TS2937CW33 RPG
TS2937CW33 RPG
    TAIWANSEMICONDUCTOR(台湾半导体)
    TS2937CW33 RPG
TS2937CW33 RPG 数据手册
TS2937 Taiwan Semiconductor 500mA Ultra Low Dropout Voltage Regulator DESCRIPTION FEATURES TS2937 of fixed-voltage monolithic micro-power voltage This device excellent choice of use in battery-power ● ● ● Dropout voltage typically 0.6V @ Io=500mA Output voltage trimmed before assembly -18V Reverse peak voltage application. current ● +30V Input over voltage protection increases on slightly at dropout, which prolongs battery ● ● ● +60V Transient peak voltage Internal current limit Thermal shutdown protection regulators is designed for a wide range of applications. Furthermore, the quiescent life. This series of fixed-voltage regulators features very low ground current (200uA Typ.) and very low drop output voltage (Typ. 60mV at light load and 600mV at 500mA). This includes a tight initial tolerance of 2%, APPLICATION extremely good line regulation of 0.05% typ., and very ● Post Regulator for SMPS low output temperature coefficient. ● Industrial Instrumentation TO-220 2 TO-263 (D PAK) TO-252 (DPAK) SOT-223 Pin Definition: 1. Input 2. Ground 3. Output Notes: Moisture sensitivity level: level 3. Per J-STD-020 TYPICAL APPLICATION CIRCUIT Document Number: DS_P0000215 1 Version: E15 TS2937 Taiwan Semiconductor ABSOLUTE MAXIMUM RATINGS (Note 1) PARAMETER Input Supply Voltage SYMBOL LIMIT UNIT VIN -18 ~ +60 V VOPR 26 V PD Internally Limited (Note 2) Operation Input Supply Voltage (Note 3) Power Dissipation Operating Junction Temperature Range TJ TSTG Storage Temperature Range W -40 ~ +125 o -65 ~ +150 o C C THERMAL PERFORMANCE PARAMETER LIMIT SYMBOL UNIT TO-220 TO-263 TO-252 SOT-223 RӨJA Junction to Ambient Thermal Resistance 60 80 150 170 °C/W Notes: RӨJA is the sum of the junction-to-case and case-to-ambient thermal resistances. The case thermal reference is defined at the solder mounting surface of the drain pins. RӨJA is guaranteed by design while RӨCA is determined by the user’s board design. RӨJA shown below for single device operation on FR-4 PCB in still air. ELECTRICAL SPECIFICATIONS (VIN=VOUT+1V, IL=5mA, CO=10uF, TA=25oC, unless otherwise noted) PARAMETER CONDITIONS MIN TYP MAX 0.980|Vo| 12 / 10 1.020|Vo| 0.970|Vo| 5.0 / 3.3 1.030|Vo| Input Supply Voltage -- -- 26 V Output Voltage Temperature Coefficient -- 50 150 ppm/ C 5mA ≤ IL ≤ 500mA, Output Voltage Vo+1V ≤ VIN≤ 26V UNIT V o Line Regulation Vo+1V ≤ VIN ≤ 26V -- 0.05 0.5 % Load Regulation 5mA ≤ IL ≤ 500mA -- 0.2 1.0 % IL=100mA -- 100 300 IL=300mA -- 400 500 IL=500mA -- 600 700 IL=100µA -- 200 -- IL=300mA -- 12 -- IL=500mA -- 25 -- VOUT =0 -- -- 1.3 CL=2.2µF -- 500 -- CL=3.3µF -- 350 -- CL=33µF -- 120 -- Dropout Voltage (Note 4) Quiescent Current (Note 5) Short Circuit Current (Note 6) Output Noise, 10Hz to 100KHz, IL=10mA Document Number: DS_P0000215 2 mV µA mA A µVrms Version: E15 TS2937 Taiwan Semiconductor ELECTRICAL SPECIFICATIONS Note: 1. Absolute Maximum Rating is limits beyond which damage to the device may occur. For guaranteed specifications and test conditions see the electrical characteristics. 2. Maximum positive supply voltage of 60V must be limited duration (
TS2937CW33 RPG 价格&库存
很抱歉,暂时无法提供与“TS2937CW33 RPG”相匹配的价格&库存,您可以联系我们找货
