SMS-1508MS-HT-R
SMS-1508MS-HT-R
    PUIAUDIO
    SMS-1508MS-HT-R
SMS-1508MS-HT-R 数据手册
This document contains data proprietary to PUI Audio Inc. Any use or reproduction, in any form, without prior written permission of PUI Audio Inc. is prohibited. ©2020, PUI Audio Inc. Data Sheet SMS-1508MS-HT-R PUI Audio’s High-Temp line of products is designed to meet and exceed the needs of the automotive industry with ultra-wide operating temperatures. The SMS-1508MS-HT-R is designed for high output at 800Hz in a small package. • Wide -40°C to +105°C operating temperature • 92 dB output at 10cm with 0.8W input • Wide 400Hz to 10,000 Hz frequency range Specifications Parameters Rated Input Power Max Input Power Impedance Sensitivity @ 1k, 1.6k, 2.0k & 3.2kHz Ave Resonant Frequency Frequency Range Weight Acceptable Soldering Methods Environmental Compliances Storage Temperature Operating Temperature Values Units 0.8 1.0 8±20% Watts Watts Ohms 92±3 800±15% 400 ~ 10,000 1.7 dB Hz Hz Grams See below for soldering information °C °C Hand Solder, Reflow RoHS -40 ~ +105 -40 ~ +105 Measurement Method (0.8W sine sweep, microphone spaced at 10cm, speaker in 1cc enclosure) PUI Audio, Inc., 3541 Stop Eight Road, Dayton, OH 45414 Tel: (937) 415-5901 Fax: (937) 415-5925 This document contains data proprietary to PUI Audio Inc. Any use or reproduction, in any form, without prior written permission of PUI Audio Inc. is prohibited. ©2020, PUI Audio Inc. Typical Frequency Response (0.8W sine-sweep with microphone spaced at 10cm) Recommended Soldering Procedure PUI Audio, Inc., 3541 Stop Eight Road, Dayton, OH 45414 Tel: (937) 415-5901 Fax: (937) 415-5925 This document contains data proprietary to PUI Audio Inc. Any use or reproduction, in any form, without prior written permission of PUI Audio Inc. is prohibited. ©2020, PUI Audio Inc. Reliability Testing Type of Test High Temperature Test Low Temperature Test Humidity Test Temperature Cycle Testing Vibration Test Shock Test Drop Test Test Specifications Test part at +105℃ for 120 hours Test part at -40℃ for 120 hours 40±2℃, 90 ~ 95% RH, 120 hours Total 5 cycles, 1 cycle consisting of -40±2℃, 30 minutes 20±5℃ 15 minutes 105±2℃, 30 minutes 20±5℃ 15 minutes The part shall be subjected to a vibration cycle of 10Hz for a period of 1 minute. Total peak amplitude shall be 1.52mm (9.3g). The vibration test shall consist of 2 hours per plane in each three mutually perpendicular planes for a total time of 6 hours. Sounder shall be measured after being applied a shock of 980m/s² for each three mutually perpendicular directions to each of 3 times by a half sine wave. Drop from 700mm height onto the surface of a 10mm thick wooden board. All specifications must be satisfied after the test. Dimensions (Tolerance: ±0.5mm unless otherwise specified) PUI Audio, Inc., 3541 Stop Eight Road, Dayton, OH 45414 Tel: (937) 415-5901 Fax: (937) 415-5925 This document contains data proprietary to PUI Audio Inc. Any use or reproduction, in any form, without prior written permission of PUI Audio Inc. is prohibited. ©2020, PUI Audio Inc. Suggested Land Pattern* *This land pattern is advisory only and its use or adaptation is entirely voluntary. PUI Audio disclaims all liability of any kind associated with the use, application, or adaptation of this land pattern. Packaging PUI Audio, Inc., 3541 Stop Eight Road, Dayton, OH 45414 Tel: (937) 415-5901 Fax: (937) 415-5925 This document contains data proprietary to PUI Audio Inc. Any use or reproduction, in any form, without prior written permission of PUI Audio Inc. is prohibited. ©2020, PUI Audio Inc. Packaging (Cont’d) PUI Audio, Inc., 3541 Stop Eight Road, Dayton, OH 45414 Tel: (937) 415-5901 Fax: (937) 415-5925 This document contains data proprietary to PUI Audio Inc. Any use or reproduction, in any form, without prior written permission of PUI Audio Inc. is prohibited. ©2020, PUI Audio Inc. Revision - Specifications Revisions Description Released from Engineering Note: 1. Unless otherwise specified: A. All dimensions are in millimeters. B. Default tolerances are ±0.5mm and angles are ±3°. 2. Specifications subject to change or withdrawal without notice. PUI Audio, Inc., 3541 Stop Eight Road, Dayton, OH 45414 Tel: (937) 415-5901 Fax: (937) 415-5925 Date 3/6/2020
SMS-1508MS-HT-R 价格&库存
很抱歉,暂时无法提供与“SMS-1508MS-HT-R”相匹配的价格&库存,您可以联系我们找货
SMS-1508MS-HT-R
  • 1+41.320721+5.34783
  • 10+32.5366010+4.21097
  • 25+29.6535425+3.83784
  • 50+27.6684450+3.58092
  • 100+26.42871100+3.42047
库存:1894
SMS-1508MS-HT-R
  • 600+23.19198600+3.00157
  • 1200+21.631481200+2.79960
  • 1800+21.592101800+2.79450
库存:1894
SMS-1508MS-HT-R
    • 1+35.27167
    • 10+31.72055
    • 100+29.32537
    • 500+27.12805
    • 1000+22.02527
    库存:540
    SMS-1508MS-HT-R
      • 1+40.570201+5.25280
      • 10+36.4856010+4.72390
      • 100+33.73060100+4.36720
      • 500+31.20320500+4.04000
      • 1000+25.333901000+3.28010
      库存:540
