泰州福声电子科技有限公司----- 电声产品专业制造商
FUSHENG ELECTRONICS------Acoustic Components ProfessionalManufacturer
SPECIFICATION OF PRODUCT
承 认 书
CUSTOMER:
DESCRIPTION:
FUSHENG P/N:
Piezo Buzzer
FSD-2316-24V
CUSTOMER P/N:
DATE:
CUSTOMER
APPROVER
CHECKER
Yunqing Wu
Bing Yan
泰州福声电子科技有限公司
地址:江苏省泰州市海陵区凤凰西路98 号
电话:0086-523-86219066 传真:0086-523-81601108
邮箱: sales@electronic-tech.cn
网址:www.tzfsdz.com
FSD-2316
1. SPECIFICATION 规格
No.
Item
Unit
Specification
Condition
1
Oscillation Frequency
Hz
3300±500
2
Operating Voltage
VDC
9 ~ 28
3
Rated Voltage
VDC
24
4
Current Consumption
mA
MAX. 10
at Rated Voltage
5
Sound Pressure Level
dB
MIN. 85
at 10cm at Rated Voltage
6
Operating Temperature
-20 ~ +70
7
Storage Temperature
-30 ~ +85
8
Dimension
mm
Φ23.0 x H12
9
Weight (MAX)
gram
4
10
Housing Material
ABS( Black )
11
Leading Pin
Wire Type
12
Environmental
Protection Regulation
RoHS
See appearance drawing
2. APPEARANCE DRAWING 尺寸图
FSD-2316
ESTINGMETHOD
测量方式
Standard Measurement conditions
Temperature:25±2℃ Humidity:45-65%
Acoustic Characteristics:
The oscillation frequency,current consumption and sound pressure are measured by the measuring
instruments shownbelow
In the measuring test, buzzer is placed as follows:
4. VOLTAGE/ CURRENT/ SOUNDPRESSURECHARACTERISTICS
5. RELIABILITYTEST 可靠性测试
FSD-2316
NO.
ITEM
1
High Temperature
Test (Storage)
Afterbeingplacedina chamberwith80 2ºCfor96 hoursandthen
beingplacedinnormalconditionfor2 hours.
AllowablevariationofSPLaftertest: 10dB.
2
Low Temperature
Test (Storage)
AfterbeingPlacedina chamberwith-30 2ºCfor96 hoursandthen
Humidity Test
AfterbeingPlacedina chamberwith90-95%R.H.at 40 2ºC for96
hoursandthenbeingplacedinnormalconditionfor2 hours.
3
TEST CONDITION AND REQUIREMENT
The part shall be subjected to 5 cycles. One cycle shall be consist of:
+70ºC
+25ºC
4
Temperature Cycle
Test
5
Drop Test
6
Vibration Test
7
Solderability
Test
8
Terminal Strength
Pulling Test
+25ºC
- 20ºC
Dropona hardwoodboardof 4cmthick,anydirections,6 times,
at theheightof 75cm.
Afterbeingappliedvibrationofamplitudeof 1.5mmwith 10 to 55 Hz
band of vibration frequency to each of 3 perpendiculardirections for
2hours .
Allowablevariationof SPLaftertest: 10dB.
Lead terminals are immersed in rosin for 5 seconds and then
immersedinsolderbathof+300 5ºCfor3 1seconds .
90% min. leadterminalsshallbewetwithsolder
(Excepttheedgeofterminals).
Theforceof 9.8N(1.0kg) isappliedtoeachterminalinaxialdirectionfor
10 seconds.
No visible damage and cutting off.
TEST CONDITION.
Standard Test Condition
一般测试条件
Judgment TestCondition
争议时测试条件
a) Temperature:+5~ +35℃
a) 温度 : +5 ~ +35℃
a) Temperature : +25 ± 2℃
a) 温度 : +25 ± 2℃
b) Humidity : 45-85%
b) 湿度 : 45-85%
b) Humidity : 60-70%
b) 湿度 : 60-70%
c) Pressure : 860-1060mbar
c) 气压 : 860-1060mbar
FSD-2316
很抱歉,暂时无法提供与“FSD-2316-24V”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+3.62500
- 30+3.50000
- 100+3.25000
- 500+3.00000
- 1000+2.87500
- 国内价格
- 1+6.03720
- 10+4.87080
- 30+4.28760
- 100+3.71520
- 500+3.31560
- 1000+3.13200
