Wire Wound Common Mode Choke
-YLM7060 Series
■ Features
● SMD construction,and low profile.
● High Impedance and Excelletn Frequency Characteristic.
● Self Electromagnetic Shielding.
● Low Magnetic Flux Leakage.
■ Applications
● LED Light,TV game,Monitor,etc.
● EMI common-mode noise.
■ Product Identification
⑴ :Type
⑵ :Dimensions
⑶ :Inductance value
⑷ :Taping
深圳市益嘉源电子有限公司
http://www.yjycoin.com
Tel:0755-27803896
Fax:0755-27803897
-1-
-YLM7060 Series
■ Shapes and Dimensions (Unit:mm)
TYPE
A
B
C Max
D Typ
E
F
G
YLM7060
7.0±0.5
6.0±0.5
3.8
3.5
1.5±0.5
1.5±0.5
1.7±0.5
■ Circuit Diagram
■ YLM7060 Series
Z (Ω)
DC
@100MHz/0.1V
Resistance
Min
Typ
(mΩ) Max.
YLM7060-400T
40
70
YLM7060-101T
100
YLM7060-301T
Rated Current
Rated Volt.
IR(MΩ)
(A) max.
(V)max.
min.
5
15.0
125
10
400
140
10
9.0
125
10
101
225
300
10
5.0
125
10
301
YLM7060-501T
275
350
10
5.0
125
10
501
YLM7060-601T
500
700
15
4.0
125
10
601
YLM7060-701T
500
700
15
4.0
125
10
701
YLM7060-102T
800
1020
17
3.0
125
10
102
YLM7060-132T
910
1300
21
2.5
125
10
132
YLM7060-272T
2000
2700
63
1.0
125
10
272
YLM7060-302T
2500
3000
75
0.9
125
10
302
Part Number
深圳市益嘉源电子有限公司
Tel:0755-27803896
Marking
Fax:0755-27803897
-2-
-YLM7060 Series
■ Materlal List
NO.
ITEM
DESCRIPTION
SUPPLIER
1
CORE
FERRITE
SINCORES OR EQ
2
WIRE
2UEW P180
ELEKTRISOLA OR EQ
3
BASE
LCP
LIANGCHENG OR EQ
4
SOLDER
Sn Cu
SHENMAO OR EQ
5
EPOXY
ME-5890
PENGNO OR EQ
6
INK
WHITE
BON MARK
■ Reliability Testing
Operating Temperature
- 30 to + 100 ℃ ( Contain Heating coil )
Appearance Inspection
No external defects by visual inspection
Terminal Strength
After soldering , between copper plaet and terminals
of coils , push in two directions of X , Y with
standing 10N(1.02kg) for10+/-2 sec.
Terminal should not peel off. ( Refer to figure at right )
Heat endurance of reflow
Refer to figure
soldering
Insulating resistance
Over 100 MΩ at 100V D.C . between wire and core .
Dielectric Strength
Apply at 0.5KV 3mA for 1 minute between wire and core .
Temperature
Inductance coefficient ( 0~2,000 ) × 10 / ℃( - 30 ~ + 100 ℃ )
characteristics
Humidity characteristics
Inductance deviation within ± 10% , after 96 hours in 90~95%
relative humidity at 40 ± 2 ℃ and 1 hours drying under normal condition .
A test is made under the above mentioned condition , and it is kept for 2 hours in the normal
深圳市益嘉源电子有限公司
Tel:0755-27803896
Fax:0755-27803897
-3-
-YLM7060 Series
■ Recommended soldering temp.Graph
■ Taping Dimensions(Unit:mm)
TYPE
W
A
B
D
P
K
T
MPQ
YLM7060
16.0±0.3
6.9±0.3
8.4±0.3
7.5±0.1
12±0.1
4.2±0.1
0.40±0.05
1500
深圳市益嘉源电子有限公司
Tel:0755-27803896
Fax:0755-27803897
-4-
-YLM7060 Series
■ Reel Dimensions(Unit:mm)
TYPE
W
W1
A
B
C
D
YLM7060
330±2.0
16.4±2.0
13.0±0.50
21.0±0.80
2.0±0.50
100Min
■ Direction of rolling
深圳市益嘉源电子有限公司
Tel:0755-27803896
Fax:0755-27803897
-5-
-YLM7060 Series
■ Cover tape peel off condition
Cover tape peel force shall be 0.1N to 1.3N.
Reference peel speed 300±10mm/min.
深圳市益嘉源电子有限公司
Tel:0755-27803896
Fax:0755-27803897
-6-
很抱歉,暂时无法提供与“YLM7060-301T”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+3.95280
- 10+3.18600
- 30+2.79720
- 100+2.41920
- 500+2.37600
- 1500+2.25720
