FH28K-50S-0.5SH
FH28K-50S-0.5SH
    HRS(广濑)
    SMD,P=0.5mm,卧贴
    FPC/FFC连接器 间距:0.50mm 50Pin 翻盖式 卧贴
FH28K-50S-0.5SH 数据手册
0.5mm/1mm Pitch, 2.55mm Height, 125℃ Heat Resistant FPC/FFC Connectors FH28K Series Robust Lock Design Retention tabs prevent the actuator from coming off. Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Each contact is attached to the actuator and provides support. Fig.1 ■Features 1. 125℃ heat resistance The FPC positioning mechanism and FPC tabs help to guide and hold the FPC prior to engaging the actuator The 125℃ heat resistance design makes FH28K ideal for use in applications requiring high heat resistance such as automotive. 2. Highly reliable connection and robust design High pin count connectors require a reinforced connector body and high FPC/FFC retention. With its unique FPC/ FFC positioning mechanism and robust design that prevents accidental disengagement, the FH28K Series achieves high connection reliability. 3. Flip lock provides superior operability The flip lock design makes it easier to engage/disengage the actuator and reduces the required force needed to operate. A clear tactile click is delivered upon the successful completion of the mating process. (Fig.1) 4. Enhanced FPC/FFC retention force Compared to Hirose's 0.5mm pitch connector the FH12 Series, vertical retention force for the FPC/FFC is 2.5 times stronger and horizontal retention force is 2 times stronger. *Horizontal retention force value achieved by use of FPC positioning tabs. Use of FPC without positioning tabs results in a horizontal retention value equivalent to FH12 Series. Fig.2 Can also be used with straight sided, non-tabbed FPC/FFC 5. Compatible with 0.3mm FPC/FFC thickness Compatible with easy to manufacture and easy to insert 0.3mm thick FPC/FFC. 6. No pattern prohibited area on bottom of connector (Overmolding Design) The bottom of the connector is fully covered with resin, eliminating contact exposure and any restrictions on PCB pattern routing for enhanced design freedom. 7. Pick & Place Mounting Offered in tape and reel packaging that is compatible with automatic machine mounting. (2,000pcs/reel) 8. Halogen-free All materials and substances used to produce this product comply with Halogen-free standards. *Defined according to IEC61249-2-21. Br: 900ppm maximum, Cl: 900ppm maximum, Br+Cl : 1,500ppm maximum Fig.3 9. Multiple packing options The standard packaging is 2,000pcs/reel, but FH28K is also offered in 500pcs/reel. (The outer diameter of the reel will be Ø330mm in this case.) In cases where the application will demand a high level of reliability, such as automotive, please contact a company representative for further information. 2021.3⑤ 1 FH28K Series●0.5mm/1mm Pitch, 2.55mm Height, 125℃ Heat Resistant FPC/FFC Connectors ■Product Specifications Rated Current 0.5A Rated Voltage 50Vrms AC Ratings Adaptive FPC/FFC Contact Specifications Storage Temperature Range -10 to +50ç (Note 2) Storage Humidity Range Relative humidity 90% or less (no condensation) t=0.3±0.05 Gold plating 125ç Heat Resistant FPC/FFC Item Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Operating Temperature Range -40 to +125ç (Note 1) Operating Humidity Range Relative humidity 90% or less (no condensation) Specification Conditions 1. Insulation Resistance Minimum of 500Mø Measured with 100V DC 2. Withstanding Voltage No flashover or breakdown 150Vrms AC is applied for 1 min. 3. Contact Resistance Maximum of 50mø *Includes FPC/FFC conductor resistance Measured at 1mA (DC or 1,000Hz) 4. Mating Durability Contact Resistance : Maximum of 50mø No damaged, cracked or looseness of parts 20 mating cycles 5. Vibration Resistance No electrical discontinuity of 1µs or greater Contact Resistance : Maximum of 50mø No damages, cracks and looseness of parts Frequency: 10 to 55Hz Single amplitude of 0.75mm for 10 cycles in 3 axial directions 6. Shock Resistance No electric discontinuity of 1µs or greater Contact Resistance : Maximum of 50mø No damaged, cracked or looseness of parts Acceleration of 981m/s2, 6ms duaration, sine half-wave waveform 3 cycles in each of the 3 axis 7. Humidity Resistance of Steady State Contact Resistance : Maximum of 50mø Insulation Resistance : Minimum of 50Mø No damaged, cracked or looseness of parts 96 hours at temperature : 60ç and humidity : 90 to 95% 8. Temperature Cycles Contact Resistance : Maximum of 50mø Insulation Resistance : Minimum of 50Mø No damaged, cracked or looseness of parts Temperature : -40/+15 to +35/+125/+15 to +35ç Time : 30/2 to 3/30/2 to 3 minutes 1000 cycles 9. Solder Heat Resistance Should not have external deformity or loose parts Reflow : according to the Recommended Temperature Profile Hand solder : 350±10ç for 5 seconds Note 1 : Includes temperature rise caused by current flow. Note 2 : The term "storage" here refers to products stored for a long period prior to board mounting and use. The operating temperature and humidity range covers the non-energized condition of connectors after board mounting and the temporary storage. ■Materials / Finish Component Insulator Contact Metal fitting Materials Color/Finish LCP LCP Copper Alloy Brass Gray Black Partially Gold Plated Pure Tin Plating Remarks UL94V-0 ----------------------------- ■Product Number Structure Refer to the chart below when determining the product specifications from the product number. Please select from the product numbers listed in this catalog when placing orders. FH 28K H - 50 (25) S B - 0.5 SH (98) ❶ ❷ ❸ ❹ ❺ ❻ ❼ ❶ Series Name : FH ❷ Series No. : 28K ❸ None : Standard type H : Space-saving type ❹ Standard type : The number of positions Eccentric type : Number of positions in 0.5mm housing ❺ Standard type : Blank Eccentric type : Number of positions 2 ❽ ❾ ❻ Contact arrangement : Single (single row) ❼ Eccentric direction : Blank…Standard type (without eccentricity) B…Eccentric type (contacts on the opposite side of polarity mark) ❽ Contact Pitch : 0.5mm, 1mm ❾ Mounting direction , SH...SMT horizontal mounting type Specification : Blank …Standard, 2,000 pcs/reel (98)…500 pcs/reel FH28K Series●0.5mm/1mm Pitch, 2.55mm Height, 125℃ Heat Resistant FPC/FFC Connectors ■Connector Dimensions 0.5mm Pitch Product A±0.1 Contact No.1 0.5±0.1 (1.9) (0.2) 2 3 0.05MAX ) 6° (11 a 0 Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. E±0.3 5.7±0.2 +0.1 0.1MAX C 0 D±0.2 8 a (1.3) (4.15) (4.95) 1.2±0.2 b 4.5±0.2 2 3 (5.4) B±0.2 HRS Mark No. of Pos. 2.55±0.2 Cav No. Polarity Mark 1.3±0.2 ** △ A 0.05MAX 0 0.1MAX 0.7±0.2 Notes 1 2 3 4 5 6 7 The dimension in parentheses are for reference. Lead co-planarity including retention tabs shall be 0.1 max. Indicates dimensions from surface b. Delivered in tape and reel packages. See the packaging specifications for details. Note that preventive hole for sink mark or slits could be added for improvement. Black spots may appear on the molded plastic however this does not represent a quality issue. This product satisfies halogen free requirements defined as 900ppm maximum chlorine, 900ppm maximum bromine, and 1500ppm maximum total of chlorine and bromine. 8 FH28KH has retention tabs extending outward from the connector body as shown in the diagram. ■Connector Dimensions Table Part No. FH28K-10S-0.5SH(**) Unit : mm HRS No. No. of Pos. A B C D E 586-1876-0 ** 10 4.5 9.9 5.57 9.58 6.5 FH28K-15S-0.5SH(**) 586-1883-0 ** 15 7 12.4 8.07 12.08 6.5 FH28K-20S-0.5SH(**) 586-1879-0 ** 20 9.5 14.9 10.57 14.58 6.5 FH28K-28S-0.5SH(**) 586-1880-0 ** 28 13.5 18.9 14.57 18.58 6.5 FH28K-30S-0.5SH(**) 586-1877-0 ** 30 14.5 19.9 15.57 19.58 6.5 FH28K-40S-0.5SH(**) 586-1878-0 ** 40 19.5 24.9 20.57 24.58 6.5 FH28K-45S-0.5SH(**) 586-1884-0 ** 45 22 27.4 23.07 27.08 6.5 FH28K-50S-0.5SH(**) 586-1875-0 ** 50 24.5 29.9 25.57 29.58 6.5 FH28K-55S-0.5SH(**) 586-1881-0 ** 55 27 32.4 28.07 32.08 6.5 FH28K-60S-0.5SH(**) 586-1872-0 ** 60 29.5 34.9 30.57 34.58 6.5 FH28K-64S-0.5SH(**) 586-1882-0 ** 64 31.5 36.9 32.57 36.58 6.5 FH28K-68S-0.5SH(**) 586-1873-0 ** 68 33.5 38.9 34.57 38.58 6.5 FH28K-74S-0.5SH(**) 586-1885-0 ** 74 36.5 41.9 37.57 41.58 6.5 FH28KH-80S-0.5SH(**) 586-1874-0 ** 80 39.5 44.9 40.57 45.7 6   3 FH28K Series●0.5mm/1mm Pitch, 2.55mm Height, 125℃ Heat Resistant FPC/FFC Connectors ■Connector Dimensions 1mm Pitch Product (2.7) 1±0.1 A±0.1 (0.2) (3.2) (1.9) Contact No.1 ** HRS Mark 2.55±0.2 1.3±0.2 Cav No. Polarity Mark B±0.2 2 3 6.5±0.3 5.7±0.2 ) 6° (11 Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 0.05MAX 0 0.1MAX +0.1 (1.3) (4.15) (4.95) C 0 D±0.2 1.2±0.2 Notes 1 2 3 4 5 6 7 b 4.5±0.2 (5.4) △ A 2 3 0.05MAX 0 0.1MAX 0.7±0.2 The dimension in parentheses are for reference. Lead co-planarity including retention tabs shall be 0.1 max. Indicates dimensions from surface b. Delivered in tape and reel packages. See the packaging specifications for details. Note that preventive hole for sink mark or slits could be added for improvement. Black spots may appear on the molded plastic however this does not represent a quality issue. This product satisfies halogen free requirements defined as 900ppm maximum chlorine, 900ppm maximum bromine, and 1500ppm maximum total of chlorine and bromine. ■Connector Dimensions Table Unit : mm Part No. HRS No. No. of Pos. A B C D FH28K-20(10)SB-1SH(**) −−− 10 9 14.9 10.57 14.58 FH28K-30(15)SB-1SH(**) −−− 15 14 19.9 15.57 19.58 FH28K-40(20)SB-1SH(**) −−− 20 19 24.9 20.57 24.58 FH28K-50(25)SB-1SH(**) −−− 25 24 29.9 25.57 29.58 FH28K-60(30)SB-1SH(**) −−− 30 29 34.9 30.57 34.58 FH28K-64(32)SB-1SH(**) −− − 32 31 36.9 32.57 36.58 FH28K-68(34)SB-1SH(**) −− − 34 33 38.9 34.57 38.58 Note : Contact positions without HRS No. are currently planned for development. Please contact Hirose for detailed information about product variation. 4 FH28K Series●0.5mm/1mm Pitch, 2.55mm Height, 125℃ Heat Resistant FPC/FFC Connectors BRecommended PCB Layout BRecommended Metal Mask Dimensions for 0.5mm Pitch Products for 0.5mm Pitch Products Recommended metal mask thickness : t= 0.15 1.3±0.1 X nX 0.3±0.03 0.05 X (Connector Outside) 0.5 A 2.2±0.1 2.2±0.1 F±0.1 G±0.1 nX 0.05 Y F±0.1 G±0.1 Standard Type(FH28K) Standard Type(FH28K) Recommended metal mask thickness : t= 0.15 nX 0.05 X (Connector Outside) 1±0.1 X 0.3±0.03 A Y 0.25±0.03 0.5 nX 0.05 Y 1.8±0.1 4.2±0.1 (0.5) A 0.5 4.2±0.1 1.3±0.1 Contact No.1 1.8±0.1 Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Y 0.25±0.03 0.5 3.9±0.1 (0.5) A 3.9±0.1 1.3±0.1 Contact No.1 F±0.1 F±0.1 G±0.1 G±0.1 Space-saving Type(FH28KH) Space-saving Type(FH28KH) Note : 'n' indicates the number of positions. BRecommended PCB Layout and Metal Mask Dimensions Part No. Unit : mm HRS No. No. of Pos. A F G FH28K-10S-0.5SH(**) 586-1876-0 ** 10 4.5 7 10.6 FH28K-15S-0.5SH(**) 586-1883-0 ** 15 7 9.5 13.1 FH28K-20S-0.5SH(**) 586-1879-0 ** 20 9.5 12 15.6 FH28K-28S-0.5SH(**) 586-1880-0 ** 28 13.5 16 19.6 FH28K-30S-0.5SH(**) 586-1877-0 ** 30 14.5 17 20.6 FH28K-40S-0.5SH(**) 586-1878-0 ** 40 19.5 22 25.6 FH28K-45S-0.5SH(**) 586-1884-0 ** 45 22 24.5 28.1 FH28K-50S-0.5SH(**) 586-1875-0 ** 50 24.5 27 30.6 FH28K-55S-0.5SH(**) 586-1881-0 ** 55 27 29.5 33.1 FH28K-60S-0.5SH(**) 586-1872-0 ** 60 29.5 32 35.6 FH28K-64S-0.5SH(**) 586-1882-0 ** 64 31.5 34 37.6 FH28K-68S-0.5SH(**) 586-1873-0 ** 68 33.5 36 39.6 FH28K-74S-0.5SH(**) 586-1885-0 ** 74 36.5 39 42.6 FH28KH-80S-0.5SH(**) 586-1874-0 ** 80 39.5 42 45.6 5 FH28K Series●0.5mm/1mm Pitch, 2.55mm Height, 125℃ Heat Resistant FPC/FFC Connectors BRecommended PCB Layout BRecommended Metal Mask Dimensions A X 0.3±0.03 nX 0.05 X (Connector Outside) 1 Recommended metal mask thickness : t= 0.15 3.9±0.1 1.3±0.1 Contact No.1 for 1mm Pitch Products 1.25±0.1 1.75±0.1 F±0.1 G±0.1 A Y 0.25±0.03 1 nX 0.05 Y 1.25±0.1 1.75±0.1 F±0.1 G±0.1 2.2±0.1 2.2±0.1 3.9±0.1 1.3±0.1 (0.5) for 1mm Pitch Products Note : 'n' indicates the number of positions. BRecommended PCB Layout and Metal Mask Dimensions BRecommended FPC/FFC C0 .5 Dimensions M AX for 0.5mm Pitch Products 0.5±0.1 G 15.6 20.6 25.6 30.6 35.6 37.6 39.6 Z 0.5±0.1 ±0.1 R0.2 0.3±0.05 0.1 3.5MIN 2.8±0.1 1.4±0.1 0.5 H±0.1 J±0.07 A nX 0.35±0.03(FPC) 0.05 Z 0.3±0.03(FFC) Unit : mm F 12 17 22 27 32 34 36 R0.2± R0.2±0.1 R0. 2M AX Contact No.1 Note : 'n' indicates the number of positions. 4.5MIN Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Part No. HRS No. No. of Pos. A FH28K-20(10)SB-1SH(**) −−− 10 9 FH28K-30(15)SB-1SH(**) −−− 15 14 FH28K-40(20)SB-1SH(**) −−− 20 19 FH28K-50(25)SB-1SH(**) −−− 25 24 FH28K-60(30)SB-1SH(**) −−− 30 29 FH28K-64(32)SB-1SH(**) −−− 32 31 FH28K-68(34)SB-1SH(**) −−− 34 33 Note : Contact positions without HRS No. are currently planned for development. Please contact Hirose for detailed information about product variation. BRecommended FPC/FFC Dimensions HRS No. 586-1876-0 ** 586-1883-0 ** 586-1879-0 ** 586-1880-0 ** 586-1877-0 ** 586-1878-0 ** 586-1884-0 ** 586-1875-0 ** 586-1881-0 ** 586-1872-0 ** 586-1882-0 ** 586-1873-0 ** 586-1885-0 ** 586-1874-0 ** AX 5M 0. Dimensions A 4.5 7 9.5 13.5 14.5 19.5 22 24.5 27 29.5 31.5 33.5 36.5 39.5 C BRecommended FPC/FFC Unit : mm No. of Pos. 10 15 20 28 30 40 45 50 55 60 64 68 74 80 1±0.1 1 3.5MIN 2.8±0.1 1.4±0.1 for 1mm Pitch Products H±0.1 J±0.07 A nX 0.05 Z 0.6±0.03 Note : 'n' indicates the number of positions. H 7.1 9.6 12.1 16.1 17.1 22.1 24.6 27.1 29.6 32.1 34.1 36.1 39.1 42.1 Z 0.5±0.1 .1 R0.2±0 .1 0 R0.2± R0.2±0.1 R0 .2M AX Contact No.1 BRecommended FPC/FFC Dimensions Part No. HRS No. No. of Pos. A FH28K-20(10)SB-1SH(**) −−− 10 9 FH28K-30(15)SB-1SH(**) −−− 15 14 FH28K-40(20)SB-1SH(**) −−− 20 19 FH28K-50(25)SB-1SH(**) −−− 25 24 FH28K-60(30)SB-1SH(**) −−− 30 29 FH28K-64(32)SB-1SH(**) −−− 32 31 FH28K-68(34)SB-1SH(**) −−− 34 33 Note : Contact positions without HRS No. are currently planned for development. Please contact Hirose for detailed information about product variation. 6 J 5.5 8 10.5 14.5 15.5 20.5 23 25.5 28 30.5 32.5 34.5 37.5 40.5 0.3±0.05 4.5MIN Part No. FH28K-10S-0.5SH(**) FH28K-15S-0.5SH(**) FH28K-20S-0.5SH(**) FH28K-28S-0.5SH(**) FH28K-30S-0.5SH(**) FH28K-40S-0.5SH(**) FH28K-45S-0.5SH(**) FH28K-50S-0.5SH(**) FH28K-55S-0.5SH(**) FH28K-60S-0.5SH(**) FH28K-64S-0.5SH(**) FH28K-68S-0.5SH(**) FH28K-74S-0.5SH(**) FH28KH-80S-0.5SH(**) Unit : mm H 12.1 17.1 22.1 27.1 32.1 34.1 36.1 J 10.5 15.5 20.5 25.5 30.5 32.5 34.5 FH28K Series●0.5mm/1mm Pitch, 2.55mm Height, 125℃ Heat Resistant FPC/FFC Connectors BFH28K Series FPC/FFC Material Configuration (Recommended Specifications) 1. Single-Sided FPC FPC : Flexible Printed Circuit Layer Cover Lay Film Materials Polymide Thickness (µm) 1mil (25) Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Cover Adhesive (25) Surface Treatment Nickel Under Plating 1~5µm+ gold plating 0.2µm Copper Foil Cu Base Adhesive Heat Stiffener Adhesive 25 Base Film Polymide 25 Stiffener Adhesive Heat Stiffener Adhesive Reinforcing Film Polymide 3 1oz 35 1mil 30 7mil 175 Total 2. Double-Sided FPC 293 FPC : Flexible Printed Circuit Layer Cover Lay Film Materials Polymide Thickness (µm) (25) 1mil (25) Cover Adhesive Surface Treatment Nickel Under Plating 1~5µm+ Gold Plating 0.2µm Through Hole Copper Cu Copper Foil Cu Base Adhesive Heat Stiffener Adhesive 18 Base Film Polymide 25 Base Adhesive Heat Stiffener Adhesive Copper Foil Cu Cover Adhesive Heat Stiffener Adhesive 25 Cover Lay Film Polymide 25 Stiffener Adhesive Heat Stiffener Adhesive Reinforcing Film Polymide * Remove the copper foil on the back of double-sided FPC to avoid damage due to FPC bending. 3. FFC 3 15 18 1/2oz 1mil 18 (18) 1/2oz 1mil 50 100 4mil 297 Total FFC : Flexible Flat Cable Layer Materials Thickness (µm) Polyester Film Adhesive 12 Polyester Thermal Plasticity Annealed Copper Foil (Gold Plated with Nickel Under Plating) Adhesive 35 Polyester Type Polyester Adhesive Reinforcing Film 30 30 12 Polyester Type 30 Polyester Type 188 Total 295 Nominal thickness tolerance is approximately ±20µm. 1. These specifications are an example of the material configuration of an FPC/FFC (t= 0.3 ±0.05) used on the FH28K series. 2. Please contact the FPC/FFC manufacturer for the material configurations of their FPC/FFC. 7 FH28K Series●0.5mm/1mm Pitch, 2.55mm Height, 125℃ Heat Resistant FPC/FFC Connectors BPackaging Specifications ●Embossed Carrier Tape Dimensions ●Embossed Carrier Tape Dimensions .1 +00 5 Ø1. (3) (0.3) 4±0.1 2±0.15 12±0.1 1.75±0.1 4±0.1 2±0.15 12±0.1 +0.1 0 Ø1.5 P±0.1 Q±0.3 (K) (L) (M) N±0.1 (K) (L) (M) N±0.1 Q±0.3 (3) (0.3) (with a maximum tape width of 32mm) 1.75±0.1 (with a maximum tape width of 24mm) (Ø1 3) ●Reel Dimensions (Ø380) (Ø80) (T:Reel Inside Width) (U:Reel Outside Width) ●Leader, Trailer Dimensions End Section Empty Pockets (10 Pockets Min.) 8 Loaded Product Section Leader (400mm Min.) Empty Pockets (10 Pockets Min.) Embossed Carrier Tape Top Cover Tape (R) (S) 1.5 +0.1 0 1.7 Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Unreeling Direction +0.15 0 (R) (S) Unreeling Direction FH28K Series●0.5mm/1mm Pitch, 2.55mm Height, 125℃ Heat Resistant FPC/FFC Connectors BPackaging specification dimensions for 0.5mm pitch products Part No. HRS No. No. of Pos. K L M N P Q R S T U 586-1876-0 ** 10 5.5 10.3 11.3 11.5 − −− 24 7.1 8.5 25.4 29.4 FH28K-15S-0.5SH(**) 586-1883-0 ** 15 8 12.8 13.8 11.5 − − − 24 7.1 8.5 25.4 29.4 FH28K-20S-0.5SH(**) 586-1879-0 ** 20 10.5 15.3 16.3 11.5 −− − 24 7.1 8.5 25.4 29.4 FH28K-28S-0.5SH(**) 586-1880-0 ** 28 14.5 19.3 20.3 14.2 28.4 32 7.1 8.5 33.4 37.4 FH28K-30S-0.5SH(**) 586-1877-0 ** 30 15.5 20.3 21.3 14.2 28.4 32 7.1 8.5 33.4 37.4 FH28K-40S-0.5SH(**) 586-1878-0 ** 40 20.5 25.3 −−− 20.2 40.4 44 7.1 8.5 45.4 49.4 FH28K-45S-0.5SH(**) 586-1884-0 ** 45 23 27.8 28.8 20.2 40.4 44 7.1 8.5 45.4 49.4 FH28K-50S-0.5SH(**) 586-1875-0 ** 50 25.5 30.3 −− − 20.2 40.4 44 7.1 8.5 45.4 49.4 FH28K-55S-0.5SH(**) 586-1881-0 ** 55 28 32.8 − − − 20.2 40.4 44 7.1 8.5 45.4 49.4 FH28K-60S-0.5SH(**) 586-1872-0 ** 60 30.5 35.3 36.3 26.2 52.4 56 7.1 8.5 57.4 61.4 FH28K-64S-0.5SH(**) 586-1882-0 ** 64 32.5 37.3 − −− 26.2 52.4 56 7.1 8.5 57.4 61.4 FH28K-68S-0.5SH(**) 586-1873-0 ** 68 34.5 39.3 40.3 26.2 52.4 56 7.1 8.5 57.4 61.4 FH28K-74S-0.5SH(**) 586-1885-0 ** 74 37.5 42.3 43.3 26.2 52.4 56 7.1 8.5 57.4 61.4 FH28KH-80S-0.5SH(**) 586-1874-0 ** 80 40.5 45.3 46.3 26.2 52.4 56 6.6 8 57.4 61.4   BPackaging specification dimensions for 1mm pitch products Unit : mm Part No. HRS No. No. of Pos. K L M N P Q R S T U FH28K-20(10)SB-1SH(**) −−− 10 10.5 15.3 16.3 11.5 −− − 24 7.1 8.5 25.4 29.4 FH28K-30(15)SB-1SH(**) − −− 15 15.5 20.3 21.3 14.2 28.4 32 7.1 8.5 33.4 37.4 FH28K-40(20)SB-1SH(**) −−− 20 20.5 25.3 −−− 20.2 40.4 44 7.1 8.5 45.4 49.4 FH28K-50(25)SB-1SH(**) −− − 25 25.5 30.3 −−− 20.2 40.4 44 7.1 8.5 45.4 49.4 FH28K-60(30)SB-1SH(**) −− − 30 30.5 35.3 36.3 26.2 52.4 56 7.1 8.5 57.4 61.4 FH28K-64(32)SB-1SH(**) −− − 32 32.5 37.3 −−− 26.2 52.4 56 7.1 8.5 57.4 61.4 FH28K-68(34)SB-1SH(**) −−− 34 34.5 39.3 40.3 26.2 52.4 56 7.1 8.5 57.4 61.4 Note : Contact positions without HRS No. are currently planned for development. Please contact Hirose for detailed information about product variation. BRecommended soldering profile MAX 250℃ 245 220 220℃ 180℃ 180 Temperature(℃) Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. FH28K-10S-0.5SH(**) Unit : mm 150 150℃ 100 25 0 25℃ Start 120±5sec. Preheating Time 20 to 40sec. Peak Temperature Heating Time 60 to 90sec. Soldering Time (Seconds) Applicable Conditions Reflow type : Far red/hot air reflow Reflow furnace atmosphere : Atmosphere Reflow soldering : 2 cycles Max. Soldering : Cream type Sn/3.0Ag/0.5Cu (M705-GRN360-K2-V made by Senju Metal Industry Co.) Testing PCB : PCB material and size Glass epoxy 80×100×1.6mm Land size, per recommended PCB layout. Metal mask : Thickness and opening size per recommended metal mask dimensions This solder profile is based on the conditions provided above. Please check the mounting conditions before use. Conditions such as solder paste types, manufacturer, PCB size and any other soldering materials may alter the performance of such materials. 9 FH28K Series●0.5mm/1mm Pitch, 2.55mm Height, 125℃ Heat Resistant FPC/FFC Connectors BOperation Methods of Connector and Precautions Operation Method 1. FPC/FFC Insertion Method 1 Rotate the actuator upward unlock. The actuator can be easily operated with the use of a thumb nail or index finger. Usage Precautions 1 The actuator on the FH28K Series connector is designed to open to a maximum of 116 degrees, trying to open it farther than that will lead to damage. Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 116˚ 2 Insert the FPC/FFC into the insertion slot as show below. Improper insertion may result in FPC/FFC damage or conduction failure. 2 Insert the FPC/FFC with the contact surface facing down. Inser the FPC/FFC at an angle from above the connector. Insert until it is securely held in positioning portion of connector. Lightly pull on the FPC/FFC to confirm it is held in place. Refer to the next page for further details. Positioning Portion 3 This connector is not designed to withstand a large amount of force in the upward direction. Secure the FPC/FFC if a force will be applied. 3 Rotate the actuator downward. 4 When inserting an FPC/FFC to a connector with a high pin count (80pos.), please use two fingers to close the actuator on both sides. Using one finger to press on the center of the actuator may result in incomplete actuator closing. 2. FPC/FFC Removal 1 Rotate the actuator upward, then lift the FPC/FFC upward after the actuator has been released and pull the FPC/FFC out. 10 5 When inserting FPC/FFC, do not rub against the underside of the connector insertion port. Otherwise, the contact and FPC/FFC will strongly hit against each other which may result in contact deformation or FPC/FFC conductor peeling. FH28K Series●0.5mm/1mm Pitch, 2.55mm Height, 125℃ Heat Resistant FPC/FFC Connectors BCautions when Mating FFC/FPC with Positioning Tabs Operation Method Usage Precautions 1. Insertion Position 2 FPC/FFC must not overlap Insert the cable so that the positioning tabs are secured into the gap ( ) between the molded walls on both sides of the connector ( ) and the guide walls on both sides of the connector interior ( ). Do not close the actuator until the FPC/FFC has been placed into its correct position. If it is sitting on the guides and the actuator closes onto it, it can cause damage and conduction failure. Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Overlapping on Left Guide Overlapping on Right Guide 2. Cautions during Insertion/Mating 1 Do not insert the cable at a skewed angle. The cable Normal Insertion corner may get caught in the terminal resulting in contact deformation. Skewed Insertion Closing the actuator with the cable sitting on the guide. Insert the cable straight into the connector opening and hook the cable tab onto the guide. Pull the cable towards yourself with a slight force after insertion, and close the actuator after confirming that the cable tab is completely secured. If it cannot be pulled to out, the cable is inserted in the correct position. Recommended Mating Method 1 Insert the cable straight from above the connector at an angle. In case you accidentally close the lock with the cable sitting on the guides, do not move the cable around. Open the actuator immediately and reposition the cable as explained in “1. Insertion Position” noted above. Moving the cable after closing the actuator with the cable sitting on the guide. 2 Pull the cable lightly towards yourself and check if the tab is secured. Pulling Direction 3 Close the actuator. 11 Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. FH28K Series●0.5mm/1mm Pitch, 2.55mm Height, 125℃ Heat Resistant FPC/FFC Connectors 2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN https://www.hirose.com/ 12 The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use. The contents of this catalog are current as of date of 03/2021. Contents are subject to change without notice for the purpose of improvements.
FH28K-50S-0.5SH 价格&库存
很抱歉,暂时无法提供与“FH28K-50S-0.5SH”相匹配的价格&库存,您可以联系我们找货
FH28K-50S-0.5SH
  • 2000+8.748642000+1.13326
  • 4000+8.331334000+1.07920
  • 6000+8.096646000+1.04880
  • 10000+7.8103510000+1.01172
库存:4873
