SRC59MFA0R50
SRC59MFA0R50
    PROSEMI(普罗森美)
SRC59MFA0R50 数据手册
Circuit Protection SRC59 Series Size 5930 (15x7.75mm) Current Shunt Resistors SRC59 Series Current Shunt Resistors aid precision measurement and high-current applications. A wide range of precision shunts, designed for use with kilowatt-hour meters and other high-current applications where a high level of accuracy is required, is now available from PROSEMI. Features Power rating up to 10 W at 100°C Excellent long term stability Extremely low resistance values (down to 0.2mΩ) Halogen free, lead free and RoHS compliant SRC 59 M F T 0R20 Appications Power modules Frequency converters Current sensor for power hybrid sources Resistance Code 0R20: 0.2 mΩ 1R0: 1mΩ Power Rating A: 6W S: 7W T: 10W Series Metal foil Size 59: 5930(15x7.75) High current for automotive Lithium battery protection board Material M:MnCu F:FeCrAl Part Number SRC59F_A2R0 SRC59F_A1R0 SRC59M_A0R50 SRC59M_S0R30 SRC59M_T0R20 Power Rating P 100°C (W) Resistance Range (mΩ) 6 6 6 7 10 2 1 0.5 0.3 0.2 Applicable temperature range of -55°C to +170°C Power rating is guaranteed for use an aluminum substrate (MCPCB) Part Number definition “_” of Resistance Tolerance 1 Document Number: D1702 1731 P TCR (ppm/°C) ±50 ±50 ±75 ±100 ±100 Resistance Tol. F: ± 1% G: ±2% J: ±5% Thickness (mm) Material 0.94±0.1 1.37±0.1 1.09±0.1 1.45±0.1 1.93±0.1 FeCrAl FeCrAl MnCu MnCu MnCu Circuit Protection Size 5930 (15x7.75mm) Current Shunt Resistors SRC59 Series Dimension Unit: mm W 5.2 Pad layout A T L p 16 8.75 L W T A p SRC59F_A2R0 15±0.2 7.75±0.1 0.94±0.1 4.2±0.1 1.0±0.1 SRC59F_A1R0 15±0.2 7.75±0.1 1.37±0.1 4.2±0.1 1.0±0.1 SRC59M_A0R50 15±0.2 7.75±0.1 1.09±0.1 4.2±0.1 1.0±0.1 SRC59M_S0R30 15±0.2 7.75±0.1 1.45±0.1 4.2±0.1 1.0±0.1 SRC59M_T0R20 15±0.2 7.75±0.1 1.93±0.1 4.2±0.1 1.0±0.1 Type Packaging Storage Conditions Temperature: 22~28 °C , Humidity: 40~75% Quantity: 2 , 000pcs 24mm wide tape on 330mm(13 inch) diameter reel -specification EIA Standard 481. Derating Curve Rated Power in % 100 80 60 40 20 0 -55 100 170 Terminal Temperature (°C) Document Number: D17021731P 2 Circuit Protection Size 5930 (15x7.75mm) Current Shunt Resistors SRC59 Series Soldering Parameters IR Reflow Profile tP Temperature TP T C -5°C Max.Ramp Up Rate= 3 °C /S Max.Ramp Down Rate= 6°C/S TL TS t max Preheat Heat Temperature min (Tsmin) Temperature max(Tsmax) Time (Tsmin to Tsmax) (ts) 150 °C 200°C 60 -120 seconds Average ramp-up rate (Tsmax to Tp) 3°C/second max. Liquidous temperature (T L ) Time at liquidous (t L ) 217 °C 60 - 150 seconds Preheat TS min tS 25 Time 25 °C to Peak Time Wave Soldering: 260°C, 10 seconds max. Infrared Reflow: 260°C, 30 seconds max. Peak temperature(Tp) 260+0/-5°C Time within 5°C of actual peak Temperature (tp) 10 – 30 seconds Average ramp-down rate (Tp to Tsmax) 6°C/second max. Time 25 °C to peak temperature 8 minutes max. Performances Short Time Overload Loading 5 times rate power 5sec Moisture Resistance The specimens shall be placed in a chamber and subjected to a relative humidity of 90~98% percent and a temperature of 25°C / 65°C 10 cycles High Temperature Exposure The chip (mounted on board) is exposed in the heat chamber 125 °C for 1000 hrs. Rapid Change of Temperature The chip (mounted on board) is exposed, -55±3°C (30min.)/+125±2°C (30min.) for 5 cycles. Load Life Apply rated power for 1000 hours with 1.5 hours ON and 0.5 hour OFF. © 2017 PROSEMI Inc. All Rights Reserved. Specifications and features are subject to change without notice. www.prosemitech.com The PROSEMI logo, and all other PROSEMI trademarks are the property of PROSEMI Inc. All other trademarks are the property of their respective owners. 3 Document Number: D17021731P
SRC59MFA0R50 价格&库存
很抱歉,暂时无法提供与“SRC59MFA0R50”相匹配的价格&库存,您可以联系我们找货
