Additional Resources:
Product Page
3D Model
PCB Footprint
date
08/05/2022
page 1 of 4
MODEL: CMI-1210-92T | DESCRIPTION: MAGNETIC BUZZER INDICATOR
FEATURES
• 12 Vdc rated
• 92 dB
• through hole
SPECIFICATIONS
parameter
conditions/description
min
rated voltage
max
12
operating voltage
7
current consumption
at rated voltage
rated frequency
at rated voltage
sound pressure level
at 10 cm, rated voltage (A-weighted)
tone
continuous
dimensions
Ø12 x 9.5
2,250
2,400
87
92
Vdc
15
Vdc
35
mA
2,550
Hz
dBA
1.6
material
PBT (UL94V-0)
terminal
pins (tin plating)
operating temperature
storage temperature
washable
units
mm
weight
g
-40
85
°C
-40
85
°C
max
units
380
°C
250
°C
yes
RoHS
Notes:
typ
yes
1. All specifications measured at 5~35°C, humidity at 45~85%, under 86~106kPa pressure, unless otherwise noted.
SOLDERABILITY
parameter
min
hand soldering
maximum 2 seconds
330
wave soldering
see recommended wave soldering profile
Wave Solder Profile
3 Sec Max
250
2~5 °C/Sec
Temperature (°C)
130 °C/Sec
2~5 °C/Sec
110
25
40 Sec
60 Sec
Preheating
1.5
Sec Max
Melting
Time (sec)
cuidevices.com
100 Sec
Cooling
typ
Product Page
3D Model
PCB Footprint
CUI DEVICES | MODEL: CMI-1210-92T | DESCRIPTION: MAGNETIC BUZZER INDICATOR
date 08/05/2022 | page 2 of 4
MECHANICAL DRAWING
units: mm
tolerance: ±0.5 mm
&0,7
6RXQG
(PLVVLRQ
+ROH
5(029(
6($/
$)7(5
:$6+,1*
Positive electrode label
7ZRFRPSRQHQW
HSR[\
Recommended PCB Layout
Top View
PERFORMANCE CURVES
Voltage vs. Current Consumption
at 10 cm, 25°C
Current Consumption (mA)
Sound Pressure Level (dB)
Voltage vs. Sound Pressure Level
at 10 cm, 25°C
95
90
85
80
75
4
6
8 10 12 14
Voltage (Vdc)
30
25
10
4
16
cuidevices.com
6
8 10 12 14
Voltage (Vdc)
16
Product Page
3D Model
PCB Footprint
date 08/05/2022 | page 3 of 4
PACKAGING
units: mm
Tray Size: 184 x 180 x 23 mm
Carton Size: 445 x 405 x 320 mm
Tray QTY: 100 pcs per tray
Carton QTY: 6,000 pcs per carton
/RW1R
3DUW1R
4XDQWLW\
'DWH
[ 3&6
;;;;3FV
7UD\
很抱歉,暂时无法提供与“CMI-1210-92T”相匹配的价格&库存,您可以联系我们找货
