1N4001FL
THRU
1N4007FL
Technical Data
Data Sheet N1646, Rev. A
1N4001FL THRU 1N4007FL
General Purpose Plastic Rectifier
Features
Low forward voltage drop
Low leakage current
High forward surge capability
Solder dip 260 °C, 40 s
Component in accordance to RoHS 2002/95/EC
and WEEE 2002/96/EC
This is a Halogen Free Device
All SMC parts are traceable to the wafer lot
Additional testing can be offered upon request
SOD-123FL
Circuit Diagram
Mechanical Data
Case: SOD-123FL molded plastic
Terminals: Plated leads solderable per
MIL-STD-750, Method 2026
Polarity: Color band denotes cathode end
Mounting Position: Any
Weight:0.0007 ounce, 0.02 grams
Maximum Ratings and Electrical Characteristics @TA=25°C unless otherwise specified
Characteristic
Symbol
Marking code
1N
1N
1N
1N
1N
1N
1N
Units
4001FL 4002FL 4003FL 4004FL 4005FL 4006FL 4007FL
A1
A2
A3
A4
A5
A6
A7
Maximum repetitive peak reverse voltage
Maximum DC blocking voltage
VRRM
VDC
50
100
200
400
600
800
1000
V
Maximum RMS voltage
VRMS
35
70
140
280
420
560
700
V
Maximum average forward rectified current
@TA = 75°C
Peak forward surge current 8.3ms single half sinewave superimposed on rated load (JEDEC
Method)
I(AV)
1.0
A
IFSM
30.0
A
Maximum instantaneous forward voltage at 1.0A
VF
1.1
V
Maximum DC reverse current @TA = 25°C
at rated DC blocking voltage @TA = 100°C
IR
5.0
50.0
µA
Typical Junction Capacitance (Note 1)
CJ
15.0
pF
RθJA
75.0
°C/W
TJ,TSTG
-65 to +150
°C
Typical Thermal Resistance (Note 2)
Operating and Storage Temperature Range
Note: 1. Measured at 1.0 MHz and applied reverse voltage of 4.0V D.C.
2.Thermal resistance from junction to ambient at 0.375" (9.5mm)lead length,P.C.B. mounted
China - Germany - Korea - Singapore - United States
http://www.smc-diodes.com - sales@ smc-diodes.com
1N4001FL
THRU
1N4007FL
Technical Data
Ratings and Characteristics Curves
1N4001FL
THRU
1N4007FL
Technical Data
Mechanical Dimensions SOD-123FL(Inches/Millimeters)
Ordering Information
Device
1N4001FL
THRU
1N4007FL
Marking Diagram
Package
Shipping
SOD-123FL
3000pcs / reel
For information on tape and reel specifications, including part
orientation and tape sizes, please refer to our tape and reel
packaging specification.
A1
= Marking Code
Carrier Tape Specification SOD-123FL
SYMBOL
A
B
C
d
E
F
P
P0
P1
W
Millimeters
Min.
Max.
7.90
8.30
1.95
3.85
1.35
1.50
1.65
3.40
3.90
3.90
1.90
2.15
4.05
1.55
1.60
1.85
3.60
4.10
4.10
2.10
1N4001FL
THRU
1N4007FL
Technical Data
DISCLAIMER:
1- The information given herein, including the specifications and dimensions, is subject to change without prior notice to improve product
characteristics. Before ordering, purchasers are advised to contact the SMC Diode Solutions sales department for the latest version of
the datasheet(s).
2- In cases where extremely high reliability is required (such as use in nuclear power control, aerospace and aviation, traffic equipment,
medical equipment , and safety equipment) , safety should be ensured by using semiconductor devices that feature assured safety or by
means of users’ fail-safe precautions or other arrangement .
3- In no event shall SMC Diode Solutions be liable for any damages that may result from an accident or any other cause during
operation of the user’s units according to the datasheet(s). SMC Diode Solution assumes no responsibility for any intellectual property
claims or any other problems that may result from applications of information, products or circuits described in the datasheets.
4- In no event shall SMC Diode Solutions be liable for any failure in a semiconductor device or any secondary damage resulting from use
at a value exceeding the absolute maximum rating.
5- No license is granted by the datasheet(s) under any patents or other rights of any third party or SMC Diode Solutions.
6- The datasheet(s) may not be reproduced or duplicated, in any form, in whole or part, without the expressed written permission of SMC
Diode Solutions.
7- The products (technologies) described in the datasheet(s) are not to be provided to any party whose purpose in their application will
hinder maintenance of international peace and safety nor are they to be applied to that purpose by their direct purchasers or any third
party. When exporting these products (technologies), the necessary procedures are to be taken in accordance with related laws and
regulations..
很抱歉,暂时无法提供与“1N4007FL”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.14008
- 200+0.11384
- 600+0.09926
- 3000+0.08511
- 9000+0.07755
- 21000+0.07344
