MBR260HW
MBR260HW
    SMCDIODESOLUTIONS(桑德斯)
    SOD123
    MBR260HW
MBR260HW 数据手册
MBR260HW Technical Data Data Sheet N1503, Rev.B MBR260HW SURFACE MOUNT SCHOTTKY BARRIER DIODE Features    SOD-123 Circuit Diagram       125°C TJ operation Low forward voltage drop High purity, high temperature epoxy encapsulation for enhanced mechanical strength and moisture resistance High frequency operation Guard ring for enhanced ruggedness and long term reliability Terminals finish: 100% Pure Tin This is a Pb − Free Device All SMC parts are traceable to the wafer lot Additional testing can be offered upon request Mechanical Data      Case: SOD-123, Molded Plastic Terminals: Plated Leads Solderable per MIL-STD-202, Method 208 Polarity: Cathode Band Weight: 0.01 grams(approx) Marking code: L26 Maximum Ratings and Electrical Characteristics @TA=25°C unless otherwise specified Characteristic Symbol Value Units VRRM VRWM VR 60 V IO 2 A VFM 0.52 0.66 V IRM 50 μA Non-Repetitive Peak Surge Current (Surge Applied at Rated Load Conditions Half-wave, Single Phase, 60 Hz) IFSM 30 A Maximum Junction Capacitance (Note 1) Cj 100 pF Operating Junction Temperature Range TJ 125 °C TSTG -55 to +150 °C Peak Repetitive Reverse Voltage Working Peak Reverse Voltage DC Blocking Voltage Average Rectified Forward Current (At Rated VR, TL = 55°C) Forward Voltage @IF = 1A,TA = 25°C @IF = 2A,TA = 25°C Peak Reverse Current @TA = 25°C Storage Temperature Range Note 1. Measured at 1MHz and applied reverse voltage of 5.0V D.C.  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  MBR260HW Technical Data Data Sheet N1503, Rev.B Ratings and Characteristics Curves TJ=125℃ TJ=25℃ TJ=25℃ Fig.1-Typical Junction Capacitance Fig.2-Typical Reverse Characteristics TJ=125℃ TJ=25℃ Fig.3-Typical Forward Voltage Drop Characteristics  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  MBR260HW Technical Data Data Sheet N1503, Rev.B Mechanical Dimensions SOD-123 SYMBOL MAX. MIN. MAX. A A1 A2 b 1.050 0.000 1.050 0.450 1.250 0.100 1.150 0.650 0.041 1 0.000 0.041 0.018 0.049 0.004 0.045 0.026 c 0.080 0.150 0.003 0.006 θ Device MBR260HW MBR260HWTR Package SOD-123 (Pb-Free) SOD-123 (Pb-Free) Inches MIN. D E E1 L L1 Ordering Information Millimeters 1.500 1.700 2.600 2.800 3.550 3.850 0.500 REF. 0.250 0.450 0° 8° 0.059 0.067 0.102 0.110 0.140 0.152 0.020 REF. 0.010 0.018 0° 8° Marking Diagram Shipping Where X is Date Code 3000pcs / reel L26 =Marking code 3000pcs / reel For information on tape and reel specifications, including part orientation and tape sizes, please refer to our tape and reel packaging specification. Carrier Tape Specification SOD-123 SYMBOL A B C d E F P P0 P1 W Millimeters Min. Max. 1.80 3.89 1.52 1.45 1.65 3.40 3.90 3.90 1.90 7.90  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com  1.90 3.99 1.62 1.65 1.85 3.60 4.10 4.10 2.10 8.30 MBR260HW Technical Data Data Sheet N1503, Rev.B DISCLAIMER: 1- The information given herein, including the specifications and dimensions, is subject to change without prior notice to improve product characteristics. Before ordering, purchasers are advised to contact the SMC Diode Solutions sales department for the latest version of the datasheet(s). 2- In cases where extremely high reliability is required (such as use in nuclear power control, aerospace and aviation, traffic equipment, medical equipment , and safety equipment) , safety should be ensured by using semiconductor devices that feature assured safety or by means of users’ fail-safe precautions or other arrangement . 3- In no event shall SMC Diode Solutions be liable for any damages that may result from an accident or any other cause during operation of the user’s units according to the datasheet(s). SMC Diode Solution assumes no responsibility for any intellectual property claims or any other problems that may result from applications of information, products or circuits described in the datasheets. 4- In no event shall SMC Diode Solutions be liable for any failure in a semiconductor device or any secondary damage resulting from use at a value exceeding the absolute maximum rating. 5- No license is granted by the datasheet(s) under any patents or other rights of any third party or SMC Diode Solutions. 6- The datasheet(s) may not be reproduced or duplicated, in any form, in whole or part, without the expressed written permission of SMC Diode Solutions. 7- The products (technologies) described in the datasheet(s) are not to be provided to any party whose purpose in their application will hinder maintenance of international peace and safety nor are they to be applied to that purpose by their direct purchasers or any third party. When exporting these products (technologies), the necessary procedures are to be taken in accordance with related laws and regulations..  China - Germany - Korea - Singapore - United States   http://www.smc-diodes.com - sales@ smc-diodes.com 
MBR260HW 价格&库存
很抱歉,暂时无法提供与“MBR260HW”相匹配的价格&库存,您可以联系我们找货
