AS02704MS-N50-LW100-R
    PUIAUDIO
AS02704MS-N50-LW100-R 数据手册
This document contains data proprietary to PUI Audio Inc. Any use or reproduction, in any form, without prior written permission of PUI Audio Inc. is prohibited. ©2019, PUI Audio Inc. Data Sheet AS02704MS-N50-LW100-R Introducing the N50 Mini Speaker Series from PUI Audio. High-grade neodymium magnetic motors are employed in each N50 Series speaker to create the highest output possible, in the smallest form factor. The 27mm square frame AS02704MS-N50-LW100-R features a polymer cone, rubber surround, and a Poron gasket for an IP67 ingress protection rating. Add high fidelity sound to your product without sacrificing space with this bigsounding speaker that measures only 6.6mm thick! Features: • Polymer cone with rubber surround with Poron gasket for IP67 rating • High 79 dB output at 1W/50cm with full range sound • N50 neodymium motor and 100mm lead wires • Only 6.6 mm thick with 1.5 mm of excursion Specifications Parameters Rated Input Power Max Input Power Impedance Sensitivity (SPL @ 1W/50cm) (800, 1000, 1200, and 1500 Hz) Resonant Frequency Frequency Range Housing Material Magnet Material Weight Environmental Protection Rating Values 2 3 4 ± 15% Units Watts Watts Ohms 79 ± 3 350 ± 20% 300 ~ 20,000 PBT NdFeB 9 IP67 dBA Hz Hz Grams - PUI Audio, Inc., 3541 Stop Eight Road, Dayton, OH 45414 Tel: (937) 415-5901 Fax: (937) 415-5925 This document contains data proprietary to PUI Audio Inc. Any use or reproduction, in any form, without prior written permission of PUI Audio Inc. is prohibited. ©2019, PUI Audio Inc. Specifications (continued) Should not be audible with 4Vpk sine wave from 500 Hz to 10 kHz When positive voltage is applied to the positive terminal, the diaphragm will move outward Buzz, Rattle, etc. Polarity Operating Temperature Storage Temperature -20 ~ +60 -25 ~ +60 Measurement Method Test Baffle (speaker mounted in circle) PUI Audio, Inc., 3541 Stop Eight Road, Dayton, OH 45414 Tel: (937) 415-5901 Fax: (937) 415-5925 °C °C This document contains data proprietary to PUI Audio Inc. Any use or reproduction, in any form, without prior written permission of PUI Audio Inc. is prohibited. ©2019, PUI Audio Inc. Frequency Response (measured at 50cm with 1W input power) Reliability Testing Type of Test High Temperature Test Low Temperature Test Humidity Test Temperature Cycle Testing Vibration Test Drop Test Load Test Test Specifications 96 hours at +70°C ± 3°C followed by six hours in normal room temperature 96 hours at -30°C ± 3°C followed by six hours in normal room temperature 96 hours at +30°C ± 3°C with relative humidity at 92% to 95% followed by 3 hours in normal room temperature The part shall be subjected to 5 cycles using the following procedure: 10 to 55 to 10 Hz cycles, 15 minutes per cycle. 2 hours in each axis X, Y, and Z. Drop the speakers onto a 40mm thick board 10 times from a height of 75cm. Pink noise is applied at the speakers rated power for 96 hours at room temperature After each test, the speaker’s SPL shall be ±3 dB of the original SPL PUI Audio, Inc., 3541 Stop Eight Road, Dayton, OH 45414 Tel: (937) 415-5901 Fax: (937) 415-5925 This document contains data proprietary to PUI Audio Inc. Any use or reproduction, in any form, without prior written permission of PUI Audio Inc. is prohibited. ©2019, PUI Audio Inc. Dimensions (Tolerances are ±0.5mm unless otherwise noted) Packaging (in cm) PUI Audio, Inc., 3541 Stop Eight Road, Dayton, OH 45414 Tel: (937) 415-5901 Fax: (937) 415-5925 This document contains data proprietary to PUI Audio Inc. Any use or reproduction, in any form, without prior written permission of PUI Audio Inc. is prohibited. ©2019, PUI Audio Inc. Revision A B C Specifications Revisions Description Released from Engineering Revised gasket material and Storage Temperature Revised IP rating to IP67 Revised gasket material to Poron Note: 1. Unless otherwise specified: A. All dimensions are in millimeters. B. Default tolerances are ±0.5mm and angles are ±3°. 2. Specifications subject to change or withdrawal without notice. 3. This part is RoHS 2011/65/EU Compliant. PUI Audio, Inc., 3541 Stop Eight Road, Dayton, OH 45414 Tel: (937) 415-5901 Fax: (937) 415-5925 Date 3/21/2018 5/21/2019 6/10/2019 3/4/2020
AS02704MS-N50-LW100-R 价格&库存
很抱歉,暂时无法提供与“AS02704MS-N50-LW100-R”相匹配的价格&库存,您可以联系我们找货
  • 1+71.369081+9.27995
