ZE05-20DS-HU/R
ZE05-20DS-HU/R
    HRS(广濑)
    ZE05-20DS-HU/R
ZE05-20DS-HU/R 数据手册
APPLICABLE STANDARD OPERATING TEMPERATURE RANGE 2 △ RATING VOLTAGE Jan.1.2023 Copyright 2023 HIROSE ELECTRIC CO., LTD. All Rights Reserved. In case of consideration for using Automotive equipment / device which demand high reliability, kindly contact our sales window correspondents. -40 C TO 60 V 2 CURRENT STORAGE TEMPERATURE RANGE +125 C AC/DC -10 C TO +60 C (1) RELATIVE HUMIDITY 85% MAX STORAGE HUMIDITY RANGE A (NOT DEWED) SPECIFICATIONS ITEM CONSTRUCTION TEST METHOD GENERAL EXAMINATION MARKING REQUIREMENTS VISUALLY AND BY MEASURING INSTRUMENT. CONFIRMED VISUALLY. QT AT ACCORDING TO DRAWING. × × × × 10 mΩ MAX . 10 mΩ MAX . - - - - ELECTRIC CHARACTERISTICS CONTACT RESISTANCE CONTACT RESISTANCE MILLIVOLT LEVEL METHOD INSULATION RESISTANCE 1A DC. 10 mV AC MAX, 500 V DC. 100 MΩ MIN. × - VOLTAGE PROOF 1000 V AC FOR 1 min. NO FLASHOVER OR BREAKDOWN. - - 0.1 mA(DC OR 1000Hz) MECHANICAL CHARACTERISTICS MECHANICAL OPERATION 30 TIMES INSERTIONS AND EXTRACTIONS. ① CONTACT RESISTANCE: 20 m MAX. ② NO DAMAGE, CRACK AND LOOSENESS OF PARTS. - × - - VIBRATION FREQUENCY 20 TO 200Hz (88m/s²) SWEEP TIME 3min.(ROUND TRIP) AT 3h FOR 3 DIRECTIONS. ① NO ELECTRICAL DISCONTINUITY OF 7MIN , 1s MIN. ② CONTACT RESISTANCE: 20 m MAX. ③ NO DAMAGE, CRACK AND LOOSENESS OF PARTS. ① NO ELECTRICAL DISCONTINUITY OF 7MIN , 1s MIN. ② NO DAMAGE, CRACK AND LOOSENESS OF PARTS. - - - × - - - - × - ① 100 N MIN × - ① CONTACT RESISTANCE: 20 m MAX. ② INSULATION RESISTANCE:100 M MIN. ③ NO DAMAGE, CRACK AND LOOSENESS OF PARTS. ① CONTACT RESISTANCE: 20 m MAX. ② NO DAMAGE, CRACK AND LOOSENESS OF PARTS. - × × - - - - × - - ① CONTACT RESISTANCE: 20 m MAX. ② NO DAMAGE, CRACK AND LOOSENESS OF PARTS. ① CONTACT RESISTANCE: 20 m MAX. ② NO DAMAGE, CRACK AND LOOSENESS OF PARTS. ① CONTACT RESISTANCE: 20 m MAX. - × - - - × - - - - SHOCK 981m/s² DURATION OF PULSE 6ms AT 3 TIMES FOR 6 DIRECTIONS. LOCK STRENGTH MEASURE BREAK STRENGTH OF THE LOCK BY PULLING THE CONNECTOR IN THE MATING DIRECTION. ENVIRONMENTAL CHARACTERISTICS 90 ~ 95 %, DAMP HEAT (STEADY STATE) EXPOSED AT 60 C, RAPID CHANGE OF TEMPERATURE DRY HEAT TEMPERATURE- 40 →ROOM TEMP →125C→ ROOM TEMP TIME 30 → 5 → 30 → 5 min UNDER 1000 CYCLES. EXPOSED AT 140C, 120 h. COLD EXPOSED AT -40C , 120 h. RESISTANCE TO SO2 GAS EXPOSED IN 25 PPM AT 75% MIN FOR 96h. △ COUNT 2 1 REMARK (NOTE1) 96 h. DESCRIPTION OF REVISIONS DESIGNED DIS-T-00006021 YH.MAMADA APPROVED "STORAGE" means a long-term storage state for the unused product before assembly to PCB. Note QT:Qualification Test AT:Assurance Test FORM HD0011-2-1 CHECKED X:Applicable Test PART NO. HIROSE ELECTRIC CO., LTD. CODE NO. 20200403 20171016 CHECKED HK.UMEHARA 20171016 DESIGNED TY.ISHIGURO 20171016 DRAWN MN.SATOH 20171016 DRAWING NO. SPECIFICATION SHEET DATE HH.TSUKUMO HK.UMEHARA ELC-368641-00-00 ZE05-20DS-HU/R CL752-2206-0-00 2 △ 1/1
ZE05-20DS-HU/R 价格&库存
很抱歉,暂时无法提供与“ZE05-20DS-HU/R”相匹配的价格&库存,您可以联系我们找货
ZE05-20DS-HU/R
