BK10C05-30DS/2-0.3V(895) 数据手册
BK10 Series
Jan.1.2023 Copyright 2023 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
0.3mm Pitch, 0.5mm Stacking Height, Fully Armored,
Hybrid FPC-to-Board Connector
NEW
May 2022
BK10 Series/0.3mm Pitch, 0.5mm Stacking Height, Fully Armored, Hybrid FPC-to-Board Connector
Features
Conventional Product
BK10
0.1mm
Reduced
Compact design ideal for mobile devices.
・Stacking height : 0.5mm, Pitch : 0.3mm,
Depth : 1.7mm
Stacking Height : 0.5mm
PCB Mounting Space : 14.25mm2
Conventional
Product
0.35mm Pitch
Signal 30Pos.
+Power 2Pos.
1.9mm
Stacking Height : 0.6mm
7.5mm
16%
Reduced
PCB Mounting Space : 12.04mm2
BK10
0.3mm Pitch
Signal 30Pos.
+Power 2Pos.
1.7mm
1. Ultra
Low-profile and
Space-saving Design
7.08mm
Ultra Low-profile and Space-saving Design
2. Robust
Design
Fully armored guides prevent housing damage
due to misalignment when mating.
Only Partially Covered
with Metal
No Metal Parts
Exposed
Housing
Housing is
Covered by
Metal
Fully Armored Design
3. Dimpled
Contact Lock Design
for High Extraction Force
: Signal Contact Lock
: Power Contact Lock
Dimpled lock design on power and signal contacts
enables high extraction force.
er
Contact
Lock
ad
He
le
c
ta
ep
c
Re
Contact Lock Design
2
4. Enhanced PCB Peeling Strength
Back Side of the Receptacle
Both the header and receptacle have 3 solder areas
at each power contact for greater PCB peeling
strength.
3 Solder Areas
on Each Power
Contact
Back Side of the Header
3 Solder Areas Enhance PCB Peeling Strength
5. High Contact Reliability
Both the power and signal contacts have a two-point
contact design, ensuring high contact reliability.
6. Superior Mating Operability
Wide self-alignment range with metal guides offers
a smooth mating operation.
(±0.29mm in pitch direction, ±0.24mm in width
direction)
Additionally, the clear tactile click generated by the
unique locking contact design ensures complete
mating.
7. Halogen-Free
All materials and substances used to produce this
product comply with Halogen-free standards.
*As defined by IEC 61249-2-21
Br : 900ppm max., Cl : 900ppm max.,
Br+Cl : 1,500ppm max.
3
Product Specifications
Rated Voltage
Specifications
Contact Resistance
Insulation Resistance
Withstanding Voltage
Mating Durability
Vibration Resistance
Humidity Resistance
Signal Contact : 50mΩ Max.
Power Contact : 30mΩ Max.
Measured at 20mV AC, 1kHz, 1mA
No flashover or insulation breakdown
100V AC for 1 min.
50MΩ Min.
Measured at 100V DC
Contact Resistance : Signal
Contact : 50mΩ Max.
Power Contact : 50mΩ Max.
No damage, crack or looseness of parts
10 mating cycles
No electrical discontinuity of 1µs or more
Frequency : 10 to 55Hz, single amplitude 0.75mm,
10 cycles in each of 3 axis directions for 5 minutes/cycle
Contact : 50mΩ Max.
Insulation Resistance : 25MΩ Min.
96 hours at temperature of 40±2℃ and
humidity range from 90 to 95%
Acceleration : 490m/s2, duration of pulse : 11ms
at 3 times for 3 directions.
Contact : 50mΩ Max.
Insulation Resistance : 50MΩ Min.
Temperature Cycle
-55℃ for 30min. → +85℃ for 30 min. for 5 Cycles
(Stabilizing Time In Chamber : Within 2 to 3 min.)
Contact : 50mΩ Max.
Sulphur Dioxide
-10 to +60℃
Conditions
Shock Resistance
-55 to +85℃
Storage Temperature Range (Note 3)
30V AC/DC
Items
Operating Temperature (Note 2)
Signal Contact : 0.3A (Note 1)
Power Contact : 5A
Rated Current
Exposed in 25 PPM for 96h at 25℃, 75±5%RH.
(Test standard : JIS C 60068)
Note 1 : The total current capacity is 12A Max. for signal contacts.
Note 2 : Includes temperature rise due to current flow.
Note 3 : The term “storage” refers to long-term-storage of unused items before they are mounted on the PCB.
Operating temperature range applies to the product in a temporary storage state such as non-powered after mounting on the PCB during transportation, etc.
Materials / Finish
Part
Component
Header
Receptacle
Material
Insulator
LCP
Power Contact
Copper Alloy
Signal Contact
Finish
Black
Copper Alloy
Gold Plated over Nickel Underplating
Remarks
UL94V-0
Product Number Structure
Refer to the chart below when determining the product specifications from the product number.
Please select from the product numbers listed in this catalog when placing orders.
Header/Receptacle
BK10C
1
05
1 Series Name
2 Stacking Height
2
3 Number of Signal Contacts
4 Connector Type
3
BK10
DP
4
2
5
0.5mm
30pos.
DP : Double-row Header
DS : Double-row Receptacle
0.3
6
V
7
(8##)
8
5 Number of Power Contacts
2pos.
7 Terminal Type
V : Straight SMT
6 Contact Pitch
8 Packaging
4
0.3mm
(800) : Standard,
Embossed Tape Packaging
(20,000pcs per reel)
(895) : Embossed tape packaging (1,000pcs per reel)
Header
Recommended PCB Layout
Recommended Metal Mask Dimensions
(Mask Thickness : 0.08mm)
Unit : mm
No. of Pos.
Part No.
HRS No.
Signal
Contact
Power
Contact
A
B
C
D
E
BK10C05-30DP/2-0.3V(8##)
CL0480-0878-0-##
30
2
6.11
4.20
5.33
5.75
5.23
Note : This connector has no polarity.
5
Purchase Unit
## : 00
20,000pcs
per reel
## : 95
1,000pcs
per reel
Receptacle
Unit : mm
No. of Pos.
Part No.
HRS No.
Signal
Contact
Power
Contact
A
B
C
D
E
BK10C05-30DS/2-0.3V(8##)
CL0480-0879-0-##
30
2
7.08
4.20
4.72
7.38
4.62
6
Purchase Unit
## : 00
20,000pcs
per reel
## : 95
1,000pcs
per reel
Packaging Specifications Diagram
Header
Embossed Tape Dimensions
Reel Dimensions
Part No.
HRS No.
BK10C05-30DP/2-0.3V(800)
CL0480-0878-0-00
BK10C05-30DP/2-0.3V(895)
CL0480-0878-0-95
Unit : mm
No. of Pos.
Signal
Contact
Power
Contact
30
2
30
2
B
C
D
E
F
G
16.0
7.5
6.22
17.5
21.5
380
80
16.0
Receptacle
7.5
6.22
17.5
21.5
180
60
Reel Dimensions
Part No.
HRS No.
BK10C05-30DS/2-0.3V(800)
CL0480-0879-0 00
A
CL0480-0879-0 95
Unit : mm
No. of Pos.
Signal
Contact
Power
Contact
30
2
30
2
A
B
C
D
E
F
G
24.0
11.5
7.18
25.5
29.5
380
80
24.0
7
11.5
7.18
25.5
29.5
180
60
Usage Precautions
Recommended Solder
Temperature Profile
[Conditions]
1. Peak Temperature
: Maximum of 250℃
2. Heated Section
: 220℃ Min., within 60 seconds
3. Preheated Section
: 150 to 180℃, 90 to 120 seconds
4. Number of Reflow Cycles : Maximum of 2 cycles
Note 1 : The temperature is the surface temperature of the PCB in the vicinity of the connector lead part.
Note 2 : When using nitrogen reflow process, please mount the product with an oxygen concentration of 1000ppm or
more. Please contact a Hirose representative if the concentration is below 1000ppm.
Recommended Manual
Soldering Conditions
Soldering iron temperature : 340±10℃
Soldering time : within 3 seconds
Thickness and Open Area to
PCB Pattern Area Ratio
Thickness : 0.08mm
Aperture ratio : 100% on the Header side, 100% on the Receptacle side
PCB Warpage
A maximum of 0.02mm at the center of the connector with reference to both ends of the connector.
Cleaning
Not recommended. If this product is cleaned, please evaluate the performance before using it.
Cleaning may cause a change in the mating/unmating properties as well as environmental resistance.
Notes
・Insertion or removal prior to board mounting may result in contact deformation.
・Avoid supporting the PCB only with the connectors. Support it by other means such as bolts, screws, posts, etc.
・Avoid excessive prying during mating/unmating as it may result in damage.
・Do not apply flux which will cause solder wicking during manual soldering.
・This product may have slight color differences due to production lot variability, but this does not have any effect on
the performance.
・Please refer to the next page for mating/unmating precautions.
・It is advised to secure the mated connectors to the board with housings and cushioning materials because the
product can disengage from FPC routing, dropping or other impact.
・Do not use the connector outside of the specifications (i.e., rated current, rated voltage, PCB design and operating
environment, etc.). Such usage could lead to material outgassing, ignition, or short-circuit, etc.
・Please use a proper stiffener on the back of the FPC. We recommend using a glass epoxy material with a minimum
thickness of 0.3mm or a stainless steel material with a minimum of thickness of 0.2mm.
8
Connector Handling Precautions
【Connector Mating Method】
Header
Receptacle
1. Locate
the guides and align the connectors to the appropriate mating position.
The connector has guide ribs on the receptacle for proper mating alignment.
Align the connectors with the guide ribs.
Metal Cover Guide
(Outside)
Metal Cover Guide
(Inside)
2. When the connector comes to the appropriate position, the connector will lower into place as indicated by the change in mated height.
3. When the connectors has lowered into place, the connector pair will be parallel to each other andcannot be moved back and forth or left and right.
Please complete mating from this state by applying force.
(Please align the connectors)
4. Please
make sure connectors are mated completely. If one side is floating or the connectors are mated at an angle,
please unmate and then redo the mating procedure following the steps described.
9
【Connector Un- Mating Precautions】
1. It
is recommended to remove the connector by pulling perpendicular to the connector mounted surface.
However, unmating FPC-to-board connectors can become more difficult with higher pin count connectors and thinner FPCs.
2. I f is difficult to remove the connector parallel to the mounting surface, remove it diagonally towards the pitch direction.
Do not remove the connector towards the width direction as it may put a large amount of stress on the contacts.
3. If
the FPC is not rigid enough, there is a possibility of solder peeling or connector damage.
Please check the repetitive operation of the FPC planned to be used in advance, such as during the early stage build.
Please do not remove the FPC by holding one corner and pulling at a diagonal as this will put a great amount of stress on the contacts.
10
While Taking into Consideration
Specifications mentioned in this catalog are reference values.
When considering to order or use this product, please confirm the Drawing and Product Specifications sheets.
Use an appropriate cable when using the connector in combination with cables.
If considering usage of a non- specified cable, please contact your sales representative.
If assembly process is done by jigs & tools which are not identified by Hirose, assurance will not be given.
If considering usage for below mentioned applications, please contact your sales representative.
In cases where the application will demand a high level of reliability, such as automotive, medical instruments,
public infrastructure, aerospace/ defense etc. Hirose must review before assurance of reliability can be given.
2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN
https://www.hirose.com/
※ The contents of this catalog are current as of date of 05/ 2022. Contents are subject to change without notice for the purpose of improvements.
11
