ACPR1208S150MT
ACPR1208S150MT
    SUNLORD(顺络)
    SMD
    ACPR1208S150MT
ACPR1208S150MT 数据手册
Shielded SMD Coupled Inductor – ACPR1208S Series Operating Temp.: -50°C~+150°C FEATURES     High efficiency, high coupling High rated current, low DC resistance RoHS compatible AEC-Q200 verified APPLICATIONS     SEPIC, Zeta, Flyback topology, etc. LED , power supplies Used as common mode choke Used as transformer PRODUCT IDENTIFICATION A CP R 1208 S XXX M T ① ② ③ ④ ⑤ ⑥ ⑦ ⑧ ① ② Type A ③ Automotive CP ④ Structure Code R ⑤ ⑦ 12.0×8.0 Nominal Inductance Example XXX type Nominal Value 1R0=1.0uH,100=10uH,101=100uH ⑧ Inductance Tolerance M External Dimensions (L×W) [mm] ⑥ Feature Type S for Coupled Power Inductor 1208 R Structure S Type Packing T ±20% Tape &Reel SHAPE AND DIMENSIONS Recommended Land Pattern Unit: mm Sunlord A B C 12.5Max. 8.0Max. 1.5±0.2 D 5.0±0.2 E K 5.0±0.2 0.25Min. Specifications subject to change without notice. Please check our website for latest information. Revised 2021/3/23. Sunlord Industrial Park, Dafuyuan Industrial Zone, Guanlan, Shenzhen, China 518110 Tel: 0086-755-29832333 Fax: 0086-755-82269029 E-Mail: sunlord@sunlordinc.com SPECIFICATIONS ACPR1208S Series Part Number Inductance DC Resistance @0.1MHz, 0.1V Saturation Heat Rating Current Current Typ. (P1-P3)or (P2-P4) A Isat Typ. (P1-P3)or (P2-P4) A Irms DC 500V/1Sec HI-POT Units Symbol μH L Max. (P1-P3)or (P2-P4) mΩ DCR ACPR1208S4R7MT 4.7±20% 25 12.9 5.0 Pass ACPR1208S6R8MT 6.8±20% 29 11.4 4.5 Pass ACPR1208S100MT 10±20% 36 9.8 4.1 Pass ACPR1208S150MT 15±20% 40 7.0 3.6 Pass ACPR1208S220MT 22±20% 72 6.7 3.0 Pass ACPR1208S270MT 27±20% 96 5.7 2.7 Pass ACPR1208S330MT 33±20% 105 5.2 2.5 Pass ACPR1208S470MT 47±20% 132 4.3 2.2 Pass ACPR1208S680MT 68±20% 206 3.6 1.8 Pass ACPR1208S101MT 100±20% 280 3.0 1.5 Pass (P1-P3)or (P2-P4) (P1-P3) to (P2-P4) / / Note: ※ 1: Saturation Current: Max. Value, DC current at which the inductance drops less than 30% from its value without current; Typ. Value, DC current at which the inductance drops approximate 30% from its value without current. ※ 2: Heat Rating Current: DC current that causes the temperature rise (ΔT) from 20°C ambient; For Max. Value, temperature rise (ΔT) is 20°C. For Typ. Value, temperature rise (ΔT) is approximate 40°C. The part temperature (ambient + temp. rise) should not exceed 150 °C under worst case operating conditions. Circuit design, component placement, PCB trace size and thickness, airflow and other cooling provisions all affect the part temperature. Part temperature should be verified in the end application. EQUIVALENT CIRCUIT Sunlord Specifications subject to change without notice. Please check our website for latest information. Revised 2021/3/23. Sunlord Industrial Park, Dafuyuan Industrial Zone, Guanlan, Shenzhen, China 518110 Tel: 0086-755-29832333 Fax: 0086-755-82269029 E-Mail: sunlord@sunlordinc.com
ACPR1208S150MT 价格&库存
很抱歉,暂时无法提供与“ACPR1208S150MT”相匹配的价格&库存,您可以联系我们找货
