T1SS-02-28-GF-02.0-T3
    SAMTEC(申泰)
T1SS-02-28-GF-02.0-T3 数据手册
REVISION A DESIGNED & DIMENSIONED IN MILLIMETERS[INCHES] ALL DIMENSION REFERENCE T1XSX-XX-XXX-XX-XX.X-X-XX PINOUT (LEAVE BLANK FOR SINGLE END ASSEMBLY) ***-D1: DOUBLE ENDED DOWN ***-D3: DOUBLE ENDED UP -T1: TRANSFER TO SOCKET DOWN -T3: TRANSFER TO SOCKET UP PANEL **-P: PANEL MOUNT -S: NON-PANEL MOUNT FEP CABLE OPTION -T: FEP INSULATION LEAVE BLANK FOR PVC (SEE NOTE 7) PANEL OPTION (LEAVE BLANK FOR NON-PANEL MOUNT) A: FITS 0.84, 1.57, & 2.29 THICK PANELS No OF POSITIONS -02 THRU -10 *-11 THRU *-20 (PER ROW) DO NOT SCALE FROM THIS PRINT ASSEMBLED LENGTH (SPECIFY IN INCHES) 01.8 IN MINIMUM WIRE GAUGE (AWG) -28, -30 PLATING SPECIFICATION COLOR CODE -C: COLOR CODE WIRE (SEE TABLE 2, SHT 2) (LEAVE BLANK FOR STANDARD WIRE) (NOT AVAILABLE WITH FEP OPTION) -GF: 3μ" GOLD CONTACT AND TAIL * = NOT TOOLED ** = NOT AVAILABLE IN -02 POS *** = NOT AVAILABLE FOR -P OPTION ASSEMBLED LENGTH (SEE NOTE 3) 01 POS 1 INDICATOR 3.79 .149 "X"±0.10[ .004] "A" 1.50 .059 1.000 .0394 (TYP) (TOL NON-ACCUM) 4.65±0.10 .183±.004 9.45±0.10 .372±.004 1.00 .039 ASSEMBLED LENGTH (SEE NOTE 3) 01 FIG 1 T1PSX-05-XXX-XX-XX.X-A SHOWN 5.00 .197 FIG 2 NOTES: 1. NOTE DELETED. 2. PARTS TO BE PACKAGED IN BAG. 3. FOR ASSEMBLED LENGTHS LESS THAN 13.00 IN, TOLERANCE SHALL BE ± 3.18[.125], FOR OTHER LENGTHS, TOLERANCE SHALL BE ± 2%. 4. NOTE DELETED. 5. NOTE DELETED. 6. ALL FINISHED GOODS ARE TO BE ELECTRICALLY TESTED INCLUDING HI-POT TEST AT 1000 VOLTS DC. AFTER FINAL ELECTRICAL TEST, LABEL WITH 1 ET STAMP ON THE BODY. 7. ASSEMBLIES USING THE FEP OPTION ARE FOR CRIMP APPLICATIONS ONLY. 8. CUT LENGTH IS ASSEMBLY LENGTH MINUS OVERALL LENGTH SUBTRACTOR. T1SSX-05-XXX-XX-XX.X SHOWN (DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 1) * PROPRIETARY NOTE THIS DOCUMENT CONTAINS CONFIDENTIAL AND * PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. MATERIAL: DO NOT SCALE DRAWING SHEET SCALE: 3:1 INSULATOR: NYLON, COLOR: LIGHT GREEN TERMINAL: PHOS BRONZE DESCRIPTION: 1MM T1XSX CABLE ASSEMBLY DWG. NO. T1XSX-XX-XXX-XX-XX.X-X-XX C:\EnterpriseVault\DWG\MISC\MKTG\T1XSX-XX-XXX-XX-XX.X-X-XX-MKT.SLDDRW BY: JERRY SU 03/05/2018 SHEET 1 OF 3 REVISION A END 1 01 END 1 END 2 ASSEMBLED LENGTH (SEE NOTE 3) 01 FIG 3 01 ASSEMBLED LENGTH (SEE NOTE 3) T1SS-05-XXX-XX-XX.X-D3 SHOWN (DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 2) END 1 END 2 01 FIG 5 01 END 2 01 FIG 6 T1PS-05-XXX-XX-XX.X-A-T3 SHOWN (DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 1 & FIG 5) T1PS-05-XXX-XX-XX.X-A-T1 SHOWN (DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 1) END 1 END 2 ASSEMBLED LENGTH (SEE NOTE 3) 01 01 01 FIG 4 T1SS-05-XXX-XX-XX.X-D1 SHOWN (DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 2) END 1 END 2 ASSEMBLED LENGTH (SEE NOTE 3) END 1 END 2 ASSEMBLED LENGTH (SEE NOTE 3) 01 01 ASSEMBLED LENGTH (SEE NOTE 3) T1SS-05-XXX-XX-XX.X-T3 SHOWN (DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 7) FIG 7 T1SS-05-XXX-XX-XX.X-T1 SHOWN (DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 2 ) 01 FIG 8 * PROPRIETARY NOTE THIS DOCUMENT CONTAINS CONFIDENTIAL AND * PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 2:1 C:\EnterpriseVault\DWG\MISC\MKTG\T1XSX-XX-XXX-XX-XX.X-X-XX-MKT.SLDDRW DESCRIPTION: 1MM T1XSX CABLE ASSEMBLY DWG. NO. T1XSX-XX-XXX-XX-XX.X-X-XX BY: JERRY SU 03/05/2018 SHEET 2 OF 3 REVISION A "D"±0.10 [0.004] R0.10 .004 MAX (TYP) PANEL LATCH ENGAGES THIS END OF CUTOUT POSITION 1 POSITION 1 4.82±0.10 .190±.004 CL 2.66±0.10 .105±.004 "E"±0.10 [0.004] "F"+-0.05 0.10 "E" REF 1.95±0.10 .077±.004 [+.002] [ -.004] CUTOUT FOR 0.84 THICK PANEL 3.45±0.10 .136±.004 1.25±0.10 .049±.004 1.25±0.10 .049±.004 CUTOUT FOR 1.57 THICK PANEL (DIFFERENT AS SHOWN, OTHERWISE SAME AS 0.84 THICK PANEL) CUTOUT FOR 2.29 THICK PANEL (DIFFERENT AS SHOWN, OTHERWISE SAME AS 0.84 THICK PANEL) 1.40 .055 1.40 .055 CUT LENGTH (SEE TABLE 6) CUT LENGTH (SEE TABLE 6) * PROPRIETARY NOTE THIS DOCUMENT CONTAINS CONFIDENTIAL AND * PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS 1.40 .055 AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. -S: SINGLE END -D: DOUBLE END -T: TRANSFER END DO NOT SCALE DRAWING SHEET SCALE: 2:1 C:\EnterpriseVault\DWG\MISC\MKTG\T1XSX-XX-XXX-XX-XX.X-X-XX-MKT.SLDDRW DESCRIPTION: 1MM T1XSX CABLE ASSEMBLY DWG. NO. T1XSX-XX-XXX-XX-XX.X-X-XX BY: JERRY SU 03/05/2018 SHEET 3 OF 3
T1SS-02-28-GF-02.0-T3 价格&库存
很抱歉,暂时无法提供与“T1SS-02-28-GF-02.0-T3”相匹配的价格&库存,您可以联系我们找货
