MBR230LS
Technical Data
Data Sheet N1466, Rev.A
MBR230LS SURFACE MOUNT
SCHOTTKY BARRIER DIODE
Features
SOD-123
Circuit Diagram
Low Turn-on Voltage
Fast Switching
PN Junction Guard Ring Transient and ESD Protection
Designed for Surface Mount Application
Plastic Material —UL Recognition Flammability
Classification 94V-O
Green Products in Compliance with the ROHS Directive
This is a Pb − Free Device
All SMC parts are traceable to the wafer lot
Additional testing can be offered upon request
Mechanical Data
Case: SOD-123, Molded Plastic
Terminals: Plated Leads Solderable per MIL-STD-202,
Method 208
Polarity: Cathode Band
Maximum Ratings and Electrical Characteristics @TA=25°C unless otherwise specified
Characteristic
Symbol
Value
Units
VR
30
V
Average Rectified Output Current
IF(AV)
2
A
Forward Voltage @IF = 0.5A,TA = 25°C
@IF = 2.0A,TA = 25°C
VFM
0.3
0.5
V
Peak Reverse Current At Rated DC Blocking Voltage @TA = 25°C
IRM
1.0
mA
Non−Repetitive Peak Surge Current
(Surge Applied at Rated Load Conditions
Halfwave, Single Phase, 60 Hz)
IFSM
25
A
Maximum Junction Capacitance (Note 1)
Cj
170
pF
Operating Junction Temperature Range
TJ
-55 to +100
°C
Storage Temperature Range
TSTG
-55 to +100
°C
Voltage Rate of Change (rated VR, TJ=25°C)
dv/dt
10000
V/µs
wt
0.028
g
Peak Reverse Voltage
Approximate Weight
Note 1. Measured at 1MHz and applied reverse voltage of 5.0V D.C.
China - Germany - Korea - Singapore - United States
http://www.smc-diodes.com - sales@ smc-diodes.com
MBR230LS
Technical Data
Mechanical Dimensions SOD-123
SYMBOL
MAX.
MIN.
MAX.
A
A1
A2
b
1.050
0.000
1.050
0.450
1.250
0.100
1.150
0.650
0.041
1
0.000
0.041
0.018
0.049
0.004
0.045
0.026
c
0.080
0.150
0.003
0.006
θ
Device
MBR230LS
Package
SOD-123
(Pb-Free)
Inches
MIN.
D
E
E1
L
L1
Ordering Information
Millimeters
1.500
1.700
2.600
2.800
3.550
3.850
0.500 REF.
0.250
0.450
0°
8°
0.059
0.067
0.102
0.110
0.140
0.152
0.020 REF.
0.010
0.018
0°
8°
Marking Diagram
Shipping
Where X is Date Code
3000pcs / reel
For information on tape and reel specifications, including part
orientation and tape sizes, please refer to our tape and reel
packaging specification.
B3N
= Part Name
MBR230LS
Carrier Tape Specification SOD-123
SYMBOL
A
B
C
d
E
F
P
P0
P1
W
Millimeters
Min.
Max.
1.80
3.89
1.52
1.45
1.65
3.40
3.90
3.90
1.90
7.90
1.90
3.99
1.62
1.65
1.85
3.60
4.10
4.10
2.10
8.30
MBR230LS
Technical Data
DISCLAIMER:
1- The information given herein, including the specifications and dimensions, is subject to change without prior notice to improve product
characteristics. Before ordering, purchasers are advised to contact the SMC - Sangdest Microelectronics (Nanjing) Co., Ltd sales
department for the latest version of the datasheet(s).
2- In cases where extremely high reliability is required (such as use in nuclear power control, aerospace and aviation, traffic equipment,
medical equipment , and safety equipment) , safety should be ensured by using semiconductor devices that feature assured safety or by
means of users’ fail-safe precautions or other arrangement .
3- In no event shall SMC - Sangdest Microelectronics (Nanjing) Co., Ltd be liable for any damages that may result from an accident or
any other cause during operation of the user’s units according to the datasheet(s). SMC - Sangdest Microelectronics (Nanjing) Co., Ltd
assumes no responsibility for any intellectual property claims or any other problems that may result from applications of information,
products or circuits described in the datasheets.
4- In no event shall SMC - Sangdest Microelectronics (Nanjing) Co., Ltd be liable for any failure in a semiconductor device or any
secondary damage resulting from use at a value exceeding the absolute maximum rating.
5- No license is granted by the datasheet(s) under any patents or other rights of any third party or SMC - Sangdest Microelectronics
(Nanjing) Co., Ltd.
6- The datasheet(s) may not be reproduced or duplicated, in any form, in whole or part, without the expressed written permission of SMC
- Sangdest Microelectronics (Nanjing) Co., Ltd.
7- The products (technologies) described in the datasheet(s) are not to be provided to any party whose purpose in their application will
hinder maintenance of international peace and safety nor are they to be applied to that purpose by their direct purchasers or any third
party. When exporting these products (technologies), the necessary procedures are to be taken in accordance with related laws and
regulations..
很抱歉,暂时无法提供与“MBR230LS”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+3.968341+0.51579
- 10+2.4524810+0.31877
- 50+1.7695450+0.23000
- 100+1.54734100+0.20112
- 500+1.15421500+0.15002
- 国内价格 香港价格
- 3000+0.865023000+0.11243
- 9000+0.741709000+0.09641
