X62D-AB-5P8(30)
X62D-AB-5P8(30)
    HRS(广濑)
    X62D-AB-5P8(30)
X62D-AB-5P8(30) 数据手册
APPLICABLE STANDARD OPERATING TEMPERATURE RANGE USB2.0 SPECIFICATION AND MICRO-USB CABLE AND CONNECTORS SPECIFICATION. -30C TO +85C STORAGE TEMPERATURE RANGE RATING 30 V AC VOLTAGE Jan.1.2023 Copyright 2023 HIROSE ELECTRIC CO., LTD. All Rights Reserved. In case of consideration for using Automotive equipment / device which demand high reliability, kindly contact our sales window correspondents. -30C TO +60 C SIGNAL ONLY CURRENT POWER APPLY 1.0 A/pin 1.8 A/pin (PIN No.1,No.5) 0.5 A/pin (PIN No.2-No.4) SPECIFICATIONS ITEM TEST METHOD REQUIREMENTS QT AT ACCORDING TO DRAWING. X X X X CONTACT RESISTANCE 100 mA (DC OR 1000 Hz). 30 m MAX. X X INSULATION RESISTANCE VOLTAGE PROOF 500 V DC. 1000 M MIN. X X 100 V AC FOR 1 min. NO FLASHOVER OR BREAKDOWN. X X MEASURE ADJACENT TWO CONTACTS AT 1000±10 Hz AC VOLTAGE. 2 pF MAX. X - X - X - X - X - X - X - X - X - X - X - CONSTRUCTION GENERAL EXAMINATION VISUALLY AND BY MEASURING INSTRUMENT. MARKING CONFIRMED VISUALLY. ELECTRIC CHARACTERISTICS CAPASITANCE MECHANICAL CHARACTERISTICS INSERTION AND WITHDRAWAL FORCES MECHANICAL OPERATION VIBRATION RANDOM VIBRATION SHOCK A MAXIMUM RATE OF 12.5 mm/min. MEASURED BY APPLICABLE CONNECTOR. INSERTION FORCE 35 N MAX. WITHDRAWAL FORCE 8 N MIN. 1) CONTACT RESISTANCE: NO INCREASE 10000 TIMES INSERTIONS AND EXTRACTIONS. OF MORE THAN 10 m FROM INITIAL VALUE. MATING SPEED 2) INSERTION FORCE 35 N MAX. - MECHANICALLY OPERATED: 500 CYCLES / h WITHDRAWAL FORCE 8 N MIN. OR 3) NO DAMAGE, CRACK AND - MANUALLY OPERATED: 200 CYCLES / h LOOSENESS, OF PARTS. FREQUENCY 10 TO 55 Hz 1) NO ELECTRICAL DISCONTINUITY OF SINGLE AMPLITUDE 0.75 mm, AT 2h 1 s. FOR 3 AXIAL DIRECTIONS, TOTAL 6h. 2) NO DAMAGE, CRACK AND LOOSENESS, OF PARTS. FREQUENCY 50 TO 2000 Hz AT 15 min FOR 3 AXIAL DIRECTIONS. 2 490m/s DURATIONS OF PULSE 11 ms AT 3 TIMES FOR 6 DIRECTIONS, TOTAL 18 TIMES. ENVIRONMENTAL CHARACTERISTICS TEMP -55 →+15 TO +35→+85→+15TO+35 C TIME 30 → 2 TO 3 → 30→ 2 TO 3 min THERMAL SHOCK UNDER 10 CYCLES. (MATING APPLICABLE CONNECTOR) TEMPERATURE -10~65 C, HUMIDITY 90 TO HUMIDITY LIFE 98 , UNDER 7 CYCLES (168 h) (MATING APPLICABLE CONNECTOR) EXPOSED AT 85±2 C , 96 h. DRY HEAT (MATING APPLICABLE CONNECTOR) EXPOSED AT -40±2 C , 96 h. COLD (MATING APPLICABLE CONNECTOR) EXPOSED AT 5  SALT WATER, 35 C, CORROSION SALT MIST FOR 48h. (LEFT UNDER UNMATED CONDITION.) COUNT DESCRIPTION OF REVISIONS 1) CONTACT RESISTANCE: 70 m MAX. 2) INSULATION RESISTANCE: 10 M MIN. 3) NO DAMAGE, CRACK AND LOOSENESS, OF PARTS. NO DAMAGE, CRACK AND LOOSENESS, OF PARTS. NO DAMAGE, CRACK AND LOOSENESS, OF PARTS. NO DAMAGE, CRACK AND LOOSENESS, OF PARTS. NO HEAVY CORROSION OF CONTACTS. DESIGNED CHECKED DATE △ 0 REMARK APPROVED HIROSE will not guarantee the performance on these specifications in CHECKED case this product will be mated with the others which is not DESIGNED HIROSE’s. Unless otherwise specified, refer to USB2.0, EIA364 or IEC 60512. Note QT:Qualification Test FORM HD0011-2-1 AT:Assurance Test X:Applicable Test DRAWN DRAWING NO. SPECIFICATION SHEET PART NO. HIROSE ELECTRIC CO., LTD. CODE NO. NM.NISHIMATSU 15.10.27 KN.ICHIKAWA 15.10.27 TS.ITO 15.10.27 AK.AKIYAMA 15.10.27 ELC-126264-30-00 ZX62D-AB-5P8(30) CL242-0027-5-30 0 1/2 △ SPECIFICATIONS Jan.1.2023 Copyright 2023 HIROSE ELECTRIC CO., LTD. All Rights Reserved. In case of consideration for using Automotive equipment / device which demand high reliability, kindly contact our sales window correspondents. ITEM SOLDERABILITY RESISTANCE TO SOLDERING HEAT TEST METHOD SOLDERING POINT IMMERSED IN SOLDER BATH OF 255±5C, 5 sec. (USING TYPE R FLAX) A PROFILE IS SHOWN IN FIG-1, UNDER 2 CYCLES. REQUIREMENTS SOLDER SHALL COVER MINIMUM OF 95% OF THE SURFACE BEING IMMERSED NO DAMAGE, CRACK AND LOOSENESS, OF PARTS. QT AT X - X - FIG – 1 RESISTANCE TO SOLDERING HEAT (TEMPERATURE AT TOP SURFACE OF CONNECTOR) RECOMMENDED PROFILE REFERS TO FIG – 2. (TEMPERATURE AT SMT LEADS) FIG – 2 Note QT:Qualification Test FORM HD0011-2-2 RECOMMENDED REFLOW PROFILE TEMPERATURE AT:Assurance Test X:Applicable Test DRAWING NO. SPECIFICATION SHEET PART NO. HIROSE ELECTRIC CO., LTD. CODE NO ELC-126264-30-00 ZX62D-AB-5P8(30) CL242-0027-5-30 △ 0 2/2
X62D-AB-5P8(30) 价格&库存
很抱歉,暂时无法提供与“X62D-AB-5P8(30)”相匹配的价格&库存,您可以联系我们找货
