SIM8051-6-0-14-00-A
SIM8051-6-0-14-00-A
    GCT
    SMD
    拔插式 NANOSIM卡 卡座
SIM8051-6-0-14-00-A 数据手册
9.00 C5 6x 1.20 8.30 1.45 4.85 0.70 12.20 10.70 -Y- 1.4 Pick/Place area G C7 C6 C5 2x 3.00 C6 4.15 A C7 Ø0.70+0.10 -0.00 1.65 0.10 (3.50) 6x 1.00 2.54 4.60 6x 1.00 6x 1.10 H Specification -X- Material Plastic Housing: LCP 30%GF, UL94V-0, Black Contact Terminal: Phosphor Bronze,T=0.12mm Cover: SUS301-H, T=0.15mm 2x 1.00 F 5.08 8.94+0.15 -0 Section A-A Recommended PCB Layout 2.54 2.54 Solder Area Keep Out Area Ø0.60 0.12 0.30 4.60 0.70 1.95 8.30±0.10 Electrical Voltage Rating: 30V max. Current Rating: 0.5A max. Dielectric Withstanding Voltage: 100V AC (60 Sec min.) Insulation Resistance: 1000 MΩ min. Contact Resistance: 100 mΩ max. Component Outline Mechanical & Environmental Operating Temperature: -40°C to +85°C Durability: 5000 cycles 9.00±0.10 10.8 Ordering Grid -Y- C 0.75 For NanoSIM 1.10 D Plating: Contact Terminal: Contact Area: 3µ” Gold Solder area: Gold Flash Underplating: Ni overall 50µ" min. Cover: Ni overall 50µ" min. C1 As viewed from component side General Tolerance ±0.05 Locating peg holes only applicable to locating peg version 1.35 0.28 0.65 (9.54) C2 5.08 7.15 10.60 1.25 0.10 C3 Ø0.90+0.10 -0.00 A 0.37±0.05 E C1 C2 C3 0.40 0.35 SIM8051 6 0 14 XX No. of Contacts 6=6 Switch 0 = Without B A Request Samples and Quotation Packing Options A = Tape & Reel (1500 per Reel) Locating Peg 01 = With (Standard) 00 = Without Profile Height (H) 14 = 1.35mm -XPart Number Product Description SIM8051 Nano SIM Card Connector Push-Pull Type, 6 Pin, SMT, Profile 1.35mm Drawing Date A 28th April 2015 1 2 3 4 By CC Detail SIM8051 D PCN Revision Date 5 D6 14/07/22 Tolerances (Except as Noted) Length Angle X. ± 0.35 X.X ± 0.25 X.XX ± 0.15 X.XXX ± 0.10 All ± 2° Units: Metric (mm) C 3rd Angle Projection 6 7 This drawing is confidential and copyright of Global Connector Technology, Ltd (GCT). This drawing must not be copied or disclosed without written consent. E & OE www.gct.co Not to Scale Drawn By AJO 8 Sheet No. 1/3 H 25.00mm Mini G 15.00mm Micro 12.30mm Nano D 8.80mm Nano E 12.00mm Micro 15.00mm Mini F C1----->VCC C2----->RST Nano SIM C3----->CLK C5----->GND C6----->Vpp C7----->I/O Micro SIM C Mini SIM Reference B Part Number Product Description SIM8051 Nano SIM Card Connector Push-Pull Type, 6 Pin, SMT, Profile 1.35mm Drawing Date A 28th April 2015 1 2 3 4 By CC Detail SIM8051 D PCN Revision Date 5 D6 14/07/22 Tolerances (Except as Noted) Length Angle X. ± 0.35 X.X ± 0.25 X.XX ± 0.15 X.XXX ± 0.10 All ± 2° Units: Metric (mm) C 3rd Angle Projection 6 7 This drawing is confidential and copyright of Global Connector Technology, Ltd (GCT). This drawing must not be copied or disclosed without written consent. E & OE www.gct.co Not to Scale Drawn By AJO 8 Sheet No. 2/3 H 400 Peeling Angle Min. 165°~18 0° Reel Label RoHS Label Ø330 1500Pcs/Reel G 160mm Product Loading Section F Desiccant Vacuum Bag 44cmX45cm Unloaded Section 128mm Unloaded Section 24.5 28.5 Inner Carton Label Direction of Unreeling RoHS Label 1.75 11.50±0.15 E 2.00 13500Pcs/carton 4.00 1 Ø 0 .5 Inner Carton:340mmX340mmX285mm 2.60 24.00±0.3 D Box label C RoHS Label 16.00 Box: 355mmX355mmX305mm Notes: Peeling off force of top tape: 0.1-1.3N (Peeling direction as shown) B Products P/N Pcs / Reel Reels/Carton 1500 SIM8051 Materials: Carrier Tape: Polystyrene (PS) Top Tape: PE Reel Tape: Polystyrene (PS) Vacuum Bag: PE A 1 2 Part Number Product Description SIM8051 Nano SIM Card Connector Push-Pull Type, 6 Pin, SMT, Profile 1.35mm Drawing Date 28th April 2015 3 4 9 By CC Detail SIM8051 D PCN Revision Date 5 D6 14/07/22 Tolerances (Except as Noted) Length Angle Units: Metric (mm) C 3rd Angle Projection 6 7 Reels/Carton 13500 This drawing is confidential and copyright of Global Connector Technology, Ltd (GCT). This drawing must not be copied or disclosed without written consent. E & OE www.gct.co Not to Scale Drawn By AJO 8 Sheet No. 3/3
SIM8051-6-0-14-00-A 价格&库存
很抱歉,暂时无法提供与“SIM8051-6-0-14-00-A”相匹配的价格&库存,您可以联系我们找货
SIM8051-6-0-14-00-A
    • 100+5.44520
    库存:1500
    SIM8051-6-0-14-00-A
      SIM8051-6-0-14-00-A
        SIM8051-6-0-14-00-A
        • 1500+5.400821500+0.70076
        • 3000+5.143083000+0.66731
        • 4500+4.998114500+0.64850
        • 7500+4.821297500+0.62556
        • 10500+4.7082810500+0.61090
        • 15000+4.5913915000+0.59573
        库存:4578
        SIM8051-6-0-14-00-A
        • 1+9.079411+1.17805
        • 10+7.6929910+0.99816
        • 25+7.2119525+0.93575
        • 50+6.8666850+0.89095
        • 100+6.53888100+0.84842
        • 250+6.12890250+0.79522
        • 500+5.83633500+0.75726
        库存:4578
        SIM8051-6-0-14-00-A
        • 1+8.482681+1.10062
        • 10+7.0456810+0.91417
        • 25+6.6189325+0.85880
        • 50+6.3315350+0.82151
        • 100+6.04413100+0.78422
        • 250+5.65222250+0.73337
        • 500+5.37353500+0.69721
        • 1000+5.077421000+0.65879
        • 1500+4.938071500+0.64071
        • 3000+4.650673000+0.60342
        库存:2017
        SIM8051-6-0-14-00-A
          • 1+10.89000
          • 10+9.13550
          • 30+8.16750
          • 100+7.07850
          • 500+6.59450
          • 1500+6.37670
          库存:1796
          SIM8051-6-0-14-00-A
            • 1+9.72000
            • 10+8.15400
            • 30+7.29000
            • 100+6.31800
            • 500+5.88600
            • 1500+5.69160
            库存:1736
