CMM-4030DT-26154-TR
CMM-4030DT-26154-TR
    CUIDEVICES
    MIC-8P_3X4MM_SM
    CMM-4030DT-26154-TR
CMM-4030DT-26154-TR 数据手册
Additional Resources: Product Page | 3D Model | PCB Footprint date 08/05/2022 page 1 of 6 MODEL: CMM-4030DT-26154-TR | DESCRIPTION: MEMS MICROPHONE FEATURES • digital (PDM) • small package • reflow solder compatible • omnidirectional ELECTRICAL parameter conditions/description directivity omnidirectional sensitivity (S) at 94 dB SPL, 1 kHz supply voltage (VDD) min typ max units -27 -26 -25 dB FS 1.6 2.0 3.6 V current consumption (IDD) sensitivity reduction VDD = 3.6 ~ 1.6 V frequency (f) 0.54 mA -0.5 dB FS 100 10,000 65 Hz signal to noise ratio (S/N) at 94 dB SPL, 1 kHz (A-weighted) dBA total harmonic distortion (THD) at 94 dB SPL, 1 kHz 0.2 % acoustic overload point (AOP) at 10% THD, 1 kHz 120 dB SPL output impedance (Zout) at 1 kHz power supply rejection (PSR) 100 mVp-p square wave at 217 Hz (A-weighted) 300 -90 Ω dB FS DIGITAL INTERFACE parameter conditions/description sleep current (ISLEEP) FCLOCK < 1 kHz fall-asleep time FCLOCK < 1 kHz wake-up time FCLOCK ≥ 1 MHz short circuit current (ISC) grounded data pin min typ 3 1 output load (CLOAD) data format max units 4 µA 50 µs 52 ms 10 mA 100 pF 3.2 MHz 1-Bit PDM clock frequency (FCLOCK) 1.0 clock duty cycle (FDC) 40 clock rise time (tCR) clock fall time (tCF) 2.4 60 % 10 ns 10 ns logic input/output low (VIOL) IOUT = 1 mA -0.30 0.35xVDD V logig input/output high (VIOH) IOUT = 1 mA 0.65xVDD VDD+0.3 V delay time for valid data (tDV) 18 60 ns delay time for high z (tDH) 0 16 ns Notes: 1. All specifications measured at 23±2°C, humidity at 55±20%, VDD = 2.0 V, FCLOCK = 2.4 MHz, unless otherwise noted. cuidevices.com Additional Resources: Product Page | 3D Model | PCB Footprint CUI DEVICES | MODEL: CMM-4030DT-26154-TR | DESCRIPTION: MEMS MICROPHONE date 08/05/2022 | page 2 of 6 TIMING CHARACTERISTICS 1/FCLOCK tCF tCR VOH CLOCK VOL tDV tDH DATA (SELECT=VDD) Mic(High) Data Mic(High) Data tDV DATA (SELECT=Gnd) Mic(Low) Data Microphone Select (L/R) High Z tDH Mic(Low) Data High Z Asserts Data On Latch Data On Mic (High) VDD rising clock edge falling clock edge Mic (Low) GND falling clock edge rising clock edge RECOMMENDED INTERFACE CIRCUIT Vdd Vdd Vdd X) X) X) Select (L/R) Select (L/R) Select (L/R) Mic (High) Mic (Low) Mic (Low) Vdd Vdd Gnd Data Clock Vdd Gnd Data Clock Vdd Codec Codec Single MIC Double MIC cuidevices.com Additional Resources: Product Page | 3D Model | PCB Footprint CUI DEVICES | MODEL: CMM-4030DT-26154-TR | DESCRIPTION: MEMS MICROPHONE date 08/05/2022 | page 3 of 6 ENVIRONMENTAL parameter conditions/description min operating temperature storage temperature in packaging RoHS yes max units -40 typ 105 °C -40 85 °C max units MECHANICAL parameter conditions/description dimensions 4.00 x 3.00 x 1.00 acoustic port top terminals surface mount min typ mm weight 0.024 g MECHANICAL DRAWING units: mm tolerance: ±0.1 mm f  TERMINAL CONNECTIONS DATA 5 GND 6 GND 7 GND 8 GND ļ ľ ķ ĺ Ļ     Ľ ļ ĺķ       Ĺĸ ľ Ļ    Recommended Vacuum Nozzle Pickup Top View cuidevices.com  4 ĸ Ĺ Recommended PCB Layout Top View  L/R CLOCK  2 3 Ľ  VDD  FUNCTION 1  TERM. Additional Resources: Product Page | 3D Model CUI DEVICES | MODEL: CMM-4030DT-26154-TR | DESCRIPTION: MEMS MICROPHONE FREQUENCY RESPONSE CURVE cuidevices.com | PCB Footprint date 08/05/2022 | page 4 of 6 Additional Resources: Product Page | 3D Model | PCB Footprint CUI DEVICES | MODEL: CMM-4030DT-26154-TR | DESCRIPTION: MEMS MICROPHONE date 08/05/2022 | page 5 of 6 SOLDERABILITY parameter conditions/description reflow soldering see reflow profile Note: min typ max units 260 °C max units 85 °C 1. Vacuuming over acoustical hole is not allowed. 2. Not suitable for wash process. 3. Not recommended to exceed 5 reflow cycles. 20~40 s 260 Temperature (°C) 3°C/s max ramp up 6°C/s max ramp down 217 60~150 s 200 150 60~180 s 25 480 s max Time (sec) PACKAGING parameter conditions/description min reel storage at relative humidity
CMM-4030DT-26154-TR
物料型号:CMM-4030DT-26154-TR
器件简介:MEMS麦克风,具有数字(PDM)输出,小尺寸封装,回流焊兼容,全向性。
引脚分配: - 1:VDD(电源) - 2:L/R(选择左右声道) - 3:CLOCK(时钟) - 4:DATA(数据) - 5:GND(地) - 6-8:GND(地,共4个接地点)
参数特性: - 工作电压:1.6V至3.6V - 工作电流:0.54mA - 灵敏度:-26dB FS(1kHz,94dB SPL) - 信噪比:65dBA(1kHz,A加权) - 总谐波失真:0.2%(94dB SPL,1kHz) - 频率响应:100Hz至10kHz - 输出阻抗:300Ω(1kHz)
功能详解: - 麦克风具有全向性,适用于各种环境。 - 支持数字PDM接口,适用于数字音频系统。 - 具有低功耗特性,适合电池供电设备。
应用信息: - 适用于需要高质量音频输入的设备,如智能手机、笔记本电脑、会议系统等。
封装信息: - 尺寸:4.00mm x 3.00mm x 1.00mm - 重量:0.024g - 表面贴装封装
环境参数: - 工作温度:-40°C至105°C - 存储温度:-40°C至85°C
焊接信息: - 回流焊接温度:最高260°C - 不适用于清洗过程,不建议超过5次回流周期。
包装信息: - 卷装存储:相对湿度小于75% - 卷装大小:最大170mm - 卷装数量:每卷1000个
修订历史: - 1.0:2018年11月12日首次发布 - 1.01:2020年1月16日品牌更新 - 1.02:2022年5月26日修改外壳,增加高度公差 - 1.03:2022年8月5日更新标志,数据手册样式
CMM-4030DT-26154-TR 价格&库存
很抱歉,暂时无法提供与“CMM-4030DT-26154-TR”相匹配的价格&库存,您可以联系我们找货
