DATA SHEET
LOW OHMIC CHIP RESISTORS
RL series
5%, 2%, 1%
sizes 0402/0603/0805/1206/
1210/1218/2010/2512
Product specification – June 01, 2017 V.2
RoHS compliant & Halogen Free
Chip Resistor Surface Mount
RL
SCOPE
ORDERING INFORMATION - GLOBAL PART NUMBER & 12NC
This specification describes
RL0402 to RL2512 low ohmic chip
resistors with lead-free terminations
made by thick film process.
Both part numbers are identified by the series, size, tolerance, packing
type, temperature coefficient, taping reel and resistance value.
APPLICATIONS
Converters
RL XXXX X X X XX XXXX L
YAGEO BRAND ordering code
GLOBAL PART NUMBER (PREFERRED )
(1)
Printer equipment
Server board
Telecom
Consumer
F = ± 1%
Car electronics
G = ± 2%
Halogen Free Epoxy
RoHS compliant
Hazardous wastes
High component and
equipment reliability
Saving of PCB space
Non-forbidden materials used
in products/production
Low resistances applied to
current sensing
MSL Class: MSL 1
(2) (3) (4)
(5)
(6)
(7)
(1) SIZE
FEATURES
AEC-Q200 qualified
2
9
0402 to 2512
SERIES
0402 / 0603 / 0805 / 1206 / 1210 / 1218 / 2010 / 2512
(2) TOLERANCE
J = ± 5%
"-" = Jumper ordering
(3) PACKAGING TYPE
R = Paper taping reel
K = Embossed taping reel
(4) TEMPERATURE COEFFICIENT OF RESISTANCE
– = Based on spec
(5) TAPING REEL
07 = 7 inch dia. Reel and standard power
10 = 10 inch dia. Reel and standard power
13 = 13 inch dia. Reel and standard power
7W = 7 inch dia. Reel and 2 x standard power (0805 and 1206)
(6) RESISTANCE VALUE
There are 2~4 digits indicated the resistor value. Letter R/K/M is decimal point.
Detailed coding rules of resistance are shown in the table of “Resistance rule of global
part number”.
(7) DEFAULT CODE
Letter L is system default code for order only (Note)
Resistance rule of global part
number
Resistance code rule
Example
0RXXX
(1 to 976 mΩ)
XRXX
(1 to 9.76 Ω)
0R1 = 0.1 Ω
0R12 = 0.12 Ω
0R105 = 0.105 Ω
1R = 1 Ω
1R5 = 1.5 Ω
9R76 = 9.76 Ω
XXRX
(10 to 97.6 Ω)
10R = 10 Ω
97R6 = 97.6 Ω
XXXR
(100 to 976 Ω)
100R = 100 Ω
XKXX
(1 to 9.76 KΩ)
1K = 1,000 Ω
9K76 = 9760 Ω
XMXX
(1 to 9.76 MΩ)
1M = 1,000,000 Ω
9M76= 9,760,000 Ω
O RDERING EXAMPLE
The ordering code of a RL0603
chip resistor, value 0.56Ω with
± 1% tolerance, supplied in 7-inch
tape reel is: RL0603FR-070R56L.
NOTE
1. All our R-Chip products meet RoHS
compliant and Halogen Free. "LFP" of
the internal 2D reel label mentions
"Lead Free Process"
2. On customized label, "LFP" or
specific symbol can be printed
www.yageo.com
Jun. 01, 2017 V.2
RL
SERIES
3
9
0402 to 2512
PHYCOMP BRAND ordering codes
Both GLOBAL PART NUMBER (preferred) and 12NC (traditional) codes are acceptable to order Phycomp
brand products.
For detailed information of GLOBAL PART NUMBER and ordering example, please refer to page 2.
12NC CODE
2350 / 2390 / 2322
(1)
SIZE TYPE
Last digit of 12NC
XXX XXXXX L
(2)
(3)
(4)
START TOL. RESISTANCE
IN (1) (%) RANGE
Resistance decade (3)
EMBOSSED (2) PAPER/PE (2)
TAPE ON REEL TAPE ON REEL (units)
4,000
5,000
10,000
Last digit
0.01 to 0.0976Ω
0.1 to 0.976Ω
7
0402 LRC31
± 5% 0.05 to 1 Ω
1 to 9.76Ω
2350
513 20xxx
8
LRC32
± 1% 0.05 to 1 Ω
10 to 97.6Ω
2350
513 22xxx
9
0603 LRC21
2350
± 5% 0.01 to 1 Ω
100 to 976Ω
512 10xxx
1
LRC22
2350
± 1% 0.01 to 1 Ω
1 to 9.76 kΩ
512 12xxx
2
0805 LRC11
± 5% 0.01 to 1 Ω
10 to 97.6 kΩ
2350
511 10xxx
3
LRC12
± 1% 0.01 to 1 Ω
100 to 976 kΩ
2350
511 12xxx
4
LRC11P 2350
± 1% 0.01 to 1 Ω
1 to 9.76 MΩ
511 15xxx
5
LRC12P 2350
± 5% 0.01 to 1 Ω
10 to 97.6 MΩ
511 17xxx
6
Example:
0.02Ω
0200 or 200
0.3Ω
3007 or 307
1Ω
1008 or 108
33 kΩ
3303 or 333
10 MΩ =
1006 or 106
1206 LRC01
2350
± 5% 0.01 to 1 Ω
510 10xxx
LRC02
2350
± 1% 0.01 to 1 Ω
510 12xxx
LRC01P 2350
± 1% 0.01 to 1 Ω
519 01xxx
LRC02P 2350
± 5% 0.01 to 1 Ω
519 1xxxx
± 5% 0.01 to 0.0976 Ω -
735 90xxx
LPRC101 2390
± 5% 0.1 to 1 Ω
735 60xxx
O RDERING EXAMPLE
LPRC102 2390
± 1% 0.01 to 1 Ω
735 3xxxx
The ordering code of a RL0603 chip
1218 LPRC201 2322
± 5% 0.01 to 1 Ω
735 64xxx
LPRC201 2322
± 1% 0.01 to 1 Ω
resistor, value 0.56 Ω with ±1%
tolerance, supplied in tape of 5,000
units per reel is: 235051212567L or
RL0603FR-070R56L.
1210 LPRC101 2390
735 7xxxx
± 5% 0.01 to 0.0976 Ω 760 90xxx
LPRC111 2322
± 5% 0.1 to 1 Ω
760 60xxx
LPRC111 2322
± 1% 0.01 to 0.0976 Ω 761 90xxx
NOTE
LPRC111 2322
± 1% 0.1 to 1 Ω
761 6xxxx
± 5% 0.01 to 0.0976 Ω 762 90xxx
LPRC221 2322
± 5% 0.1 to 1 Ω
762 60xxx
"Lead Free Process"
LPRC221 2322
± 1% 0.01 to 0.0976 Ω 763 90xxx
LPRC221 2322
± 1% 0.1 to 1 Ω
2010 LPRC111 2322
2512 LPRC221 2322
763 6xxxx
2. On customized label, "LFP" or specific
(1) The resistors have a 12-digit ordering code starting with 2350/2390/2322.
(2) The subsequent 4 or 5 digits indicate the resistor tolerance and packaging. (In
12NC code, only 07'' tape reel code is supplied. Supply of 10''/13'' tape reel is
requested in Global part number ordering code.)
(3) The remaining 4 or 3 digits represent the resistance value with the last digit
indicating the multiplier as shown in the table of “Last digit of 12NC”.
(4) Letter L is system default code for order only
(Note)
www.yageo.com
Jun. 01, 2017 V.2
RL
SERIES
0402 to 2512
4
9
MARKING
RL0402 / RL0603: R
很抱歉,暂时无法提供与“RL2512FK070R03L”相匹配的价格&库存,您可以联系我们找货
