DRR7016C
DRR7016C
    NIDEC(尼得科)
    插件
    超小型可清洗DIP旋转开关,适用于高密度安装,采用镀金触点
DRR7016C 数据手册
DRS・DRR 7000C 8000C Washable Hyper-Miniature Dip Rotary Switches(7.5mm sq.) 〔PC Mount〕 RoHS Compliant ■ Features 1. Hyper-miniature Size(7.5mm sq.) Designed for high density mounting. 2. Process Sealed 3. Gold Plated Contacts 4. Clearly Visible Legends and Position   Indicator ■ Specifications Rating Max. 30mA 15VDC Switching Min. Non-switching 1μA 20mVDC 100mA 50VDC Contact resistance 100mΩ maximum Dielectric strength 250VAC, 60s Insulation resistance 1,000MΩ minimum (100VDC) Load life 20,000 steps 30mA 15VDC Operating torque 49mN・m〔500gf・cm〕maximum Operating temperature range -25~+85℃ Storage temperature range -40~+85℃ ■ Part Numbering DR Series code S 7 Terminals 0 Actuators 10 Circuits C Number of positions S Straight 7 Screwdriver Actuator 0 Real code 10 10 positions R Right angle 8 Shaft Actuator 1 Complementary code 16 16 positions Structure ■ 品種一覧表 /Table of Part Numbers Actuators Terminal style Circuit function Complementary code   ★:Made-to-order products. Shaft Actuator PC Straight Right-Angle Straight 10 DRS7010C DRR7010C DRS8010C ★ DRR8010C 16 DRS7016C DRR7016C DRS8016C 10 DRS7110C DRR7110C ★ DRS8110C DRR8016C 16 DRS7116C DRR7116C DRS8116C positions Real code Screwdriver Actuator Right Angle ★ DRR8110C ★ DRR8116C DRS・DRR7000C DRS7010C DRS7110C Production date code ● Real code Washable Actuator color:Yellow Part No. Position DRS7010C DRR7010C 0 1 2 3 4 5 6 7 8 9 Straight 1 ● ● ● ● Terminal # 2 4 8 ● ● ● ● ● ● ● ● ● ● ● Terminal numbers are shown on the bottom of the switch. DRR7010C DRR7110C ● Complementary code Production date code Right Angle DRS7016C DRS7116C Terminal numbers are shown on the bottom of the switch. Part No. Position DRS7110C DRR7110C 0 1 2 3 4 5 6 7 8 9 ● Real code ● ● ● ● Position DRS7016C DRR7016C 0 1 2 3 4 5 6 7 8 9 A B C D E F ● Complementary code ● ● ● ● ● ● ● DRS7116C DRR7116C 0 1 2 3 4 5 6 7 8 9 A B C D E F :Terminal E is ground terminal Terminal # 2 4 8 ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● Terminal # 2 4 8 ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● Actuator color:Red Position Terminal numbers are shown on the bottom of the switch. 1 ● Part No. Production date code Right Angle ● Part No. Straight DRR7016C DRR7116C 1 Actuator color:Yellow Production date code Terminal numbers are shown on the bottom of the switch. Actuator color:Red 1 ● ● ● ● ● ● ● ● Terminal # 2 4 8 ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ●…Connection to common (C). Washable DRS・DRR8000C DRS8010C DRS8110C Production date code ● Real code Straight DRR8010C DRR8110C Part No. Position DRS8010C DRR8010C 0 1 2 3 4 5 6 7 8 9 ● Complementary code Production date code ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● Terminal numbers are shown on the bottom of the switch. Position DRS8110C DRR8110C 0 1 2 3 4 5 6 7 8 9 ● Real code Right Angle Terminal numbers are shown on the bottom of the switch. ● ● ● ● ● Part No. Position DRS8016C DRR8016C 0 1 2 3 4 5 6 7 8 9 A B C D E F ● Complementary code Terminal # 2 4 8 ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● Terminal # 2 4 8 1 ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● Actuator color:Red Part No. Position DRS8116C DRR8116C 0 1 2 3 4 5 6 7 8 9 A B C D E F Production date code 1 Actuator color:Yellow Production date code Terminal numbers are shown on the bottom of the switch. Actuator color:Red Part No. Straight DRR8016C DRR8116C Terminal # 2 4 8 1 Terminal numbers are shown on the bottom of the switch. Right Angle DRS8016C DRS8116C Actuator color:Yellow :Terminal E is ground terminal 1 ● ● ● ● ● ● ● ● Terminal # 2 4 8 ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ●…Contact closed DRS・DRR7000C/8000C ■ PCB Footprints Washable    (Top view) Straight Right Angle DRS7000C/8000C DRR7000C/8000C Terminal style Footprint dimensions ■ Packaging Specifications Series Stick-Tube Specifications ※Order in 50 piece increments. ■ Soldering Specifications (1)Manual Soldering 350℃, 3 sec. Max (2)Flow 245~260℃, Max.; 3 to 5 seconds (One time) Total dip time within 10 sec. ■ Switch Operation Use a screwdriver for setting position of the actuator. ■ Flux Cleaning After soldering, wait until the switches cool down to room temperature (30℃ or below) before washing. If the switches are cleaned while still above 30℃, a vacuum will occur which will cause the cleaning solution to be sucked into the switches.
DRR7016C 价格&库存
很抱歉,暂时无法提供与“DRR7016C”相匹配的价格&库存,您可以联系我们找货
