F I   A -1H  带 为重点管控尺寸 Remarks: 1H=Housing  HF:Halogen free Packing: A=Tape & rell  C=tube Gold flash I=1u"AU M=5U"AU    Right Angle Double Contact Type NO.of contacts Series name FPC Series Pitch=0.5mm 深圳市钜硕电子有限公司 SHENZHEN JUSHUO ELECTRONIC CO.,LTD 0.5Pitch 1.0H ZIF/前插后掀式 AFH34-S**FIA-1H 本产品需符合 □ □ ※禁止使用本公司所禁用有毒物质 (Metal mask) 深圳市钜硕电子有限公司 SHENZHEN JUSHUO ELECTRONIC CO.,LTD 0.5Pitch 1.0H ZIF/前插后掀式 AFH34-S**FIA-1H 本产品需符合 □ □ ※禁止使用本公司所禁用有毒物质 后面留大约128mm盖带 后面空16个穴不装产品 前面空16个穴不装产品 深圳市钜硕电子有限公司 装4000PCS产品 SHENZHEN JUSHUO ELECTRONIC CO.,LTD 0.5Pitch 1.0H ZIF/前插后掀式 AFH34-S**FIA-1H 本产品需符合 □ □ ※禁止使用本公司所禁用有毒物质 深圳市钜硕电子有限公司 SHENZHEN JUSHUO ELECTRONIC CO.,LTD FPC Connector 0.5mmPitch A Product Specification Issued Date 2021-05-21 FPC 0.5 Pitch Right Angle ZIF SMT TYPE Connector Item 1 2 Update List: Update Description Rev. IssuedDate New Edit A 2013/03/27 Modify B 2021/05/21 Revisor PETER PETER Prepared By:Peter Rechecked By:Peter Approved By:Gao ` Document No:CPC -RD002 Product Name: FPC CONN. 1 of 8 深圳市钜硕电子有限公司 SHENZHEN JUSHUO ELECTRONIC CO.,LTD FPC Connector Issued Date Product Specification 0.5mmPitch A 2021-05-21 1. SCOPE This specification covers theAFH34Series Connector. 2. ORDERING INFORMATION PART NO.: AFH34 FIA S** 1 2 3 4 5 1 Series name FPC Connector 2 Pitch between 0.5 mm Pitch contacts 3 Series Number 4 Number of terminals 5 Assembly style 6 Plating 7 The height Packaging 1H 6 7 09 4~50 F: Right Angle /Low and top Contact SMT I: Gold flashMatte Tin A: Tape Reel H:1.0mm 3. CONNECTOR DIMENSIONS See attached drawings. 4. MATERIAL Housing : Contact : LCP Color : White Flammability Rating (UL94V-0) HF LCP Color : Black. Flammability Rating (UL94V-0) COPPER ALLOY Leg : COPPER ALLOY Contact Plating Gold Flash 50u”-100u” Nickel Underplating Tin over Nickel Actuator Leg Plating: 5. ACCOMMODATED P.C.B. LAYOUT See attached drawings. 6. RATING. Document No:CPC -RD002 Product Name: FPC CONN. 2 of 8 深圳市钜硕电子有限公司 SHENZHEN JUSHUO ELECTRONIC CO.,LTD FPC Connector Issued Date Product Specification 0.5mmPitch A ITEM 2021-05-21 STANDARD Operating Voltage (Max.) 50Vrms AC Current Rating (Max.) 0.5A Operating Temperature -55°C ~ +85°C (Including terminal temperature rise) Operating Humidity range Relative humidity 90%Max Storage temperature range -10°C ~ +50°C Storage Humidity range Relative humidity 90%Max. 7. PERFORMANCE 项目 ITEM 测试条件 TEST CONDITION 电气特性 (ELECTRICAL PERFORMANCE) 规格 REQUIRMENT 将样品与适合之 FPC 连接,测试电压 20mV,限电流 10mA 下进行阻抗测试。 接触阻抗 (JIS C5402 5.4) 40mΩ 以下. Contact Resistance Mate applicable FPC and measure by dry circuit, 40 mΩ Max. 20mV Max, 10mA. (JIS C5402 5.4) 将样品与适合之 FPC 连接,提供相邻端子间测试电压 500V DC 进行绝缘阻抗测试。 绝缘阻抗 (JIS C5402 5.2 / MIL-STD-202 Method 302) 50 MΩ 以上. Insulation Resistance Mate applicable FPC and apply 500V DC between 50 MΩ Min. adjacent terminal or ground. (JIS C5402 5.2 / MIL-STD-202 Method 302) 将样品与适合之 FPC 连接,相邻端子间需可承受 250V AC(rms) 1 分钟。 耐电压 (JIS C5402 5.1 / MIL-STD-202 Method 301) 目视外观无任何损坏异状 Dielectric Strength Mate applicable FPC, apply 250V AC(rms) for No Breakdown 1 minute between adjacent terminal or ground. (JIS C5402 5.1 / MIL-STD-202 Method 301) 机械特性 (MECHANICAL PERFORMANCE) 将盖子盖上,与 FPC 连接,以操作速度每分钟位移 FPC 保持力 25±3mm 进行 FPC 保持力测试。 Pos. x 0.2N 以上 FPC Retention Force Insert the actuator, pull the FPC at a rate of 25±3mm Pos. x 0.2N Min. per minute. 端子保持力 Terminal Retention Force 端子与 Housing 组装后,以操作速度每分钟位移 25±3mm 将端子拔出 Housing,进行端子保持力测试。 Pos. x 0.08Kgf {0.8N} 以上 Apply axial pull out force at the rate of 25±3 Pos. x 0.08Kgf {0.8N} Min. mm/minute on the terminal assembled in the housing. Document No:CPC -RD002 Product Name: FPC CONN. 3 of 8 深圳市钜硕电子有限公司 SHENZHEN JUSHUO ELECTRONIC CO.,LTD FPC Connector 0.5mmPitch A 项目 ITEM 温升 Temperature Rise 耐振性 Vibration 耐冲击性 Shock 耐热性 Heat Resistance 耐寒性 Cold Resistance Issued Date Product Specification 测试条件 TEST CONDITION 量测通过 FPC 最大容许电流时,样品接触点之温 升。 (UL498) Mate applicable FPC and measure the temperature rise of contact when the maximum AC rated current is passed. (UL498) 通过 DC 电流 1mA,位移相对距离 1.5mm,振 动周期10∼ 55∼ 10 Hz 在 1 分钟内,持续 2 小 时,方向在 X,Y,Z轴做测试。 (MIL-STD-202 Method 201) Mate connectors and subject to the following vibration conditions, for period of 2 hours in each of 3 mutually perpendicular axes, passing DC 1mA during the test. Amplitude : 1.5mm P-P Frequency : 10∼55∼10 Hz in 1 minute. Duration : 2 hours in each of X,Y,Z axes. (MIL-STD-202 Method 201) 将样品与适合之 FPC 连接,通过 DC 1 mA 测试 条件, 连续测试 3 次。在 X、Y、Z 3 轴 6 个 2 垂直方向施予重力加速度.490m/s {50G} 冲击。 (JIS C0041/MIL-STD-202 Method 213) Mate applicable FPC and subject to the following shock conditions. 3 times of shocks shall be applied for each 6 directions along 3 mutually perpendicular axes, passing DC 1 mA current during the test. (JIS C0021 / MIL-STD-202 Method 108) 将样品与适合之 FPC 连接,置于环境温度 85±2°C 测试时间 96 小时,再置放于室温下 1∼2 小时。 Mate applicable FPC and expose to 85±2°C for 96 hours. Upon completion of the exposure period, the test specimens shall be conditioned at ambient room conditions for 1 to 2 hours, after which the specified measurements shall be performed. (JIS C0021 / MIL-STD-202 Method 108) 将样品与适合之 FPC 连接,置于环境温度40±2°C, 测试时间 96 小时,再置放于室温下 1 ∼2 小时。 (JIS C0020) Mate applicable FPC and expose to -40±2°C for 96 hours. Upon completion of the exposure period, the test specimens shall be conditioned at ambient room conditions for 1 to 2 hours, after which the specified measurements shall be performed.(JIS C0020) 2021-05-21 规格 REQUIRMENT 温升 Temperature rise 30°C 以下. 外观 Appearance 目视外观无 任 何 损坏异 状 No Damage 接 触 阻 抗 Contact Resistance 瞬间断电 Discontinuity 60 mΩ 以下. 60 mΩ Max. 30°C Max. 1 μsec 以下. 1 μsec Max. 外观 Appearance 目视外观无 任 何 损坏异 状 No Damage 接 触 阻 抗 Contact Resistance 60 mΩ 以下. 60 mΩ Max. 瞬间断电 Discontinuity 外观 Appearance 1 μsec 以下. 1 μsec Max. 目视外观无 任 何 损坏异 状 No Damage 接 触 阻 抗 Contact Resistance 60 mΩ 以下. 60 mΩ Max. 外观 Appearance 目视外观无 任 何 损坏异 状 No Damage 接 触 阻 抗 Contact Resistance 60 mΩ 以下. 60 mΩ Max. 4 of 8 Document No:CPC -RD002 Product Name: FPC CONN. 深圳市钜硕电子有限公司 SHENZHEN JUSHUO ELECTRONIC CO.,LTD FPC Connector 0.5mmPitch A Product Specification 测试条件 TEST CONDITION 项目 ITEM 耐湿性 Humidity 将样品与适合之 FPC 连接,置于环境温度 60±2°C, 相对湿度 90∼95%,测试时间 96 小时,再置放 于室温 下 1∼2 小时。 (JIS C0022 / MIL-STD-202 Method 103) Mate applicable FPC and expose to 60 ± 2°C, relative humidity 90 to 95% for 96 hours. Upon completion of the exposure period, the test specimens shall be conditioned at ambient room conditions for 1 to 2 hours, after which the specified measurements shall be performed. (JIS C0022 / MIL-STD-202 Method 103) 冷热冲击 Temperature Cycling Issued Date 2021-05-21 规格 REQUIRMENT 外观 Appearance 目视外观无 任 何 损坏异状 No Damage 接 触 阻 抗 Contact Resistance 60 mΩ 以下. 60 mΩ Max. 耐电压 Dielectric Strength 绝 缘 阻 抗 Insulation Resistance 外观 将样品与适合之 FPC 连接,承受 5 cycles 冷热冲击 Appearance 后, 置放于室温下 1∼2 小时。 1 cycle time 如下 a) -55±3°C 30 分钟 b) +85±3°C 30 分钟 (JIS C0025) Mate applicable FPC and subject to the following conditions for 5 cycles. 接触阻抗 Upon completion of the exposure period, the test specimens shall be conditioned at ambient room Contact conditions for 1 to 2 hours, after which the Resistance specified measurements shall be performed. 需能符合耐电 压 测试 No Breakdown 50 MΩ 以上. 50 MΩ Min. 目视外观无 任 何 损坏异状 No Damage 60 mΩ 以下. 60 mΩ Max. 1 cycle a) -55±3°C 30minutes b) +85±3°C 30minutes (Transit time shall be with in 3 minutes) (JIS C0025) 盐水喷雾 Salt Spray 外观 将样品与适合之 FPC 连接,使用 5±1%浓度盐水, 测试温度 35±2°C,测试时间 48±1 小时,后于室温下 Appearance 使用清水 冲洗后再干燥。 (JIS C0023 / MIL-STD-202 Method 101) Mate applicable FPC and expose to the following salt mist conditions. Upon completion of the exposure period, salt deposits shall be removed by a gentle wash or dip in running water, after which the specified 接触阻抗 NaCl solution Contact Concentration : 5 ± 1% Resistance Spray time : 48 ± 4 hours Ambient temperature : 35 ± 2°C (JIS C0023 / MIL-STD-202 Method 101) 目视外观无 任何 损坏异状 60 mΩ 以下. 60 mΩ Max. 5 of 8 Document No:CPC -RD002 Product Name: FPC CONN. 深圳市钜硕电子有限公司 SHENZHEN JUSHUO ELECTRONIC CO.,LTD FPC Connector Product Specification 0.5mmPitch A Issued Date 2021-05-21 8. INFRARED REFLOW CONDITION 250°C MAX.(Peak Temp.)3Sec. or less °C 230°C MIN. / 20~40Sec. 230 200 150 100 50 0 Start 60 Sec. 60~90 Sec. 30 Sec. Time(sec.) NOTE: Please check the re-flow soldering condition by your own devices beforehand . Because the condition changes by the soldering devices, p.c. boards, and so on. 9. TAPE AND REEL PACKAGE SPECIFICATION 9-1.Tape and Reel Dimensions:See attached drawings. 6 of 8 Document No:CPC -RD002 Product Name: FPC CONN. 深圳市钜硕电子有限公司 SHENZHEN JUSHUO ELECTRONIC CO.,LTD FPC Connector 0.5mmPitch A Product Specification Issued Date 2021-05-21 10.操作指示Instruction upon usage 步骤 1: Joining step 1: 当上盖呈打开状态 时,将FPC插入连接器中。 Insert the FPC with the actuator opened. 步骤 2: Joining step 2: FPC完全插入且没有移动,压上盖往下 旋转至定位。 FPC is totally inserted and not moved. press the actuator and rotate down to make a reservation . 步骤 3: Joining step 3: FPC removal FPC退出。 掀起上盖,将FPC退出 Lift the actuator, withdraw FPC . 警告 Warning!! 旋转的角度不可大于 90 度。 The whirling angle can't be greater than 90 degrees. 警告 Warning!! 施压的力量应该要平均且要压盖的中心部位 The strength of exerting pressure should be average and pushing actuator at the center . 7 of 8 Document No:CPC -RD002 Product Name: FPC CONN. 深圳市钜硕电子有限公司 SHENZHEN JUSHUO ELECTRONIC CO.,LTD FPC Connector 0.5mmPitch A Product Specification Issued Date 2021-05-21 警告 Warning!! 掀盖要掀盖的中心部位。 To lift actruator at the center. 警告 Warning!! PCB板平整度必须在0.1mm max 。 The roughness of PCB board must be in 0.1mm max. 警告 Warning!! 产品不能不插FPC时翻转盖子。 Products not inserted flip lid. 8 of 8 Document No:CPC -RD002 Product Name: FPC CONN.
AFH34-S40FIA-1H 价格&库存
很抱歉,暂时无法提供与“AFH34-S40FIA-1H”相匹配的价格&库存,您可以联系我们找货
AFH34-S40FIA-1H
    • 1+2.00880
    • 10+1.76040
    • 30+1.65240
    • 100+1.52280
    • 500+1.39320
    • 1000+1.36080
    库存:2389
