DTC114ECA /124ECA/143ECA/144ECA
Digital Transistor
DTC(R1=R2 SERIES)CA
FEATURES
Pb
z
Epitaxial planar die construction.
z
Complementary PNP types available(DTA).
z
Built-in biasing resistors,R1=R2.
z
Also available in lead free version.
Lead-free
APPLICATIONS
z
The NPN style digital transistor.
SOT-23
ORDERING INFORMATION
Type No.
Marking
Package Code
DTC114ECA
DTC124ECA
DTC143ECA
DTC144ECA
24
25
23
26
SOT-23
SOT-23
SOT-23
SOT-23
MAXIMUM RATING @ Ta=25℃ unless otherwise specified
Symbol
Parameter
Value
Units
VCC
Supply Voltage
50
V
DTC114ECA
DTC124ECA
DTC143ECA
DTC144ECA
-10 to+40
-10 to+40
-10 to+30
-10 to+40
V
DTC114ECA
DTC124ECA
DTC143ECA
DTC144ECA
50
30
100
100
mA
ALL
100
mA
Input Voltage
VIN
Output Current
IO
IC(Max.)
Output current
PD
Power Dissipation
200
mW
RθJA
Thermal Resistance, Junction to Ambient Air
625
℃/W
Tj,Tstg
Operating and Storage and Temperature Range
-55 to +150
www.slkormicro.com
1
ELECTRICAL CHARACTERISTICS @ Ta=25℃ unless otherwise specified
Parameter
Symbol
Test conditions
MIN
TYP
MAX
Input Voltage
VI(off)
VCC=5V,IO=100μA
0.5
1.1
VI(on)
VO=0.3V,IO=10mA
VO=0.2V,IO=5mA
VO=0.3V,IO=20mA
VO=0.3V,IO=2mA
1.9
3
VO(on)
Io/II=10mA/0.5mA,
0.1
0.3
V
mA
μA
Input Voltage
DTC114ECA
DTC124ECA
DTC143ECA
DTC144ECA
Output Voltage
Input Current
DTC114ECA
DTC124ECA
DTC143ECA
DTC144ECA
Output Current
DC Current Gain
Input Resistor
DTC114ECA
DTC124ECA
DTC143ECA
DTC144ECA
DTC114ECA
DTC124ECA
DTC143ECA
DTC144ECA
II
VI=5V
0.88
0.36
1.8
0.18
IO(off)
VCC=50V,VI=0V
0.5
GI
VO=5V,IO=5mA
VO=5V,IO=5mA
VO=5V,IO=10mA
VO=5V,IO=5mA
30
56
7
15.4
3.29
32.9
10
22
4.7
47
13
28.6
6.11
61.1
R1(R2)
Resistance Ratio
R2/R1
0.8
1
1.2
Gain-Bandwidth Product
fT
VCE=10V,IE=-5mA,
f=100MHz
250
TYPICAL CHARACTERISTICS @ Ta=25℃ unless otherwise specified
www.slkormicro.com
2
UNIT
V
kΩ
MHz
PACKAGE OUTLINE
Plastic surface mounted package
SOT-23
SOT-23
A
Dim
Min
Max
A
2.70
3.10
B
1.10
1.50
E
K
B
C
1.0 Typical
D
0.4 Typical
E
0.35
0.48
G
1.80
2.00
H
0.02
0.1
J
D
G
J
H
C
K
0.1 Typical
2.20
2.60
All Dimensions in mm
SOLDERING FOOTPRINT
0.95
0.95
2.00
0.90
0.80
PACKAGE
Unit : mm
INFORMATION
Device
Package
Shipping
DTC114ECA/124ECA/143ECA/144ECA
SOT-23
3000/Tape&Reel
www.slkormicro.com
3
很抱歉,暂时无法提供与“DTC114ECA”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 3000+0.08424
- 9000+0.08073
- 27000+0.07863
- 36000+0.07722
