S-5731NNL2-M3T2U
S-5731NNL2-M3T2U
    ABLIC(艾普凌科)
    SOT23-3
    霍尔效应开关
S-5731NNL2-M3T2U 数据手册
S-5731 Series www.ablic.com www.ablicinc.com HIGH-WITHSTAND VOLTAGE HIGH-SPEED UNIPOLAR DETECTION TYPE HALL EFFECT SWITCH IC Rev.1.1_01 © ABLIC Inc., 2014-2017 This IC, developed by CMOS technology, is a unipolar detection type Hall effect switch IC with high-withstand voltage, highspeed detection and high-accuracy magnetic characteristics. The output voltage changes when this IC detects the intensity level of magnetic flux density. Using this IC with a magnet makes it possible to detect the open / close and rotation status in various devices. This IC includes an output current limit circuit. High-density mounting is possible by using the small SOT-23-3 package. Due to its high-accuracy magnetic characteristics, this IC can make operation's dispersion in the system combined with magnet smaller. ABLIC Inc. offers a "magnetic simulation service" that provides the ideal combination of magnets and our Hall effect ICs for customer systems. Our magnetic simulation service will reduce prototype production, development period and development costs. In addition, it will contribute to optimization of parts to realize high cost performance. For more information regarding our magnetic simulation service, contact our sales office.  Features  Pole detection*1:  Output logic*1:  Output form*1: *1  Magnetic sensitivity :  Chopping frequency:  Output delay time:  Power supply voltage range:  Built-in regulator  Built-in output current limit circuit  Operation temperature range:  Lead-free (Sn 100%), halogen-free Detection of S pole, detection of N pole Active "L", active "H" Nch open-drain output, Nch driver  built-in pull-up resistor BOP = 3.0 mT typ., BOP = 6.0 mT typ. fC = 250 kHz typ. tD = 16.0 s typ. VDD = 3.5 V to 26.0 V Ta = 40C to 85C *1. The option can be selected.  Applications  Home appliance  DC brushless motor  Housing equipment  Industrial equipment  Package  SOT-23-3 1 HIGH-WITHSTAND VOLTAGE HIGH-SPEED UNIPOLAR DETECTION TYPE HALL EFFECT SWITCH IC Rev.1.1_01 S-5731 Series  Block Diagrams 1. Nch open-drain output product VDD OUT Regulator Chopping stabilized amplifier *1 Output current limit circuit VSS *1. Parasitic diode Figure 1 2. Nch driver  built-in pull-up resistor product VDD OUT Regulator Chopping stabilized amplifier Output current limit circuit VSS *1. Parasitic diode Figure 2 2 *1 HIGH-WITHSTAND VOLTAGE HIGH-SPEED UNIPOLAR DETECTION TYPE HALL EFFECT SWITCH IC Rev.1.1_01 S-5731 Series  Product Name Structure 1. Product name S-5731 x x x x - M3T2 U Environmental code U: Lead-free (Sn 100%), halogen-free Package abbreviation and packing specifications*1 M3T2: SOT-23-3, Tape Magnetic sensitivity 1: BOP = 3.0 mT typ. 2: BOP = 6.0 mT typ. Output logic L: Active "L" H: Active "H" Pole detection S: Detection of S pole N: Detection of N pole Output form N: Nch open-drain output R: Nch driver  built-in pull-up resistor *1. Refer to the tape drawing. 2. Package Table 1 Package Name SOT-23-3 3. Package Drawing Codes Dimension MP003-C-P-SD Tape MP003-C-C-SD Reel MP003-Z-R-SD Product name list Table 2 Product Name Output Form Pole Detection S pole S-5731NSL1-M3T2U Nch open-drain output S pole S-5731NSL2-M3T2U Nch open-drain output N pole S-5731NNL2-M3T2U Nch open-drain output S-5731RSL1-M3T2U Nch driver  built-in pull-up resistor S pole Remark Please contact our sales office for products other than the above. Output Logic Active "L" Active "L" Active "L" Active "L" Magnetic Sensitivity (BOP) 3.0 mT typ. 6.0 mT typ. 6.0 mT typ. 3.0 mT typ. 3 HIGH-WITHSTAND VOLTAGE HIGH-SPEED UNIPOLAR DETECTION TYPE HALL EFFECT SWITCH IC Rev.1.1_01 S-5731 Series  Pin Configuration 1. SOT-23-3 Top view Table 3 1 2 Pin No. 3 Symbol Description 1 VSS GND pin 2 VDD Power supply pin 3 OUT Output pin Figure 3  Absolute Maximum Ratings Table 4 Item Symbol Power supply voltage Output current Nch open-drain output product Output voltage Nch driver  built-in pull-up resistor product Operation ambient temperature Storage temperature Caution (Ta = 25C unless otherwise specified) Absolute Maximum Rating Unit VDD IOUT VOUT Topr Tstg VSS  0.3 to VSS  28.0 20 VSS  0.3 to VSS  28.0 VSS  0.3 to VDD  0.3 40 to 85 40 to 125 V mA V V C C The absolute maximum ratings are rated values exceeding which the product could suffer physical damage. These values must therefore not be exceeded under any conditions.  Thermal Resistance Value Table 5 Item Condition Board A Board B Junction-to-ambient thermal resistance*1 SOT-23-3 JA Board C Board D Board E *1. Test environment: compliance with JEDEC STANDARD JESD51-2A Remark 4 Symbol Refer to " Power Dissipation" and "Test Board" for details. Min.      Typ. 200 165    Max.      Unit C/W C/W C/W C/W C/W HIGH-WITHSTAND VOLTAGE HIGH-SPEED UNIPOLAR DETECTION TYPE HALL EFFECT SWITCH IC Rev.1.1_01 S-5731 Series  Electrical Characteristics Table 6 Item Symbol Power supply voltage VDD Current consumption IDD Output voltage VOUT Output drop voltage VD Leakage current ILEAK Output limit current Output delay time Chopping frequency Start up time IOM tD fC tPON Output rise time tR Output fall time Pull-up resistor (Ta = 25C, VDD = 12.0 V, VSS = 0 V unless otherwise specified) Test Condition Min. Typ. Max. Unit Circuit tF RL  Nch open-drain output product Average value Nch driver  built-in pull-up resistor product Average value, VOUT = "H" Nch open-drain output product Output transistor Nch, VOUT = "L", IOUT = 10 mA Nch driver  built-in pull-up resistor product Output transistor Nch, VOUT = "L", IOUT = 10 mA Nch driver  built-in pull-up resistor product VOUT = "H", VD = VDD  VOUT Nch open-drain output product Output transistor Nch, VOUT = "H" = 26.0 V VOUT = 12.0 V    Nch open-drain output product C = 20 pF, R = 820  Nch driver  built-in pull-up resistor product C = 20 pF C = 20 pF, R = 820  Nch driver  built-in pull-up resistor product 3.5 12.0 26.0 V   3.0 4.0 mA 1  3.0 4.0 mA 1   0.4 V 2   0.5 V 2   20 mV 2   10 A 3 22     16.0 250 30 70    mA s kHz s 3   4   2.0 s 5   6.0 s 5  7  10 2.0 13 s k 5  S pole Magnetic flux density applied to this IC (B) BOPS BRPS 0 tD tD tF tR 90% Output voltage (VOUT) (Product with S pole detection and active "L") 10% tD tD tR tF 90% Output voltage (VOUT) (Product with S pole detection and active "H") 10% Figure 4 Operation Timing 5 HIGH-WITHSTAND VOLTAGE HIGH-SPEED UNIPOLAR DETECTION TYPE HALL EFFECT SWITCH IC Rev.1.1_01 S-5731 Series  Magnetic Characteristics 1. Product with S pole detection 1. 1 Product with BOP = 3.0 mT typ. Table 7 (Ta = 25C, VDD = 12.0 V, VSS = 0 V unless otherwise specified) Item Operation point*1 S pole Release point*2 S pole Hysteresis width*3 S pole 1. 2 Symbol BOPS BRPS BHYSS Condition   BHYSS = BOPS  BRPS Min. 1.5 1.0  Typ. 3.0 2.0 1.0 Max. 4.5 3.3  Unit mT mT mT Test Circuit 4 4 4 Product with BOP = 6.0 mT typ. Table 8 (Ta = 25C, VDD = 12.0 V, VSS = 0 V unless otherwise specified) Item Operation point*1 S pole Release point*2 S pole Hysteresis width*3 S pole 2. Symbol BOPS BRPS BHYSS Condition   BHYSS = BOPS  BRPS Min. 3.0 2.5  Typ. 6.0 4.5 1.5 Max. 9.0 7.5  Unit mT mT mT Test Circuit 4 4 4 Product with N pole detection 2. 1 Product with BOP = 6.0 mT typ. Table 9 (Ta = 25C, VDD = 12.0 V, VSS = 0 V unless otherwise specified) Item Operation point*1 N pole *2 Release point N pole Hysteresis width*3 N pole Symbol BOPN BRPN BHYSN Condition   BHYSN = BOPN  BRPN Min. 9.0 7.5  Typ. 6.0 4.5 1.5 Max. 3.0 2.5  Unit mT mT mT Test Circuit 4 4 4 *1. BOPN, BOPS: Operation points BOPN and BOPS are the values of magnetic flux density when the output voltage (VOUT) changes after the magnetic flux density applied to this IC by the magnet (N pole or S pole) is increased (by moving the magnet closer). Even when the magnetic flux density exceeds BOPN or BOPS, VOUT retains the status. *2. BRPN, BRPS: Release points BRPN and BRPS are the values of magnetic flux density when the output voltage (VOUT) changes after the magnetic flux density applied to this IC by the magnet (N pole or S pole) is decreased (the magnet is moved further away). Even when the magnetic flux density falls below BRPN or BRPS, VOUT retains the status. *3. BHYSN, BHYSS: Hysteresis widths BHYSN and BHYSS are the difference between BOPN and BRPN, and BOPS and BRPS, respectively. Remark 6 The unit of magnetic density mT can be converted by using the formula 1 mT = 10 Gauss. HIGH-WITHSTAND VOLTAGE HIGH-SPEED UNIPOLAR DETECTION TYPE HALL EFFECT SWITCH IC Rev.1.1_01 S-5731 Series  Test Circuits A *1 VDD R 820  S-5731 Series OUT VSS *1. Resistor (R) is unnecessary for Nch driver  built-in pull-up resistor product. Figure 5 Test Circuit 1 VDD S-5731 Series OUT VSS Figure 6 A V Test Circuit 2 VDD S-5731 Series OUT VSS A V Figure 7 Test Circuit 3 *1 VDD R 820  S-5731 Series OUT VSS *1. V Resistor (R) is unnecessary for Nch driver  built-in pull-up resistor product. Figure 8 Test Circuit 4 7 HIGH-WITHSTAND VOLTAGE HIGH-SPEED UNIPOLAR DETECTION TYPE HALL EFFECT SWITCH IC Rev.1.1_01 S-5731 Series *1 VDD S-5731 OUT Series VSS *1. R 820  C 20 pF V Resistor (R) is unnecessary for Nch driver  built-in pull-up resistor product. Figure 9 Test Circuit 5  Standard Circuit *1 VDD CIN 0.1 F R 820  S-5731 Series OUT VSS *1. Resistor (R) is unnecessary for Nch driver  built-in pull-up resistor product. Figure 10 Caution The above connection diagram and constant will not guarantee successful operation. Perform thorough evaluation using the actual application to set the constant. 8 HIGH-WITHSTAND VOLTAGE HIGH-SPEED UNIPOLAR DETECTION TYPE HALL EFFECT SWITCH IC Rev.1.1_01 S-5731 Series  Operation 1. Direction of applied magnetic flux This IC detects the magnetic flux density which is vertical to the marking surface. Figure 11 shows the direction in which magnetic flux is being applied. N S Marking surface Figure 11 2. Position of Hall sensor Figure 12 shows the position of Hall sensor. The center of this Hall sensor is located in the area indicated by a circle, which is in the center of a package as described below. The following also shows the distance (typ. value) between the marking surface and the chip surface of a package. Top view The center of Hall sensor; in this  0.3 mm 1 2 3 0.7 mm (typ.) Figure 12 9 HIGH-WITHSTAND VOLTAGE HIGH-SPEED UNIPOLAR DETECTION TYPE HALL EFFECT SWITCH IC Rev.1.1_01 S-5731 Series 3. Basic operation This IC changes the output voltage (V OUT ) according to the level of the magnetic flux density (N pole or S pole) applied by a magnet. The following explains the operation when the output logic is active "L". 3. 1 Product with S pole detection When the magnetic flux density of the S pole perpendicular to the marking surface exceeds the operation point (BOPS) after the S pole of a magnet is moved closer to the marking surface of this IC, VOUT changes from "H" to "L". When the S pole of a magnet is moved further away from the marking surface of this IC and the magnetic flux density is lower than the release point (BRPS), VOUT changes from "L" to "H". Figure 13 shows the relationship between the magnetic flux density and VOUT. VOUT BHYSS H L N pole BRPS 0 S pole BOPS Magnetic flux density (B) Figure 13 3. 2 Product with N pole detection When the magnetic flux density of the N pole perpendicular to the marking surface exceeds the operation point (BOPN) after the N pole of a magnet is moved closer to the marking surface of this IC, VOUT changes from "H" to "L". When the N pole of a magnet is moved further away from the marking surface of this IC and the magnetic flux density of the N pole is lower than the release point (BRPN), VOUT changes from "L" to "H". Figure 14 shows the relationship between the magnetic flux density and VOUT. VOUT BHYSN H L N pole BOPN BRPN 0 S pole Magnetic flux density (B) Figure 14 10 HIGH-WITHSTAND VOLTAGE HIGH-SPEED UNIPOLAR DETECTION TYPE HALL EFFECT SWITCH IC Rev.1.1_01 S-5731 Series 4. Timing chart Figure 15 shows the operation timing at power-on. The initial output voltage at rising of power supply voltage (VDD) is either "H" or "L". In case of B  BOPS (operation point) or B BRPS (release point) at the time when the start up time (tPON) is passed after rising of VDD, this IC outputs VOUT according to the applied magnetic flux density. In case of BRPS  B  BOPS at the time when tPON is passed after rising of VDD, this IC maintains the initial output voltage. Product with S pole detection and active "L" Product with S pole detection and active "H" Power supply voltage (VDD) Power supply voltage (VDD) tPON tPON Output voltage (VOUT) (B  BOPS) "H" / "L" "L" Output voltage (VOUT) (B  BOPS) "H" / "L" "H" Output voltage (VOUT) (B  BRPS) "H" / "L" "H" Output voltage (VOUT) (B  BRPS) "H" / "L" "L" Output voltage (VOUT) (BRPS  B  BOPS) "H" / "L" Latching Output voltage (VOUT) (BRPS  B  BOPS) "H" / "L" Latching Figure 15 11 HIGH-WITHSTAND VOLTAGE HIGH-SPEED UNIPOLAR DETECTION TYPE HALL EFFECT SWITCH IC Rev.1.1_01 S-5731 Series  Precautions  If the impedance of the power supply is high, the IC may malfunction due to a supply voltage drop caused by feedthrough current. Take care with the pattern wiring to ensure that the impedance of the power supply is low.  Note that the IC may malfunction if the power supply voltage rapidly changes. When the IC is used under the environment where the power supply voltage rapidly changes, it is recommended to judge the output voltage of the IC by reading it multiple times.  Note that the output voltage may rarely change if the magnetic flux density between the operation point and the release point is applied to this IC continuously for a long time.  Do not apply an electrostatic discharge to this IC that exceeds the performance ratings of the built-in electrostatic protection circuit.  Although this IC has a built-in output current limit circuit, it may suffer physical damage such as product deterioration under the environment where the absolute maximum ratings are exceeded.  The application conditions for the power supply voltage, the pull-up voltage, and the pull-up resistor should not exceed the power dissipation.  Large stress on this IC may affect on the magnetic characteristics. Avoid large stress which is caused by the handling during or after mounting the IC on a board.  ABLIC Inc. claims no responsibility for any disputes arising out of or in connection with any infringement by products including this IC of patents owned by a third party. 12 HIGH-WITHSTAND VOLTAGE HIGH-SPEED UNIPOLAR DETECTION TYPE HALL EFFECT SWITCH IC Rev.1.1_01 S-5731 Series  Power Dissipation SOT-23-3 Tj = 125C max. Power dissipation (PD) [W] 1.0 0.8 B A 0.6 0.4 0.2 0.0 0 25 50 75 100 125 150 175 Ambient temperature (Ta) [C] Board A B C D E Power Dissipation (PD) 0.50 W 0.61 W    13 SOT-23-3/3S/5/6 Test Board IC Mount Area (1) Board A Item Size [mm] Material Number of copper foil layer Copper foil layer [mm] 1 2 3 4 Thermal via Specification 114.3 x 76.2 x t1.6 FR-4 2 Land pattern and wiring for testing: t0.070 74.2 x 74.2 x t0.070 - (2) Board B Item Size [mm] Material Number of copper foil layer Copper foil layer [mm] Thermal via 1 2 3 4 Specification 114.3 x 76.2 x t1.6 FR-4 4 Land pattern and wiring for testing: t0.070 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.070 - No. SOT23x-A-Board-SD-2.0 ABLIC Inc. 2.9±0.2 1 2 3 +0.1 0.16 -0.06 0.95±0.1 1.9±0.2 0.4±0.1 No. MP003-C-P-SD-1.1 TITLE SOT233-C-PKG Dimensions No. MP003-C-P-SD-1.1 ANGLE UNIT mm ABLIC Inc. +0.1 ø1.5 -0 4.0±0.1 2.0±0.1 +0.25 ø1.0 -0 0.23±0.1 4.0±0.1 1.4±0.2 3.2±0.2 1 2 3 Feed direction No. MP003-C-C-SD-2.0 TITLE SOT233-C-Carrier Tape No. MP003-C-C-SD-2.0 ANGLE UNIT mm ABLIC Inc. 12.5max. 9.2±0.5 Enlarged drawing in the central part ø13±0.2 No. MP003-Z-R-SD-1.0 SOT233-C-Reel TITLE MP003-Z-R-SD-1.0 No. QTY. ANGLE UNIT mm ABLIC Inc. 3,000 Disclaimers (Handling Precautions) 1. All the information described herein (product data, specifications, figures, tables, programs, algorithms and application circuit examples, etc.) is current as of publishing date of this document and is subject to change without notice. 2. The circuit examples and the usages described herein are for reference only, and do not guarantee the success of any specific mass-production design. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by the reasons other than the products described herein (hereinafter "the products") or infringement of third-party intellectual property right and any other right due to the use of the information described herein. 3. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by the incorrect information described herein. 4. Be careful to use the products within their ranges described herein. Pay special attention for use to the absolute maximum ratings, operation voltage range and electrical characteristics, etc. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by failures and / or accidents, etc. due to the use of the products outside their specified ranges. 5. Before using the products, confirm their applications, and the laws and regulations of the region or country where they are used and verify suitability, safety and other factors for the intended use. 6. When exporting the products, comply with the Foreign Exchange and Foreign Trade Act and all other export-related laws, and follow the required procedures. 7. The products are strictly prohibited from using, providing or exporting for the purposes of the development of weapons of mass destruction or military use. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by any provision or export to the person or entity who intends to develop, manufacture, use or store nuclear, biological or chemical weapons or missiles, or use any other military purposes. 8. The products are not designed to be used as part of any device or equipment that may affect the human body, human life, or assets (such as medical equipment, disaster prevention systems, security systems, combustion control systems, infrastructure control systems, vehicle equipment, traffic systems, in-vehicle equipment, aviation equipment, aerospace equipment, and nuclear-related equipment), excluding when specified for in-vehicle use or other uses by ABLIC, Inc. Do not apply the products to the above listed devices and equipments. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by unauthorized or unspecified use of the products. 9. In general, semiconductor products may fail or malfunction with some probability. The user of the products should therefore take responsibility to give thorough consideration to safety design including redundancy, fire spread prevention measures, and malfunction prevention to prevent accidents causing injury or death, fires and social damage, etc. that may ensue from the products' failure or malfunction. The entire system in which the products are used must be sufficiently evaluated and judged whether the products are allowed to apply for the system on customer's own responsibility. 10. The products are not designed to be radiation-proof. The necessary radiation measures should be taken in the product design by the customer depending on the intended use. 11. The products do not affect human health under normal use. However, they contain chemical substances and heavy metals and should therefore not be put in the mouth. The fracture surfaces of wafers and chips may be sharp. Be careful when handling these with the bare hands to prevent injuries, etc. 12. When disposing of the products, comply with the laws and ordinances of the country or region where they are used. 13. The information described herein contains copyright information and know-how of ABLIC Inc. The information described herein does not convey any license under any intellectual property rights or any other rights belonging to ABLIC Inc. or a third party. Reproduction or copying of the information from this document or any part of this document described herein for the purpose of disclosing it to a third-party is strictly prohibited without the express permission of ABLIC Inc. 14. For more details on the information described herein or any other questions, please contact ABLIC Inc.'s sales representative. 15. This Disclaimers have been delivered in a text using the Japanese language, which text, despite any translations into the English language and the Chinese language, shall be controlling. 2.4-2019.07 www.ablic.com
S-5731NNL2-M3T2U 价格&库存
很抱歉,暂时无法提供与“S-5731NNL2-M3T2U”相匹配的价格&库存,您可以联系我们找货
S-5731NNL2-M3T2U
  • 1+9.820561+1.26764
  • 5+8.686595+1.12127
  • 10+8.2447810+1.06424
  • 25+7.7250825+0.99716
  • 50+7.3712050+0.95148
  • 100+7.04823100+0.90979
  • 500+6.39783500+0.82584
  • 1000+6.156131000+0.79464
库存:1685
S-5731NNL2-M3T2U
